we observed the same issue after upgrading to GeoServer 2.13.1.
Unfortunately we haven't found a quick fix for a running instance except
patching the underlying imageio-ext library used in GS. The patch is
available as a PR here [1].
Daniel
[1] https://github.com/geosolutions-it/imageio-ext/pull/163
Am 05.06.2018 um 13:00 schrieb Chris Buckmaster:
I have recently upgraded from Geoserver 2.11.0 to 2.13.1 and have found
my external graphics for point layers are not displaying (they revert to
a default grey symbol).
Is there anything wrong in my code, or has anything changed between 2.11
and 2.13 which might be causing problems? Inaccessibility problems for
Geoserver to online resources?
An example of my xml is below:
<StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.1.0"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd"
xmlns:se="http://www.opengis.net/se">
<NamedLayer>
<se:Name>cctv\_cameras</se:Name>
<UserStyle>
<se:FeatureTypeStyle>
<se:Rule>
<se:Name>Single symbol</se:Name>
<se:PointSymbolizer>
<se:Graphic>
<se:ExternalGraphic>
<se:OnlineResource xlink:type="simple"
xlink:href="http://maps.runnymede.gov.uk/website/maps/png/community/cctv_cameras.png"/>
<se:Format>image/png</se:Format>
</se:ExternalGraphic>
</se:Graphic>
</se:PointSymbolizer>
</se:Rule>
</se:FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Check out the vibrant tech community on one of the world's most
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
M.Sc. Geographie Daniel Koch
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Kölnstraße 99
53111 Bonn
Tel: +49 (0)228 / 96 28 99 -553
Fax: +49 (0)228 / 96 28 99 -57
Email: koch@anonymised.com
Web: http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Torsten Brassat, Marc Jansen,
Hinrich Paulsen, Till Adams
Informationen über Ihre gespeicherten Daten finden Sie auf
unserer Homepage unter folgendem Link:
https://www.terrestris.de/datenschutzerklaerung/
