Thanks Andrea.
The error was resolved with your recommendations. But now I have another problem. The Codehaus repository is closed and the extension gs -charts tries to connect to it. I removed that repository from pom file located in the root of Geoserver,however the error persists . The mistake that sends me now is:
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project’s POM).
Project ID: org.geotools:gt-charts
Reason: Error getting POM for ‘org.geotools:gt-charts’ from the repository: Unable to read local copy of metadata: Cannot read metadata from ‘/home/javalos/.m2/repository/org/geotools/gt-charts/11-SNAPSHOT/maven-metadata-codehaus.xml’: only whitespace content allowed before start tag and not T (position: START_DOCUMENT seen T… @1:1)
org.geotools:gt-charts:pom:11-SNAPSHOT
for project org.geotools:gt-charts
Thanks for everything
2015-08-24 2:28 GMT-05:00 Andrea Aime <andrea.aime@anonymised.com>:
On Mon, Aug 24, 2015 at 9:22 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’ve fixed them, now you can build GeoServer by:
- Checking out GeoTools 12.x and build it locally, to get fresh jars from it
- Build GeoServer with -nsu, to make sure Maven does not try to get GeoTools jars from the maven repositories
Hum nope, never mind… GeoServer still does not build.
Hmm… ah, GeoServer 2.5.x depends on GeoTools 11.x, not 12.x
So, you’ll need a local build of that one
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Servicios Computacionales y Asesoría en Sistemas de Información Geográfica
Francisco Javier Avalos Zapata
Ciudad Victoria, Tamaulipas
javalos@anonymised.com
