[Geoserver-users] Fail to load from war file - java.lang.NoClassDefFoundError: org/geotools/data/DataStoreFactorySpi
Hi.
I had a working geoserver installation which I haven't looked at for a
couple of weeks. I went to log in this morning and couldn't. I have removed
the geoserver directory, reloaded the war file and restarted tomcat but even
with a brand new geoserver installation I get the same problem. I haven't
changed any profile settings although it is a hosted server so the hosts may
have done.
Can anyone give me any ideas what would cause this problem?
Thanks. Dan
View this message in context: http://www.nabble.com/Fail-to-load-from-war-file---java.lang.NoClassDefFoundError%3A-org-geotools-data-DataStoreFactorySpi-tf3155116.html#a8749033
lunarfish ha scritto:
Hi.
have done.
The web app classpath is broken. Why, I don't know... maybe you have to
clean up the working directory as well, if you can. Or re-install the
container...
