[Geoserver-users] Feature - vector to raster/tiff image
Hello everybody,
I would know if any of you ever thought of generating “images” from a spatial database in the background. For example, if I have a large table of polygons and to gain performance I would create her image in the background and publish.
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Daniel,
This sounds like it would be an ideal situation for using the integrated GeoWebCache. Create the images once and they’re cached for future requests.
Jonathan
On 14 July 2014 22:24, Daniel Bevilacqua <danielunesp02@anonymised.com> wrote:
Hello everybody,
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-users mailing list
