Alberto,
rather than filtering the output, you could also include a predicate in the XPath to select only the CoverageId elements you want:
$ curl -s 'http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCapabilities’ | xpath -q -e '//wcs:CoverageId/text()[contains(.,"Sample")]'
nurc__Arc_Sample
nurc__Img_Sample
This example is not strictly what you want if you only want to match a substring at the end of the CoverageId text. xpath appears to support only XPath 1.0 so does not support ends-with() (from XPath 2.0), but you can make your own with this ugly but effective construct:
$ curl -s 'http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCapabilities’ | xpath -q -e '//wcs:CoverageId/text()[substring(.,string-length(.)-string-length("Sample")+1)="Sample"]'
nurc__Arc_Sample
nurc__Img_Sample
In your case this would be:
curl -s 'http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCapabilities’ | xpath -q -e '//wcs:CoverageId/text()[substring(.,string-length(.)-string-length("RGB")+1)="RGB"]'
Kind regards,
Ben.
On 16/04/16 09:01, Ben Caradoc-Davies wrote:
Alberto,
the canonical way to discover resources via OGC web services is with a
GetCapabilities request. In the case of WCS, you can discover the names
of all enabled coverages. Use curl or any other HTTP client to retrieve
the capabilities document, then parse it as XML with your language or
tool of choice to extract the coverage names.
For example, for the release configuration of GeoServer, with curl
output piped into the xpath tool (from the libxml-xpath-perl package on
Debian; what is your platform?):
curl -s
"http://localhost:8080/geoserver/wcs?service=WCS&version=2.0.1&request=GetCapabilities"
| xpath -q -e '//wcs:CoverageId/text()'
Output:
nurc__Arc_Sample
nurc__Img_Sample
nurc__mosaic
sf__sfdem
Filter this output to obtain a list of coverages whose names end in
"RGB". You can do exactly the same thing in Java, Python, or any other
general purpose language with HTTP and XML parsing support.
Kind regards,
Ben.
On 16/04/16 04:43, Alberto Callejas Delgado wrote:
Dear GeoServer users,
I am working with the rest api and I need to get a list of coverages from
GeoServer via cURL but just those which are RGB products (layer name ending
in "RGB")
I read in here that almost everything you can do in the GUI can be done
using cURL.
Please, could anybody point me to the right way to find out a solution?
Thank you very much,
Alberto
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
