Hello,
Thanks Ian and Rahkonen for your suggestions - I have tried the
following four WMS requests:
http://localhost:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&WIDTH=459
&HEIGHT=353&LAYERS=sprint21:DepthArea&TRANSPARENT=TRUE&FORMAT=image/png&
BBOX=-1.304114,50.724729,-1.040936,50.817929&SRS=EPSG:4326&STYLES=
http://localhost:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&VERSION=1
.1.0&WIDTH=459&HEIGHT=353&LAYERS=sprint21:DepthArea&TRANSPARENT=TRUE&FOR
MAT=image/png&BBOX=50.724729,-1.304114,50.817929,-1.040936&SRS=EPSG:4326
&STYLES=
&STYLES=
Unfortunately, all four of these requests still give me the same
bounding box error.
I presume I am switching the coordinates correctly? i.e. BBOX=minX,
minY, maxX, maxY should become BBOX=minY,minX,maxY,maxX?
Neil Kirk - could you try the WMS requests above to see if you get the
same problem?
Any other suggestions?
Many thanks,
Ryan
-----Original Message-----
From: Rahkonen Jukka [mailto:jukka.rahkonen@anonymised.com]
Sent: 07 November 2013 18:03
Subject: Re: [Geoserver-users] Failing to Render WMS PNG Image
I would start with the Geoserver demo layers and with complete WMS
GetMap requests. Especially I recommend to always use SERVICE and
VERSION with OGC web services even they are not always compulsory by the
standard.
OpenJUMP comes with a nice BeanShell tool which shows the GetMap url
that was used for fetching the image on the map. Here are examples for
the "states" layer and for WMS 1.1.1 and 1.3.0
SERVICE=WMS&
REQUEST=GetMap&
SERVICE=WMS&
VERSION=1.1.1&
WIDTH=459&
HEIGHT=353&
LAYERS=topp:states&
TRANSPARENT=TRUE&
FORMAT=image/png&
BBOX=-125.964082115,14.004707960577342,-65.737188885,60.32299403942266&
SRS=EPSG:4326&
STYLES=
http://localhost:8080/geoserver/ows?
SERVICE=WMS&
REQUEST=GetMap&
SERVICE=WMS&
VERSION=1.3.0&
WIDTH=459&
HEIGHT=353&
LAYERS=topp:states&
TRANSPARENT=TRUE&
FORMAT=image/png&
BBOX=14.004707960577342,-125.964082115,60.32299403942266,-65.737188885&
CRS=EPSG:4326&
STYLES=
Pay attention to the order of lat and lon in the BBOX when using the
EPSG:4326 system.
Ryan Moody wrote:
Hello,
I have a WFS set up which is successfully returning me feature data in
the GML 3.1 format. I'm now trying to generate a PNG image through a WMS
request, but unfortunately I'm given the following error:
"Rendering process failed null Details:
org.geoserver.platform.ServiceException: Rendering process failed".
From the stack trace, it appears that the bounding box I am specifying
in my WMS request is incorrect. However, I'm requesting the same
bounding box that is automatically computed by GeoServer. Can someone
please advise me where I may be going wrong?
Best Regards,
Ryan
WMS request:
http://localhost:8080/geoserver/wms?request=GetMap&width=100&height=100&
layers=DepthArea&format=image/png&count=1&srs=EPSG:4326&bbox=-1.304114,5
Stack trace:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.d
td"> <ServiceExceptionReport version="1.1.1" > <ServiceException
code="internalError">
null
Details:
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedIm
ageMapOutputFormat.java:507)
at
ageMapOutputFormat.java:251)
at
ageMapOutputFormat.java:123)
at
org.geoserver.wms.GetMap.executeInternal(GetMap.java:521)
at org.geoserver.wms.GetMap.run(GetMap.java:253)
at org.geoserver.wms.GetMap.run(GetMap.java:124)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:
328)
at sun.reflect.GeneratedMethodAccessor245.invoke(Unknown
Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(
AopUtils.java:319)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinp
oint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(Ref
lectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInt
erceptor.java:34)
at
lectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMa
pService.java:61)
at
pService.java:35)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.j
ava:73)
at
ava:54)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.ja
va:54)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAo
pProxy.java:202)
at $Proxy65.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor214.invoke(Unknown
Source)
at
at
org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abs
tractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handl
e(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherS
ervlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherSe
rvlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(Framewor
kServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.
java:778)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1093)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCle
anupFilter.java:27)
at
dler.java:1084)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelega
tingFilter.java:74)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFi
lter.java:45)
at
dler.java:1084)
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchF
ilter.java:49)
at
dler.java:1084)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:109)
at
dler.java:1084)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doF
ilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain
.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityIntercep
tor.invoke(FilterSecurityInterceptor.java:116)
at
tor.doFilter(FilterSecurityInterceptor.java:83)
at
.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServe
rCompositeFilter.java:91)
at
ilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFil
ter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doF
ilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationF
ilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilte
r(GeoServerBasicAuthenticationFilter.java:82)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilte
r.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$
1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainPr
oxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoSer
verSecurityFilterChainProxy.java:134)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(Dele
gatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(Delegating
FilterProxy.java:259)
at
dler.java:1084)
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at
dler.java:1084)
at
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
dler.java:1084)
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.jav
a:47)
at
dler.java:1084)
at
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at
dler.java:1084)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:2
16)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:206)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:114)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConne
ction.java:828)
at
org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:
395)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:450)
Caused by: java.lang.IllegalArgumentException
at
org.geotools.filter.FilterFactoryImpl.bbox2d(FilterFactoryImpl.java:434)
at
org.geotools.filter.FilterFactoryImpl.bbox(FilterFactoryImpl.java:423)
at
org.geotools.data.complex.filter.UnmappingFilterVisitor.visit(UnmappingF
ilterVisitor.java:539)
at
org.geotools.renderer.lite.FastBBOX.accept(FastBBOX.java:127)
at
org.geotools.data.complex.AppSchemaDataAccess.unrollFilter(AppSchemaData
Access.java:593)
at
org.geotools.data.complex.AppSchemaDataAccess.unrollQuery(AppSchemaDataA
ccess.java:319)
at
org.geotools.data.complex.AbstractMappingFeatureIterator.getUnrolledQuer
y(AbstractMappingFeatureIterator.java:315)
at
org.geotools.data.complex.AbstractMappingFeatureIterator.<init>(Ab
stractMappingFeatureIterator.java:202)
at
org.geotools.data.complex.DataAccessMappingFeatureIterator.<init>(
DataAccessMappingFeatureIterator.java:135)
at
org.geotools.data.complex.MappingFeatureIteratorFactory.getInstance(Mapp
ingFeatureIteratorFactory.java:193)
at
org.geotools.data.complex.MappingFeatureCollection.features(MappingFeatu
reCollection.java:174)
at
org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer
.java:2475)
at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRen
derer.java:2045)
at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.jav
a:829)
at
ageMapOutputFormat.java:481)
... 103 more
</ServiceException></ServiceExceptionReport>
November Webinars for C, C++, Fortran Developers Accelerate application
performance with scalable programming models. Explore techniques for
threading, error checking, porting, and tuning. Get the most from the
latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clk
trk
Geoserver-users mailing list
