Hi Lee Wai See,
If you go to the OGC site and look at the OpenGIS spec page:
http://www.opengeospatial.org/specs/?page=specs you can download the
<http://portal.opengeospatial.org/files/?artifact_id=8340> OpenGISR Filter
Encoding Implementation Specification It has many examples and a list of
the elements you can make use of in a filter.
<https://portal.opengeospatial.org/files/?artifact_id=1188> OpenGISR Styled
Layer Descriptor (SLD) Implementation Specification (SLD) is another spec
worth reading.
Here is one example:
<Rule>
<ogc:Filter xmlns:gml="http://www.opengis.net/gml">
<ogc:And>
<ogc:PropertyIsBetween>
<ogc:PropertyName>UN_GRAD__C</ogc:PropertyName>
<ogc:LowerBoundary>
<ogc:Literal>81</ogc:Literal></ogc:LowerBoundary>
<ogc:UpperBoundary>
<ogc:Literal>160</ogc:Literal></ogc:UpperBoundary>
</ogc:PropertyIsBetween>
<ogc:And>
<ogc:LowerBoundary><ogc:Literal>100</ogc:Literal></ogc:LowerBoundary>
<ogc:UpperBoundary><ogc:Literal>102</ogc:Literal></ogc:UpperBoundary>
<ogc:PropertyName>BOT_TEMP__</ogc:PropertyName>
<ogc:LowerBoundary><ogc:Literal>0</ogc:Literal></ogc:LowerBoundary>
<ogc:UpperBoundary><ogc:Literal>360</ogc:Literal></ogc:UpperBoundary>
</ogc:And>
</ogc:And>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<Mark>
<WellKnownName>circle</WellKnownName>
<Fill>
<CssParameter name="fill">#FF6600</CssParameter>
<CssParameter name="fill-opacity">1.0</CssParameter>
</Fill>
</Mark>
<Size>6</Size>
</Graphic>
</PointSymbolizer>
<PolygonSymbolizer>
<Fill>
</Fill>
</PolygonSymbolizer>
</Rule>
_____
[mailto:geoserver-users-admin@lists.sourceforge.net] On Behalf Of Lee Wai
See
Sent: Tuesday, February 28, 2006 3:27 AM
Subject: [Geoserver-users] Filtering
1. I understand that a request to the GeoServer can have filters in
it, as follows (in the xml form, not the url form):
http://localhost:8070/geoserver/wms?bbox=-130,24,-66,50&Format=image/png&req
uest=GetMap&width=550&height=250&srs=EPSG:4326&SLD_BODY=
<StyledLayerDescriptor version="1.0.0">
<UserLayer>
<Name>topp:states</Name>
<UserStyle>
<Name>UserSelection</Name>
<FeatureTypeStyle>
<Rule>
<Filter
<PropertyIsEqualTo>
<PropertyName>COUNTRY_NAME</PropertyName>
<Literal>USA</Literal>
</PropertyIsEqualTo>
</Filter>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#FF0000</CssParameter>
</Fill>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</UserLayer>
</StyledLayerDescriptor>
Can I filter with more than one condition (property)? How do I do it? Do I
repeat the filtering with another <Filter>, <PropertyIsEqualTo> or
<PropertyName> tag? I have tried all three but it doesn't seem to give me
the desired result.
2. And is it possible for me to do filtering for a range? Say, I
have a scenario where my data stores a column called minSpeed. Can I
actually filter out all the rows such that, say minSpeed < 50? If this is
possible, how can I go about doing it?
Hope someone can enlighten me on these issues. Greatly appreciate it and
thanks.
Lee Wai See
ST Electronics (Info-Software Systems) Pte Ltd
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
