[Geoserver-users] format=application/pdf doesn't do alpha blending?
how awesome would it be if I could export this:
http://transit.frumin.net:8081/geoserver/wms?bbox=226355.0575892257,902465.5512216543,231305.9078647848,908256.0201132837&styles=&Format=application/openlayers&request=GetMap&layers=aw:towns,aw:tiger_road,aw:buildings,aw:bike_buffer,aw:walk_buffer,aw:rt_line,aw:rt_station,aw:aw_bike_arc,aw:bike_tracts,aw:rt_station,aw:possible_rt_origins,aw:rt_daccess_origins&width=1000&height=1000&srs=EPSG:26986
as a PDF? but when I change format=application/pdf, eg:
http://transit.frumin.net:8081/geoserver/wms?bbox=226355.0575892257,902465.5512216543,231305.9078647848,908256.0201132837&styles=&Format=application/pdf&request=GetMap&layers=aw:towns,aw:tiger_road,aw:buildings,aw:bike_buffer,aw:walk_buffer,aw:rt_line,aw:rt_station,aw:aw_bike_arc,aw:bike_tracts,aw:rt_station,aw:possible_rt_origins,aw:rt_daccess_origins&width=1000&height=1000&srs=EPSG:26986
all the semi-opaque polygons get rendered as totally opaque. bummer!
any thoughts?
thanks,
mike
PS I know I still owe you guys a JIRA entry from stuff from yesterday
View this message in context: http://www.nabble.com/format%3Dapplication-pdf-doesn't-do-alpha-blending--tf4722474.html#a13501698
I have done some tests and I think it's a bug in iText that has been fixed recently. I just tried to use iText 2.0.6, found a workaround
for raster rendering not working and... here is the result of rendering
the spearfish group layer as a pdf:
http://geo.openplans.org/aaime/spearfish.pdf
Here are the two issues that need to be fixed:
http://jira.codehaus.org/browse/GEOS-1460
http://jira.codehaus.org/browse/GEOS-1461
If you can't wait just take your GeoServer, remove the iText
1.3 jar and replace it with an iText 2.0.6 jar you can download
from the iText site. This will fix the rendering transparency issue
(but not the black rasters one)
