[Geoserver-users] Export data from geoserver.
Hi!.
I would need to export all data from a Geoserver to mix with other data from another Geoserver different. What can we do? I've tried with no result.
Thanks.
-Francisco.
Francisco Luis López ha scritto:
Hi!.
The question is quite generic.
One example of doing what you ask is to use the WFS GetFeature SHAPE-ZIP
format to extract data in shapefile format and then use ogr2ogr with the
  -append parameter to merge the two shapefiles into one.
http://gdal.osgeo.org/ogr2ogr.html
Andrea Aime
OpenGeo - http://opengeo.org
Expert support for open source geospatial.
