[Geoserver-users] filter arg for a WMS getMap request
Hello Andrea:
I am trying to use your solution for filtering data on the database
end (Postgis):
http://jira.codehaus.org/browse/GEOS-529
I am using geoserver trunk. Following your example from the bottom
doesn't seem to work for me. Do you know if the "filter=" parameter
should be functional in geoserver trunk?
This is my getMap request (same as your example):
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&Format=image/png&request=GetMap&layers=states&width=550&height=250&srs=EPSG:4326&filter=(<Filter><PropertyIsEqualTo><PropertyName>STATE_NAME</PropertyName><Literal>Illinois</Literal></PropertyIsEqualTo></Filter>)
Thanks in advance,
Alex
I 've got Alessio to help me with this.
Apparently the filter code was in, but not used. He commited a fix on
trunk and the sample request on the jira page works!!!
Alex
On 12/4/06, Alexander Petkov <greenkov@anonymised.com> wrote:
Hello Andrea:
end (Postgis):
Thanks in advance,
Alex
Yeah, I've noticed. I've been quite busy, sorry.
Thank you very much for the help Alessio :slight_smile:
Did this fix make it on to 1.4.x branch? Or was it a fix from 1.4 that didn't make it into trunk?
Alex
Hello Andrea:
end (Postgis):
Thanks in advance,
Alex
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
!DSPAM:1003,4575a81a276531194215290!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Chris:
I believe Alessio commited the changes to trunk only.
Alex
> Alex
>> Hello Andrea:
>> end (Postgis):
>> Thanks in advance,
>> Alex
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Chris Holmes
Chris:
Alex
I checked the states request on 1.4.x and was working, so probably
I forgot to add some changes to trunk.
> Chris:
> Alex
Does it work also against featureTypes from a Postgis datastore? So
far no luck here :frowning:
Alex
> Chris:
> Alex
I just tried with shapefile in fact, curious it may be dependent on
the specific datastore... can you check with a shapefile? If not,
open a jira issue.
Shapefile works indeed.
Was it not intended to work with Postgis featureTypes?
Alex
>> > Chris:
>> > Alex
>> that
>> Cheers
>> Andrea
open a jira issue.
Nope, the patch that adds filter does not have anything
to do with datastores, so I expect it to work with any kind
of datastore. Are you sure your filters do not have case issues
with attribute names? Like attributes being lowercase in the
feature type and you filter with upper case?
I will double-check.
Alex
