Hi list,
does anyone know if there was any follow-up on the issue raised here:
http://opensource-archive.org/showthread.php?p=30279
TIA.
Best regards,
Bart
Hi list,
TIA.
Best regards,
Bart
Hi Bart,
could you open a jira for this for the arcsde module? it seems I missed the
discussion on the users list and wasn't aware of this.
best regards,
Gabriel
On Monday 24 November 2008 10:29:09 bartvde@anonymised.com wrote:
Hi list,
TIA.
Best regards,
Bart-------------------------------------------------------------------------
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK & win
great prizes Grand prize is a trip for two to an Open Source event anywhere
in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Hi Gabriel,
done, see:
http://jira.codehaus.org/browse/GEOS-2453
Best regards,
Bart
Hi Bart,
the
discussion on the users list and wasn't aware of this.best regards,
Gabriel
On Monday 24 November 2008 10:29:09 bartvde@anonymised.com wrote:Hi list,
TIA.
Best regards,
win
anywhere
Hej
To my knowledge, ArcSDE is the only datastore that supports several spatial columns in the same DB table.
When defining an ArcSDE layer, the spatial column to be used must be named and is stored in the layer definition in the SDE LAYERS table.
This may be the reason, depending on how GeoTools is accessing the ArcSDE layer.
Best Regards
Andreas Oxenstierna Telefon direkt 040-16 70 17 Mobil 0734-12 80 17 andreas.oxenstierna@anonymised.com |
SWECO Position AB Hans Michelsensgatan 2 Box 286 201 22 Malmö Telefon 040-16 70 00 www.sweco.se |
-----Ursprungligt meddelande-----
Från: bartvde@anonymised.com [mailto:bartvde@anonymised.com]
Skickat: den 27 november 2008 13:31
Till: Gabriel Roldán
Kopia: geoserver-users@lists.sourceforge.net; JECHEVE@anonymised.com
Ämne: Re: [Geoserver-users] follow-up on failing BBOX filter on ArcSDE
Hi Gabriel,
done, see:
Best regards,
Bart
Hi Bart,
missed the discussion on the users list and wasn’t aware of this.best regards,
Gabriel
TIA.
Best regards,
Bart
---- This SF.Net email is sponsored by the Moblin Your Move
Developer’s challenge Build the coolest Linux based applications with
Moblin SDK & win great prizes Grand prize is a trip for two to an
Open Source event anywhere in the world
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge Build the coolest Linux based applications with Moblin SDK & win great prizes Grand prize is a trip for two to an Open Source event anywhere in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/
PostGIS supports multiple spatial columns too afaik.
I guess the thing to do is that if a property name is not specified the
bounding box should be applied to all geometry columns?
Gabriel
On Thursday 27 November 2008 10:54:36 Oxenstierna Andreas wrote:
Hej
columns in the same DB table. When defining an ArcSDE layer, the spatial
the SDE LAYERS table. This may be the reason, depending on how GeoTools is
accessing the ArcSDE layer.Best Regards
Andreas Oxenstierna
Mobil 0734-12 80 17
SWECO Position ABHans Michelsensgatan 2
Box 286
201 22 Malmö
www.sweco.se-----Ursprungligt meddelande-----
Ämne: Re: [Geoserver-users] follow-up on failing BBOX filter on ArcSDEHi Gabriel,
done, see:
Best regards,
Bart> Hi Bart,
> missed the discussion on the users list and wasn't aware of this.
> best regards,
> Gabriel
>> Hi list,
>> TIA.
>> Best regards,
>> Bart
>> Developer's challenge Build the coolest Linux based applications with
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users-------------------------------------------------------------------------
Guess not. The ArcSDE layer is defined as
,. You may check all columns and/or the SDE LAYERS table for all ArcSDE layers using the specified table and which spatial columns that are used.Best regards
Från: Gabriel Roldán [mailto:groldan@anonymised.com]
Skickat: den 27 november 2008 14:13
Till: Oxenstierna Andreas
Kopia: bartvde@anonymised.com; geoserver-users@lists.sourceforge.net; JECHEVE@anonymised.com
Ämne: Re: SV: [Geoserver-users] follow-up on failing BBOX filter on ArcSDE
I guess the thing to do is that if a property name is not specified the bounding box should be applied to all geometry columns?
Gabriel
Hej
spatial columns in the same DB table. When defining an ArcSDE layer,
definition in the SDE LAYERS table. This may be the reason, depending
on how GeoTools is accessing the ArcSDE layer.Best Regards
Andreas Oxenstierna
Mobil 0734-12 80 17
Box 286
201 22 Malmö
done, see:
Best regards,
BartHi Bart,
GabrielOn Monday 24 November 2008 10:29:09 bartvde@anonymised.com wrote:
Hi list,
TIA.
