hmm
You were able to color the points in previous geoserver versions with
kml? Right now I think it is just the placemark that is returned
because there isn't a symbolizer for points in KML. I will have
another peek at it.
SLD filters are in there and do work, but maybe not in all cases. If
you can send me an SLD as a test case I can take a look into it.
Brent
On 9/12/06, Scott Pezanowski <scottpez@anonymised.com> wrote:
Brent, Chris or others,
Since I upgraded geoserver, I have noticed that point feature symbology is
not displayed correctly in google earth (kml). For example, I have some
points that are colored red and some that are colored orange in my sld.
However, all points only show up in orange in google earth. With geoserver
1.3.0-PR1 (my previous install), the point features were correctly displayed
with red and orange point symbols. If I make a regular wms request for the
points, they are displayed with the correct colors.
Another thing I would like to do is use sld filters to only display some of
the points. However, it seems that all points are displayed instead of the
filtered subset.
Am I doing something wrong or should I log these as bugs? My current
Geoserver version is 1.3.3.
Scott
********************************************* Scott
Pezanowski
email: scottpez@anonymised.com
To: Scott Pezanowski
CC: cholmes@anonymised.com,
geoserver-devel@lists.sourceforge.net,
geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-devel] [Geoserver-users] feature attributes within
kml
Date: Thu, 07 Sep 2006 09:43:08 -0700
Hi Scott
Upgrading to a newer version should fix the issue. (1.3.1+)
Brent Owens
(The Open Planning Project)
Scott Pezanowski wrote:
>Chris,
>Thanks for getting back to me. I have tried a polygon layer and it
>does not seem to work either. With polygon's I can not even click
>on the features to get a popup.
>In my previous email, I forgot to mention that I am using Geoserver
>1.3.0-PR1.
>Thanks,
>Scott
>Scott Pezanowski email: scottpez@anonymised.com
> From: Chris Holmes
> CC: geoserver-users@lists.sourceforge.net,
> Subject: Re: [Geoserver-users] feature attributes within kml
> Date: Thu, 07 Sep 2006 12:03:16 -0400
> >Hi,
> >I am successfully serving up some kml through geoserver to
>Google
> >Earth. One of the layers that I am serving up is a point
>layer. Is
> >there a way currently to have attributes of the points show
>up in
> >the info popup when the user clicks on the points in Google
>Earth?
> >Currently, when the user clicks on the points, a popup
>appears but
> >it has nothing within it.
> Hmmmm... I know this works with polygons - we add an extra
>point
> just to do this. Is it working for you on polygons? If it's
>just
> not working for points then it should be pretty easy to add.
> >If this functionality does not exist, could anyone gives me
>some
> >tips to start with for implementing something like this?
> Sure, but just want to make sure that it does work for
>polygons for
> you, that it's a general issue.
> Chris
> >Thank you in advance for any help,
> >Scott
> >Scott Pezanowski
> >!DSPAM:1003,450041f2193607731818748!
> >Using Tomcat but need to do more? Need to support web
>services,
> >security?
> >Get stuff done quickly with pre-integrated technology to make
>your
> >job easier
> >Download IBM WebSphere Application Server v.1.0.1 based on
>Apache
> >Geronimo
>http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> >_______________________________________________
> >Geoserver-users mailing list
> >Geoserver-users@lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geoserver-users
> Chris Holmes
> http://topp.openplans.org
> << cholmes.vcf >>
>Using Tomcat but need to do more? Need to support web services,
>security?
>Get stuff done quickly with pre-integrated technology to make your
>job easier
>Download IBM WebSphere Application Server v.1.0.1 based on Apache
>Geronimo
>Geoserver-devel mailing list
>Geoserver-devel@lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
