[Geoserver-users] featureID within GetFeature requests
Right, and in WFS 1.0.0 the attribute is ”fid”.
Test with this
http://demo.opengeo.org/geoserver/wfs?service=wfs&version=1.0.0&request=getfeature&typename=topp:states&featureID=states.1
Rudy Commenge wrote:
When you perform GetFeature request with GML output format, featureID is the value of the “gml:id” attribute in the response.
Best Regards,
Rudy
2013/9/5 Jonathan Moules <jonathanmoules@anonymised.com>
Hi List,
I’m trying to use WFS GetFeature to get a specific feature - http://docs.geoserver.org/stable/en/user/services/wfs/reference.html#getfeature
The documentation says:
To limit the output you can restrict the GetFeature request to a single feature by including an additional parameter, featureID and providing the ID of a specific feature. In this case, the GET request would be:
What does this actually mean? What column is the featureID coming from? I can do it using a filter, but I’m just trying to understand what the featureID bit is actually for.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58041391&iu=/4140/ostg.clktrk
Geoserver-users mailing list
