Hi
I get this error message frequently in the Geoserver log. I've searched the
repositories for help, but cant find any. Someone who knows when this may
occur? is it possible to find out which request that forces the error?
Regards
Anders Erlandsson
View this message in context: http://osgeo-org.1560.x6.nabble.com/Failed-to-derive-native-bbox-from-declared-one-tp5106580.html
Hi Anders,
I’ve not seen this error myself, but you should be able to look at your tomcat/jetty logs to see what request was made to the server at the time that the geoserver.log entry was made. If it was a GET request it should/may include the entire request allowing you to replicate it.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 28 February 2014 11:39, sbkkae <anders.erlandsson@anonymised.com> wrote:
Hi
I get this error message frequently in the Geoserver log. I’ve searched the
Regards
Anders Erlandsson
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Its a simple getcapabilities request that makes geoserver log full of these
errors:
/geoserver/wms?request=getcapabilities
View this message in context: http://osgeo-org.1560.x6.nabble.com/Failed-to-derive-native-bbox-from-declared-one-tp5106580p5149018.html
