[Geoserver-users] FeatureInfo problem
Hi
I have a problem using the FeatureInfo ( I use openlayers ).
I test the FeatureInfo with two Shapefiles
and if I request the Info of a geometry that belong to the bounding box of both of the Shapefiles Geoserver take a very long time to respond (and sometimes do not respond at all).
The rendering of the Shapefiles (WMS) is OK,
Thanks
Adil TAHRI
Expert Research
Adil Tahri ha scritto:
Hi
I test the FeatureInfo with two Shapefiles and if I request the Info of a geometry that belong to the bounding box of both of the Shapefiles Geoserver take a very long time to respond (and sometimes do not respond at all).
Not sure why. Can you send me by private mail the shapfiles in
question and their styles so that I can check out?
Andrea Aime
OpenGeo - http://opengeo.org
