[Geoserver-users] Fill color in an SLD document
I am trying Geoserver 1.7.0-alpha1. I have two problems when using SLDs with a very simple FeatureType.
In this request:
http://java.imastedev.com/geoserver/wms?SRS=EPSG%3A4326&WIDTH=800&HEIGHT=377&LAYERS=ba%3Agbif_density_stats&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=-77.34375,-35.9482421875,77.34375,36.9482421875&SLD=http://java.imastedev.com/geoserver/sld/densityLayer.sld
Two things happen that are strange to me:
  1. In the default SLD document assigned to the FeatureType I have declared a Fill for the polygons using:
#cc0000 0.7
But the fill does not seem to take effect.
  1. I am trying to assign dynamically an SLD with a URL. Geoserver request it, because if it is wrong it throws an error. The remote SLD is exactly the same as the one defined as default for the FeatureType apart that I have changed the color of the stroke. But this change also does not seem to take effect.
The SLD in the server looks like this:
<?xml version="1.0" encoding="UTF-8"?> densityStatsLayer Style to draw density layers based on number of occurrences in gbif_density_stats Nothing to say for the moment Rule 1 RedFill RedOutline 50% transparent red fill with a red outline 1 pixel in width #cc0000 0.7 #ff6600 1
Any idea what is going wrong? Maybe Geoserver 1.7.0 lacks functionality? Should I go to the stable?
Thanks in advance.
Javier.
Javier de la Torre ha scritto:
When we say alpha, we really mean it :wink:
If you need geoserver for production, or just don't want to pull hairs
for your experiments with it, try 1.6.3 instead.
In this request:
1) In the default SLD document assigned to the FeatureType I have declared a Fill for the polygons using:
                        <Fill>
                            <CssParameter name="fill">#cc0000</CssParameter>
                            <CssParameter name="fill-opacity">0.7</CssParameter>
                        </Fill>
Yeah, that one has been fixed.
2) I am trying to assign dynamically an SLD with a URL. Geoserver request it, because if it is wrong it throws an error. The remote SLD is exactly the same as the one defined as default for the FeatureType apart that I have changed the color of the stroke. But this change also does not seem to take effect.
Same as above, it does not matter how you inputed it.
<?xml version="1.0" encoding="UTF-8"?> <StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd" xmlns="http://www.opengis.net/sld&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt; <NamedLayer> <Name>densityStatsLayer</Name> <UserStyle> <Title>Style to draw density layers based on number of occurrences in gbif_density_stats</Title> <Abstract>Nothing to say for the moment</Abstract> <FeatureTypeStyle> <!-- 1-9 --> <Rule> <Name>Rule 1</Name> <Title>RedFill RedOutline</Title> <Abstract>50% transparent red fill with a red outline 1 pixel in width</Abstract> <PolygonSymbolizer> <Fill> <CssParameter name="fill">#cc0000</CssParameter> <CssParameter name="fill-opacity">0.7</CssParameter> </Fill> <Stroke> <CssParameter name="stroke">#ff6600</CssParameter> <CssParameter name="stroke-width">1</CssParameter> </Stroke> </PolygonSymbolizer> </Rule> </FeatureTypeStyle> </UserStyle> </NamedLayer> </StyledLayerDescriptor>
You should definitely go with stable unless you have a very good reason
to stay with 1.7.0-alpha. 1.7 as is is less stable and quite a bit slower than 1.6.3, so unless you need wfs xlink support or wcs 1.1.1
support, I see no reason for using it.
cheers
Ok, ok... lot of reasons to downgrade...
When not in production i dont mind to go with the latest in order to help you find some bugs on the way, but this is clearly under production then.
Thanks.
Javier.
In this request:
                       <Fill>
                       </Fill>
cheers
