While looking for various performance improvements against my large dataset
in PostGIS, I came across a suggestion in the PostGIS manual at http://postgis.refractions.net/docs/ch05.html. The suggestion is to create a
new geometry column and populate it with:
UPDATE mytable set bbox = Envelope(Force_2d(the_geom));
This considerably speeds up the slow queries I tested directly against the
pgAdmin III interface. Is there a way to take advantage of this in
GeoServer? That is, can I specify the envelope column for the WHERE clause,
but continue to have the_geom column in the SELECT clause?
Can you quantify that "considerably"? 20%? 10 times?
Nope, there is no way to do so, at least not for WMS.
For WFS yes, you can manually select one and filter on the other, but it's not transparent.
