[Geoserver-users] exception unable to solve
I had the following exception when I press generate button whilst creating a new feature type.
The following exception was thrown:
org.geotools.data.DataSourceException: Could not count Request All Features
** `I tried googling, but was not exactly enlightend. Can anyone help?`
Thanks
Regards
Kim Sia
Extension: 3160
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
What kind of dataset are you using? (shapefile, postgis, oracle...).
Also, make sure you have the correct SRS value defined. If your data is in a projection other than the SRS you defined, you probably won't get back any features and it could cause this problem.
Brent Owens
(The Open Planning Project)
Sim Kim Sia wrote:
/|org.geotools.data.DataSourceException: Could not count Request All Features|/
/||/ |I tried googling, but was not exactly enlightend. Can anyone help?|
|| |Thanks|
Regards
Kim Sia
Extension: 3160
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Hi Brent,
I am uisng shapefiles and postgis and that I have ensure that srid in the
data is the same as the SRS defined.
But I am still getting the same errors.
Is it possible that this is due to postgres version?
Thanks
Brent Owens
Sim Kim Sia wrote:
Features|/
|Thanks|
Regards
Kim Sia
Extension: 3160
message
disclose
security?
easier.
Geronimo
