[Geoserver-users] Filter grouping in YSLD
It would be nice to have a possibility to group filters in YSLD styles.
For example, if we have a repeating condition (condition1):
  • rules:
  • filter: condition1 and condition2
    symbolizers:
  • polygon:
  • filter: condition1 and condition3
    symbolizers:
  • polygon:
then it could be grouped like this
  • rules:
  • filter: condition2
symbolizers:
  • polygon:
  • filter: condition3
    symbolizers:
  • polygon:
Any number grouping levels should be allowed.
Best regards,
Eugene
YSLD directly mirrors the structure of the SLD standard (using yaml rather than xml). As such I do not feel comfortable adjusting the representation too far from the original.
Can you experiment with YAML define to get the same affect? Rather than repeat “condition 1”?
See https://docs.geoserver.org/stable/en/user/styling/ysld/reference/variables.html
Jody Garnett
Could anyone help me clarify how to compose a CSS filter with a function returning boolean?
I thought this should be fine, but I get “Expecting Filter Parsing : equalTo(1,1).”
[equalTo(1,1)] {
:mark {
stroke: #e52e2e;
fill: #ff6c6c;
Thank you,
Laszlo
in OGC Filter, and by extension, in SLD and CSS, a function is not a filter, it’s an expression.
The filters are the alphanumeric and spatial comparisons. like, between, and the logical combinators.
In order to make that a filter you’ll have to write:
[equalTo(1, 1) = true]
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thank you, Andrea!
Could you also help me understand the following.
I try to add a new function to geoserver. The function I implemented is called properly, however the feature passed to the evaluate function seems to have only 2 properties however the feature should have tens of properties.
I call my function from CSS like this:
label: [npIsL1Splitter()];
And the evalute() is coded as below:
public T evaluate(Object object, Class context) {
String isL1;
if (object instanceof SimpleFeature) {
isL1 = isL1Splitter((SimpleFeature)object);
else {
isL1 = object.getClass().getName();
return Converters.convert(isL1, context); // convert to requested format
private String isL1Splitter(SimpleFeature feature) {
return (Integer.toString(feature.getAttributeCount());
Is there any “lasy” loading of properties?
Laszlo
Yes, only the properties explicitly referenced in the style are loaded from the source data,
so your function will have to have the necessary parameters explicitly listed as call arguments
Thanks. I was wondering how “property" feature function is working. Is it possible to load properties dymanically or at least indicate what propereties are needed for the function to work?
Laszlo
There is the “property” function that can be used to load properties dynamically, no other way.
For best performance is best to always indicate the properties needed in clear in the style.
Should it be referenced in the style anywhere or being argument of the function call?
If it is enough to reference, what is the best practice for a “noop” function to reference all attributes required by the functions of the style?
Laszlo
Best if it’s in the function call, functions should have explicit arguments, not implicit/magical ones.
Support for this kind of magic function could be added, but it requires development in GeoTools
(an interface to mark this type of function, and changes in the code to recognize the case in the style
attribute extraction code).
Contributions rules are here (read carefully):
https://github.com/geotools/geotools/blob/master/CONTRIBUTING.md
A similar case (referencing a dynamic property via the “property” function, making attribute resolution not
entirely predictable with static analysis) was added years ago, these two commits might give you some hints:
https://github.com/geotools/geotools/commit/d7d3d63019708eb02e3523020aa4d138196d8f3d
https://github.com/geotools/geotools/commit/6ae713f874688a0b6a91c4985fea248cb48a1f85
Also see the function tutorial:
http://docs.geotools.org/latest/userguide/tutorial/function.html
Dear Andrea,
Thank you!
László
