[Geoserver-users] Feature collection import into GeoServer through WPS
Dear all,
I am having trouble trying to import a feature collection into GeoServer
2.5.2 through the usage of the WPS 'gs:Import'.
In my WPS there are some chained process and at the end I would like to
import the result of the operations, which I've checked and it's correct.
When I run it on a localhost server it works. It take several minutes, about
7 or 8, but it does import the new create collection into GeoServer.
When I run it on a remote server it returns this error:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request POST /geoserver/TestWfsPost.
Reason: Error reading from remote server
Apache/2.4.7 (Ubuntu) Server at my-remote-server Port 80
But I noticed that the WPS doesn't stop and keeps running, indeed on
GeoServer log there are no errors.
At the end I still get the feature collection imported on GeoServer but I
need the WPS to return the name of the new layer as 'gs:Import' does.
What could be the problem? Do you know how to solve it?
Thanks for the help,
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Feature-collection-import-into-GeoServer-through-WPS-tp5211576.html
On Thu, Jun 18, 2015 at 10:32 AM, matteo.eccher <matteo.eccher@anonymised.com
wrote:
Proxy Error
It looks like you're using the request demo builder, or the demo requests
page (no reason to end up hitting TestWfsPost
otherwise), both are not really meant for production, just for simple tests
and learning the protocol.
It could be it's not working because of the apache proxy you setup... it
could
be that you haven't setup the "proxy base" in your configuration, but it's
also
possible that the demo pages simply do not work in a proxied enviroment.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the reply,
I forgot to mention that I also tried to call the WPS by a POST request from
a client on the same remote machine.
The error is almost the same, except the request url:
Proxy Error
The proxy server could not handle the request POST /geoserver/wps.
I have the same test client on my local machine and calling the local WPS
works.
Also, I don't know if it's relevant but if I remove the WPS 'gs:Import' from
the process chaining everything works.
Now I'll check the proxy configuration and come back with news.
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Feature-collection-import-into-GeoServer-through-WPS-tp5211576p5211596.html
Hi Matteo,
when you do the chaining, are you using the special URLs that will make
GeoSeverver avoid calling onto itself using HTTP?
It’s “http://geoserver/wps”, and it’s recognized to be the internal WPS, without
the need to make extra network calls.
On Thu, Jun 18, 2015 at 11:40 AM, matteo.eccher <matteo.eccher@anonymised.com> wrote:
Proxy Error
works.
Also, I don’t know if it’s relevant but if I remove the WPS ‘gs:Import’ from
Now I’ll check the proxy configuration and come back with news.
Matteo
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Hello Andrea,
I think what I'm doing is not proper "chaining" because I don't use any URL
inside my WPS.
Just to be sure I am doing the right thing I'll briefly explain you the
process.
The WPS I created "chains" some WPS together in Java by using the
ProcessFactory class.
I call the Process.execute method of the WPS I want to execute.
I take the result and put it in another Map then use it as input for the
next WPS.
Here an example:
Iterator<ProcessFactory> it = factories.iterator();
while(it.hasNext()) {
    ProcessFactory fact = (ProcessFactory) it.next();
    Name processName = new NameImpl("gs", "Unique");
    Set<Name> names = fact.getNames();
    if(names.contains(processName)) {
        Process p = fact.create(processName);
        inputs.put("features", collection);
        inputs.put("attribute", attribute1 + year2);
        outputs = p.execute(inputs, pl);
        results.put("uniqueResult", outputs.get("result"));
Then I build my WPS with Maven and put the '.jar' file in the Geoserver
WEB-INF/lib.
To call the WPS I make a POST request to the URL:
'http://my-remote-server/geoserver/wps’, as data I pass the XML containing
the wps:Execute the input and the putputs of the WPS.
By chaining the processes inside the WPS code, I have only one Execute in my
XML file.
I've done other WPSes like this and they seems to work.
I hope I've explained myself well.
Thanks again,
Matteo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Feature-collection-import-into-GeoServer-through-WPS-tp5211576p5211617.html
