jan_w
August 15, 2007, 9:29am
1
hi,
i’m doing the following request
http://server:8080/geoserver/wfs?VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&typename=lb:services&bbox=$box
this request worked until i changed the typename .
services is a oracle datastore, before i requested data from a shapefile :
http://server:8080/geoserver/wfs?VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&typename=lb:poi&bbox=$box
that worked, requesting the data from services i get an error :
<?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="[http://www.opengis.net/ogc](http://www.opengis.net/ogc)"
xmlns:xsi="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)"
xsi:schemaLocation="[http://www.opengis.net/ogc
](http://www.opengis.net/ogc) [http://loki.logiball.de:8080/geoserver/schemas//wfs](http://loki.logiball.de:8080/geoserver/schemas//wfs)
/1.0.0/OGC-exception.xsd">
<ServiceException>
Filter creation problem: null
Filter creation problem: null </ServiceException>
</ServiceExceptionReport>
whats wrong here?
regards,
Jan
jan w. ha scritto:
hi,
i'm doing the following request
Hmm... that may be anything. I assume $box is just a placeholder in your examples, but you replacing it with a real bbox spec before the request is sent, right?
Can you attach the full stack trace that you can find in the GeoServer logs?
