Ooohhhps! you're right. What a stupid mistake. I think in the future i will move to a real XML-editor with validation functions. Now it works for me too. And the hint with the size is valuable either.
Thanks a lot Alida
Albrecht
Albrecht Weiser,
E6, GIS Center
Hessische Zentrale für Datenverarbeitung (HZD)
Mainzer Straße 29, 65185 Wiesbaden
Tel.: 0611 340-3113
Fax: 0611 340-5113
E-Mail: albrecht.weiser-at-hzd.hessen.de
Albrecht, I think you simply have a typo:
OnlineRessource - too many "s" in there - should be OnlineResource
Also, I've found that the value of Size should match the value of the
image's height for best results.
Otherwise, it can get stretched or squished or be too small.
You might want
to check that just in case.I have some working examples at these URLs if you're interested:
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:pol
ygon_example_diagonal_graphic&s=sld
ygon_example_fill_graphics
ygon_example_trans_graphic
View this message in context:
http://www.nabble.com/SLD%3A-ExtarnalGraphic-does-not-work-tp1
8927405p18946078.html
