[Geoserver-users] features send in wrong namespace using mysql-datastore
Hello Justin,
can you tell me which place must be fixed?
I am really interested in getting MySQL working with Geoserver.
Thanks a lot
Tim
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet: Donnerstag, 9. August 2007 16:18
An: Tim Englich
Cc: aaime; geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] features send in wrong namespace using
mysql-datastore
Hi Tim,
Looking at the code I believe you are correct. The DataStoreFactory
correctly looks up the namespace set by GeoServer but the datastore
seems to mishandle it.
The patch should be pretty simple. I could send it your way if you are
interested. I cant really just commit the change since i am not the
mysql module maintainer. Or do I have a mysql install around to test with.
-Justin
Tim Englich wrote:
Hello Andrea,
might it be possible that the Namespace will not be set to the params for
the
GeoTools DatastoreFinder?
I sometimes also have got the problem, that the Namespace is used as
DatabaseName.
Tim
Von: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net]Im Auftrag von
aaime
Gesendet: Donnerstag, 9. August 2007 12:06
An: geoserver-users@lists.sourceforge.net
mysql-datastore
Tim Englich-2 wrote:
Hello,
I have got an problem with the getFeature-Response of Geoserver when I
query
data from a MySQL-Datastore.
The features are set to the GML-Namespace and not to the namespace I set
to
the Datastore.
Has anyone an Idea how to solve this problem?
It seems you keep on hitting on datastores that have issues. MySql is
barely
mantained,
so I guess you'll have to roll a patch on it.
Oh, before starting have a look at the jira issues for mysql, there are
some
patches sitting there made by another user that I still haven't managed to
include in the code, it may be that there's one solving this problem
already
(haven't checked).
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Tim Englich ha scritto:
Hello Justin,
Tim,
Justin gave me a patch I'm going to integrate into gt2 2.4.x and trunk
right away (well, after creating a unit test and making sure it works).
You do need this for GeoServer 1.6.x right?
I'll let you know when I'm done.
