I upgraded to 2.21-RC but I still have the error on startup when using the GSR plugin (essential for me):
12 002 13:02:52 WARN [support.XmlWebApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gsrDispatcher’ defined in URL [jar:file:/home/nico/gs.bak-2.21-RC/webapps/geoserver/WEB-INF/lib/gs-gsr-2.21-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
12 002 13:02:52 WARN [support.DisposableBeanAdapter] - Destroy method ‘destroy’ on bean with name ‘gwcMemoryBlobStore’ threw an exception: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@anonymised.com rejected from java.util.concurrent.ThreadPoolExecutor@anonymised.com[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
12 002 13:02:52 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘geoWebCacheExtensions’: Singleton bean creation not allowed while singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
12 002 13:02:52 ERROR [context.ContextLoader] - Context initialization failed
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:602)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:516)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:324)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
So I still have to use a 2.18.x version.
I would appreciate if anyone has an idea how to fix it.
Nico
The GSR extension continues to be a community module which is provided on a completely unsupported model. It gets even less support than a standard extension and is not tested when new code is added to geoserver so there is every chance that it is broken by recent updates. If you are unable to fix it yourself you will need to find a developer who can fix it. If it is essential to your company then you will be able to determine how much the work is worth to you. Or you can continue to run an out of date and insecure version, after telling the world about it.
Ian
On Thu, 12 May 2022, 14:46 Nicolas Matzick, <nicolas.matzick@anonymised.com> wrote:
Nico
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
