Hi Andrea,
you're right, it is a view with a primary key, and the primary key has a
value of 1 for all rows. I think I needed this when Geotools suddenly
required a primary key 1 year back. I need to revert these changes.
Sorry for the confusion.
CREATE VIEW V_KMMARKERINGEN_VWG_NAAM AS SELECT DISTINCT(VWG_NAAM), 1 AS
OGR_FID FROM V_KMMARKERINGEN ORDER BY VWG_NAAM
ALTER VIEW V_KMMARKERINGEN_VWG_NAAM ADD CONSTRAINT
PK_V_KMMARKERINGEN_VWG_NAAM PRIMARY KEY(OGR_FID) DISABLE NOVALIDATE;
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Andrea Aime <aaime@anonymised.com>
Naar: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Cc: Justin Deoliveira <jdeolive@anonymised.com>,
geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] fid generation
Datum: 14/11/07 11:47
Bart van den Eijnden (OSGIS) ha scritto:
> Hi Justin,
> I was using an Oracle table and not a PostgreSQL table (should have
> mentioned that before).
Bart, I tried out with one of my tables but could not reproduce.
Say I have a working table with a primary key called shapes, I did
something like:create table shapesnopk as select * from shapes
insert into USER_SDO_GEOM_METADATA select 'SHAPESNOPK', COLUMN_NAME,
DIMINFO, SRID from user_sdo_geom_metadata where table_name = 'SHAPES'This way I created a spatial clone with no pk, which I then queried
with wfs:
http://localhost:8080/geoserver/wfs?service=WFS&request=GetFeature&typeName=topp:SHAPESNOPK
and the fids I got back looked like:
shapesnopk.nfm--25fa8814_1163e66b9c2_-8000So it works for me, with the latest nightly. Are you sure that table
really has no pk?
