With Oracle you can control FID generation pretty well by creating a view and then primary key for the view. Geoserver will use that primary key for FIDs and there is no need to change primary key of the original table. Be carefull when creating the primary key for a view, Oracle cannot know if it is unique and that may leed to dublicated FIDs and troubles with WFS clients.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Thomas Jahnsen [mailto:thja@anonymised.com]
Lähetetty: ti 17.2.2009 16:02
Vastaanottaja: 'Andrea Aime'
Kopio: 'geoserver-users@lists.sourceforge.net'
Aihe: Re: [Geoserver-users] Filter by ID list
Hi
Well, it is really only one question, with various alternatives.
Well, I got the FID to work - the data was loaded with shp2pgsql, which adds its own primary key. I usually work with the street data in Oracle, where the primary key is link_id. I changed that, and the FID got a little better. But still, is it possible to skip the layer name prefix? Now it is like "navteq_streets_polyline.571393864".
I plan to overcome URL length problems by using POST. I can still use normal HTTP headers for POST, right? I don't have to use WMS XML query?
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
E-mail: thja@anonymised.com
Hi. Wow, many questions
> I am just starting to use filtering for WMS images. I wish to filter
> roads based on a list of IDs. The SQL equivalent I want to do is
"WHERE
> link_id IN (5500, 6600, 1111, 2154)". Such syntax doesn't work in
CQL.
> They have some functions in2, in3, up till in10, but these are
> open-ended lists that can count in the thousands.
No, OGC never defined a id filter for CQL. In GeoServer 2.0
we'll have our own extension of the base CQL sytanx, named
ECQL (Extended-CQL) that will support fid filters too.
Anyways, if you count in the thousands, you're out of luck, you'll
soon end up with a url too long for your browser/http server to handle.
> Are there some special syntax for CQL for this? Does OGC filters
support
> it? I see there is a FID-filter that takes a list of comma-separated
> IDs. Is it possible to make Feature ID use the primary key of the
data
> source table instead of some pseudorandom sequence that is completely
> useless for everything? The road network is stored in a PostGIS
database.
If you have a primary key, it will be used to generate the FIDs.
If you have random values, then the most likely cause it's that you
don't have a primary key on your table. Or the primary key has some
odd structure that we cannot handle, but I'm not aware of such a case.
Another case in which you get randomly generated fids is you using
a view. Unfortunately we don't have a way to configure GeoServer
so that it picks up the FID from a user defined field returned
by a view.
Andrea Aime
OpenGeo - http://opengeo.org
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
