Hi
Unfortunatley our data source is set up with most of our item atributes in
one field delimited by commas. Is there any way to use the sld file to
filter the right atributes into rules to display certian icons. Something
similar to an instring command would be great.
I have found some xsl code here http://www.xml.com/pub/a/2003/05/07/tr.html
that does what i want but i'm unsure if its possible to use this in an sld
or else where in geoserver.
Thanks in advance
View this message in context: http://www.nabble.com/Filtering-delimited-field-in-SLD-t1609232.html#a4362703
Sent from the GeoServer - User forum at Nabble.com.
