*Hello List
I reinstalled GeoServer rel. 2.2.4, when creating a layer when I make the bounding boxes I find the following error:*
2013-04-10 18:39:52,570 WARN [geotools.jdbc] - Failed to use
SDO_TUNE.EXTENT_OF, falling back on envelope aggregation
java.sql.SQLException: ORA-44003: nome SQL non valido
ORA-06512: a "MDSYS.SDO_TUNE", line 571
ORA-06512: a line 1
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:194)
at
oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:853)
at
oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
at
oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1469)
at
oracle.jdbc.driver.OracleStatementWrapper.executeQuery(OracleStatementWrapper.java:389)
at
org.apache.tomcat.dbcp.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at
at
at
org.geotools.data.oracle.OracleDialect.getOptimizedBounds(OracleDialect.java:749)
at
org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1123)
at
org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:501)
at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:426)
at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:363)
at
org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:591)
at
org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:556)
at
org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:538)
at
org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:115)
*Do you know where is the problem? Our software environment is:**
On Wed, Apr 10, 2013 at 9:55 PM, Angelo <angelo.digiorgio@anonymised.com>wrote:
*Hello List
ORA-06512: a line 1
at
at
at
at
at
at
at
at
at
at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1123)
at
at
at
at
at
at
at
As you can see, it's a WARN, not an ERROR. It means the fast path for
computing an envelope was tried,
and failed. Not fatal, it will just take longer to compute the bbox.
You might be affected by this one: http://jira.codehaus.org/browse/GEOS-5535
Hi Angelo,
I picked up on this a few months ago, which is the ticket Andrea is pointing to. Its fixed in 2.2.5 and 2.3 (thanks again Andrea ).
Its not much of an issue with small datasets (few thousand features), but 100,000 plus and it’ll lock up the GeoServer admin interface for noticeable periods of time. Get into the millions and it can be several hours!
So if you have larger datasets, its worth upgrading.
Jonathan
Hello List I reinstalled GeoServer rel. 2.2.4, when creating a layer when I make the bounding boxes I find the following error:
2013-04-10 18:39:52,570 WARN [geotools.jdbc] - Failed to use SDO_TUNE.EXTENT_OF, falling back on envelope aggregation
ORA-06512: a “MDSYS.SDO_TUNE”, line 571
ORA-06512: a line 1
at oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:853)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1469)
at oracle.jdbc.driver.OracleStatementWrapper.executeQuery(OracleStatementWrapper.java:389)
at org.apache.tomcat.dbcp.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.data.oracle.OracleDialect.getOptimizedBounds(OracleDialect.java:749)
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:501)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:426)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:363)
at org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:591)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:556)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:538)
at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:115)
As you can see, it’s a WARN, not an ERROR. It means the fast path for computing an envelope was tried,
