I’m running Geoserver 2.3.2 and I’ve set up a layer using the timeseries[1] functionality to hold a single layer consisting of a lot of constuction plans stored as geotiffs (i’ve modified the regexp property file to just read an single integer value instead of an timeentry as index and I then request the correct plan with a filter.
All has been working fine for the last 6months but lately I was going to add new tifs to the layer and then faced some problem.
I moved the new files into the folder where the other imagefiles resides, removed the generated property file and dropped the database table. As I understand this would force Geoserver to reindex the mosaic and include all the new files.
So what happens? The database table is generated as is the properties file. All the previous imagefiles are being indexed and inserted into the database table but not the new ones. The table is the same as before I added the new files.
Anyone got any pointers on what could be causing this?
Thank you
Vänliga Hälsningar
Lukas
Lukas Bergliden
Civilingenjör
Mobil 070 644 96 61 Electrum 234, 164 40 Kista
Direkt 08 630 75 09 Kistagången 16, 7 tr
