[Geoserver-users] Exception serving GeoTIFF.
Hi List,
I have a GeoTIFF that I’ve created using the stuff from the previous thread (
gdal_merge -q -o file_name.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=85 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 --optfile tiff_list.txt
gdaladdo Aerial_Photography_2000.tif -r average --config COMPRESS_OVERVIEW JPEG --config JPEG_QUALITY_OVERVIEW 85 --config INTERLEAVE_OVERVIEW PIXEL --config PHOTOMETRIC_OVERVIEW YCBCR 2 4 8 16 32 64 128 256
However, when I add it to GeoServer (2.4.1) I get this:
Error rendering coverage on the fast path
javax.media.jai.util.ImagingException: All factories fail for the operation "ImageRead"
null
java.lang.IndexOutOfBoundsException: imageIndex out of bounds!
The gdalinfo:
Files: Aerial_2006_jpeg.tif
Size is 220000, 332000
Coordinate System is:
PROJCS[“OSGB 1936 / British National Grid”,
GEOGCS[“OSGB 1936”,
DATUM[“OSGB_1936”,
SPHEROID[“Airy 1830”,6377563.396,299.3249646000044,
AUTHORITY[“EPSG”,“7001”]],
AUTHORITY[“EPSG”,“6277”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4277”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,49],
PARAMETER[“central_meridian”,-2],
PARAMETER[“scale_factor”,0.9996012717],
PARAMETER[“false_easting”,400000],
PARAMETER[“false_northing”,-100000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“27700”]]
Origin = (402000.000000000000000,311000.000000000000000)
Pixel Size = (0.250000000000000,-0.250000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=YCbCr JPEG
INTERLEAVE=PIXEL
SOURCE_COLOR_SPACE=YCbCr
Corner Coordinates:
Upper Left ( 402000.000, 311000.000) ( 1d58’13.45"W, 52d41’46.79"N)
Lower Left ( 402000.000, 228000.000) ( 1d58’15.23"W, 51d57’ 0.21"N)
Upper Right ( 457000.000, 311000.000) ( 1d 9’23.50"W, 52d41’36.01"N)
Lower Right ( 457000.000, 228000.000) ( 1d10’14.15"W, 51d56’49.71"N)
Center ( 429500.000, 269500.000) ( 1d34’ 1.66"W, 52d19’20.70"N)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Overviews: 110000x166000, 55000x83000, 27500x41500, 13750x20750, 6875x10375, 3438x5188, 1719x2594, 860x1297
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
The image works fine in ArcGIS.
Does anyone know what this means or why it’s not working?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Dear Jonathan,
two things:
-1- we would need a large portion of the stacktrace
-2- a sample might be worth a thousand words :slight_smile:
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Thu, Nov 28, 2013 at 1:40 PM, Jonathan Moules
<jonathanmoules@anonymised.com> wrote:
Hi List,
  I have a GeoTIFF that I've created using the stuff from the previous
thread (
operation &quot;ImageRead&quot;
All factories fail for the operation &quot;ImageRead&quot;
null
The gdalinfo:
PROJCS["OSGB 1936 / British National Grid",
    GEOGCS["OSGB 1936",
        DATUM["OSGB_1936",
            SPHEROID["Airy 1830",6377563.396,299.3249646000044,
                AUTHORITY["EPSG","7001"]],
            AUTHORITY["EPSG","6277"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4277"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",-2],
    PARAMETER["scale_factor",0.9996012717],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",-100000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","27700"]]
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 402000.000, 311000.000) ( 1d58'13.45"W, 52d41'46.79"N)
Lower Left ( 402000.000, 228000.000) ( 1d58'15.23"W, 51d57' 0.21"N)
Upper Right ( 457000.000, 311000.000) ( 1d 9'23.50"W, 52d41'36.01"N)
Lower Right ( 457000.000, 228000.000) ( 1d10'14.15"W, 51d56'49.71"N)
Center ( 429500.000, 269500.000) ( 1d34' 1.66"W, 52d19'20.70"N)
Does anyone know what this means or why it's not working?
Jonathan
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don't have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics
Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Simone,
Thanks for this, but I ended up re-creating the Tiffs using a newer version of GDAL now that I’ve found one that works. It now works fine. No idea what was wrong with the previous one.
Thanks again,
Jonathan
On 28 November 2013 19:28, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Dear Jonathan,
two things:
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi List,
thread (
–optfile tiff_list.txt
–config PHOTOMETRIC_OVERVIEW YCBCR 2 4 8 16 32 64 128 256
null
The gdalinfo:
GEOGCS[“OSGB 1936”,
DATUM[“OSGB_1936”,
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
Jonathan
organizations don’t have a clear picture of how application performance
Pro!
np :slight_smile:
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Mon, Dec 2, 2013 at 11:34 AM, Jonathan Moules
Hi Simone,
of GDAL now that I've found one that works. It now works fine. No idea what
Thanks again,
Jonathan
Dear Jonathan,
two things:
Simone Giannecchini
more information.
@simogeo
Founder/Director
> Hi List,
> thread (
> -co
> COMPRESS_OVERVIEW
> PIXEL
>> null
> The gdalinfo:
> GEOGCS["OSGB 1936",
> DATUM["OSGB_1936",
> UNIT["metre",1,
> Metadata:
> AREA_OR_POINT=Area
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Thanks,
> Jonathan
> or
> error
> us,
> recording
> your
> AppDynamics
> Pro!
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
