L.S.
WMR has recently upgraded to GeoServer 2.20.1 (weeks) and a few days ago we noticed that for a Workspace intended to only server WMS the WFS-service was also active.
Possible flaw 1: GeoServer is to lenient during an upgrade and activates e.g. WFS on workspaces/stores/layers that were defined as WMS-only.
I am not sure that this has happened during the latest upgrade, it may have happened earlier. Which actually makes it worse as we may have leaked data for much longer.
I have checked the changelogs for recent versions and have not noticed warnings about such behaviour/changes.
To remedy the leak I have started at the top level with attempts to deactivate the WFS-activation.
However setting WFS to inactive and only leaving WMS active for the Workspace did give the desired result.
Next the Stores that are involved where change to only have WMS active. Still the layers were visible for WFS.
Finally each layer that should not have a WFS has been modified and only then did the unwanted WFS-layers disappear.
I have used [Reload]-button from the Server Status pages in between changes, expecting that that would activate my edits.
Possible flaw 2: Deactivating WFS (or WMS or …) apparently does not propagate down to the lower levels. Which I expect is not how this is intended to work as it results in much more administrative work.
Interested in knowing whether other have come across this behaviour. You may have to check for this.
Interested in how I may have misinterpreted the settings, thus lumbering myself with all that extra work.
Kind regards,
Jan Tjalling van der Wal
Wageningen Marine Research (IMARES) Institute for Marine Resources & Ecosystem Studies
Ankerpark 27, 1781 AG Den Helder
Postbus 57, 1780 AB Den Helder
Tel. +31 (0)317-4 87147 #
GSM +31(0)626120915 (privé) #
Ma+Di 09:00-18:00, Wo XX, Do+Vr 09:00-18:00
Jan_Tjalling.vanderWal@anonymised.com
www.wur.nl/marine-research (NL) / www.wur.eu/marine-research (ENG)