Best regards,
Bart
— This SF.Net email is sponsored by the Moblin Your Move Developer’s
Oxenstierna Andreas ha scritto:
Hej
Nope, all jdbc databases support multiple geom columns. But they don't
allow you to define the default one, if you want to use the others
in WMS you have to ask about them explicitly in the SLD or to
in the bbox filter (and thus make a POST request, you're right
it does not work for a GET one).
Andrea Aime
OpenGeo - http://opengeo.org
In my understanding a single sde layer can hold more than one spatial column.
It's just that it won't wor with, eg. ArcMap, but certainly do with the Java
and C APIs.
On Thursday 27 November 2008 11:19:59 Oxenstierna Andreas wrote:
Guess not. The ArcSDE layer is defined as <table>,<spatial column>. You may
the specified table and which spatial columns that are used. However,
ArcSDE layers should be read from the SDE LAYERS table, and there you can
find the spatial column to use (in the column SPATIAL_COLUMN), together
with other needed information like SRS.
We're using the ArcSDE Java API to hit an ArcSDE server, no direct connection
to the database, so we don't have access to the sde_layers table, but the sde
gateway does. We can just ask the SeLayer instance about its spatial columns,
if I'm not missing something.
Gabriel
Best regards
Andreas Oxenstierna
Mobil 0734-12 80 17
Box 286
201 22 Malmö
JECHEVE@anonymised.com Ämne: Re: SV: [Geoserver-users] follow-up on failing
BBOX filter on ArcSDEPostGIS supports multiple spatial columns too afaik.
bounding box should be applied to all geometry columns?Gabriel
> Hej
> Best Regards
> Andreas Oxenstierna
> Mobil 0734-12 80 17
> SWECO Position AB
> Box 286
> 201 22 Malmö
> www.sweco.se
> Hi Gabriel,
> done, see:
> Best regards,
> Bart
> > Hi Bart,
> > best regards,
> > Gabriel
> >> Hi list,
> >> TIA.
> >> Best regards,
> >> Bart
> --- This SF.Net email is sponsored by the Moblin Your Move Developer's
Andrea so what JDBC backed datastores do upon a bbox filter with no attribute
set? do they filter by all the spatial cols or just the default one? (wonder
since at least in theory the different spatial cols may be in different CRS's
meaning and extra step to transform the CRS to the column's native one before
issueing the request)
> Hej
> spatial columns in the same DB table.Nope, all jdbc databases support multiple geom columns. But they don't
it does not work for a GET one).Cheers
Gabriel Roldán ha scritto:
Andrea so what JDBC backed datastores do upon a bbox filter with no attribute set? do they filter by all the spatial cols or just the default one? (wonder since at least in theory the different spatial cols may be in different CRS's meaning and extra step to transform the CRS to the column's native one before issueing the request)
We use the default geometry only as far as I remember.
Andrea Aime
With the sde commands you define an ArcSDE layer with one specific spatial column, SRS, spatial index etc. So you can define several ArcSDE layers on the same table, with different or the same spatial columns. I do not remember how SeLayer exposes this.
Yes, ArcGIS (ArcObjects / Geodatabase) does not support this. The APIs (including ArcInfo workstation) supports it, as far I am aware of.
Andreas
Skickat: den 27 november 2008 14:35
Ämne: Re: SV: SV: [Geoserver-users] follow-up on failing BBOX filter on ArcSDE
It’s just that it won’t wor with, eg. ArcMap, but certainly do with the Java and C APIs.
used. However, ArcSDE layers should be read from the SDE LAYERS table,
and there you can find the spatial column to use (in the column
SPATIAL_COLUMN), together with other needed information like SRS.
We’re using the ArcSDE Java API to hit an ArcSDE server, no direct connection to the database, so we don’t have access to the sde_layers table, but the sde gateway does. We can just ask the SeLayer instance about its spatial columns, if I’m not missing something.Gabriel
Best regards
Andreas Oxenstierna
Mobil 0734-12 80 17
Box 286
201 22 Malmö
failing BBOX filter on ArcSDEPostGIS supports multiple spatial columns too afaik.
the bounding box should be applied to all geometry columns?Gabriel
Hej
layer definition in the SDE LAYERS table. This may be the reason,
depending on how GeoTools is accessing the ArcSDE layer.Best Regards
Andreas Oxenstierna
Mobil 0734-12 80 17
Box 286
201 22 Malmö
ArcSDEHi Gabriel,
done, see:
Best regards,
BartHi Bart,
Hi list,
TIA.
Best regards,
Bart
Hi Bart,
the issue is fixed on trunk and 1.7.x
Best regards,
Gabriel
On Thursday 27 November 2008 10:30:30 bartvde@anonymised.com wrote:
Hi Gabriel,
done, see:
Best regards,
Bart> Hi Bart,
> the
> best regards,
> Gabriel
>> Hi list,
>> TIA.
>> Best regards,
>> Bart
>> win
>> anywhere
