[Geoserver-users] format_options and POST requests
Is the format_options parameter supported in POST requests (expecially wfs requests)? If yes, how can it be used in a GetFeature request?
Mauro Bartolomeoli
It should be yes, if not it is a bug. Basically just do the POST as you normally would, just specifying the format_options parameter. Example with curl:
curl -XPOST -d '...' http://localhost:8080/geoserver/wfs?format_options=
-Justin
Mauro Bartolomeoli
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I did some testing (1.7.5) and it seems to be ignored. It's correctly read when I specify all parameters in the url (effectively doing a GET request), but when I'm sending a post (through the "Sample Requests" geoserver page), no way. I presume that on post all parameters are taken from the request xml and I can't see any corresponding attribute in the XML Schema.
Mauro Bartolomeoli
-Justin
Mauro Bartolomeoli
