[Geoserver-users] Export KML problem with 1.7 RC2
we transfered our datas on geoserver 1.7.0 RC2 and we got a problem when
exporting them in KML.
The file .kml looks good, but the WMS gives an extrud polygon as result...
so our polygons are no longer displayed on the same ground as the map...
how can we change this <extrud> parameter and why this trouble appears ?
thks for help
Flo
View this message in context: http://www.nabble.com/Export-KML-problem-with-1.7-RC2-tp19620830p19620830.html
floflo ha scritto:
afaik David (cc'ed) was working on extrusion but the work was not complete, and he did back out his changes so that they won't appear
in 1.7.0-RC3. When it's out can you double check and see if the problem
went away for you?
Andrea Aime
OpenGeo - http://opengeo.org
Andrea Aime-4 wrote:
went away for you?
got a solution for this problem :
add '&format_options=altitudeMode:clampToGround' as parameter
source :
http://jira.codehaus.org/browse/GEOS-2194
Flo
View this message in context: http://www.nabble.com/Export-KML-problem-with-1.7-RC2-tp19620830p19638466.html
