Hi
We are testing an External (cascading) WFS datasource in geoserver 2.4.2.
We just use some of the bathing waters WFS available from EA.
The datastore setup is working, it is only when trying to add a layer from
the datastore that we get a failure, the layer can not be found.
Caused by: org.geotools.data.SchemaNotFoundException: Feature type could not
be found for wfs:ea-wfs-bathing_waters_inspire at
org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getSchema(WFS_1_1_0_DataStore.java:257)
at
org.geotools.data.wfs.v1_1_0.WFSFeatureSource.<init>(WFSFeatureSource.java:69)
at
org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getFeatureSource(WFS_1_1_0_DataStore.java:590)
at
org.geotools.data.wfs.v1_1_0.WFS_1_1_0_DataStore.getFeatureSource(WFS_1_1_0_DataStore.java:108)
at
org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:158)
at
org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:293)
at
org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:46)
at
org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:329)
at
org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:300)
... 95 more
To our opinon, not sure about this, it seems that Geoserver addedd the wfs:
namespace to th eeffective layer name ea-wfs-bathing_waters_inspire.
Could it be that this is not found on the host as unknown (name with
namesapce wfs)?
Is it possible to set geoserver not use tha wfs namespace in this case?
tx
Luc
View this message in context: http://osgeo-org.1560.x6.nabble.com/external-wfs-get-schema-geoserver-adds-a-wfs-namespace-to-the-layername-tp5102864.html
Hi Luc,
It is not clear where/when you see the error, I will assume it is when you try to add a layer.
I think problem can be because of several reasons:
Is table placed in correct schema (default is public)? Is the schema name spelled correctly?
Does the user geoserver use in datastore definition has privileges to read the table?
Leo
On Mon, Feb 10, 2014 at 2:42 AM, lucvanlinden <luc.vanlinden@anonymised.com> wrote:
Hi
at
org.geotools.data.wfs.v1_1_0.WFSFeatureSource.(WFSFeatureSource.java:69)
at
at
at
at
at
at
at
… 95 more
namesapce wfs)?
tx
Luc
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
