Hi List,
I've been able to set up the WMS server and render a map and I now would like to have a better understanding of advanced settings. Regarding tuning of geoserver, I see two opposite objectives :
- performance (how fast my map is ready)
- output quality (how nice my map looks like)
Is there some customization options that have an important impact on performance/map quality?
Also, is there some design choice that may change performance? (maybe some output format take less time to be rendered than other or some styling options take long time to proceed)?
Gilles
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
Hi Gilles,
This page includes some recommendations about how to run GeoServer in a
production environment to get the best performance.
http://docs.codehaus.org/display/GEOSDOC/4+GeoServer+in+Production+Environment
Past that, there have been some great work that has gone on recently to
support paletted images. This allows you to reduce the resulting image
size which increases performance with a minimal sacrifice in image
quality. More detail here:
http://docs.codehaus.org/display/GEOS/Paletted+images
http://docs.codehaus.org/display/GEOSDOC/Paletted+images+tutorial
In terms of a design choice... i guess the only one is that simpler
styles will render faster then complex ones. Things like labels,
filters, etc... in styles slow down the renderer.
Andrea can give you more information about what performance improvements
are coming in the future when he gets back from vacation.
-Justin
Gilles Bassière wrote:
Hi List,
Gilles
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Gilles Bassière ha scritto:
Hi List,
By default GeoServer provides its best quality output at the cost of
bigger images. To have smaller images, and thus faster downloads
from a remote site, see:
As for design choices, there are a few things that slow down a map
generation significantly, and they are:
* labels (if you can, activate them only when the map is fairly zoomed
in, or piecewise so that the clutter is not much) and halos.
* thick lines, 1 pixel wide lines draw significantly faster
* complex geometries, if possible try to activate detailed geometry
layers only when fairly zoomed in. If you have to use the same layer
when zoomed out too, consider creating generalized versions of it
(postgis has a Douglas-Peuker based generalize routine you can use).
* attribute dependent symbolizer sizes, such as a line width
proportional to some data property, and expressed as an expression
of it (such as "size = sqrt(myattribute) / 10"), using multiple
rules such as "myattribute < 10 -> size = 3" is usually faster.
Besides that, I can try to provide more hints if you can describe
more in detail what performance issues you're facing (GeoServer version,
datastore kind, data volumes and the like).
