Alex,
Just making sure you're following the geoserver-devel list. You should
find support for custom SLD requests to Geoserver WMS.
a) (http get) SLD=(URL) geoserver makes an http location to the SLD and
loads it
b) (http get) SLD_BODY=... send an SLD file to geoserver using GET
c) (http post) WMS GetMap 1.2 request Send the SLD (and other request
parameters) in a POST XML document. This is how the SLD spec says you
should do it.
d) (http post) GET Parameters, SLD in the Post Use http GET for the
parameters (ie. location and image size) and use POST for the SLD
dave
This mail sent through IMP: https://webmail.limegroup.com/
