Hello group!
I created a GetFeatureInfo-template for a 2-band raster layer. This works fine and i can get the band values and convert them into numbers and write the into a table:
${cell.attributes["dgm"].value?number}
${cell.attributes["wd"].value?number}
Now i want to add these two values, this is the part that does not work.
this creates a text output like n1 + n2 (n1,2 are the correct numbers)
${cell.attributes[“dgm”].value?number} + ${cell.attributes[“wd”].value?number}
This does not work:
${${cell.attributes[“dgm”].value?number} + ${cell.attributes[“wd”].value?number}}
Writing a function sum does also not work with the expressions only with fixed numbers like 10or 20:
<#function sum a b>
<#return a + b>
</#function>
${sum(${cell.attributes["dgm"].value?number},${cell.attributes["wd"].value?number})}
Changing the localization does not have an effect:
<#setting locale=“de_DE”>
Can someone give me a hint how to add two expressions with freemarker?
Thank you in advance
Uwe
jive
October 31, 2017, 10:34pm
2
Did you get any exceptions in the log to provide a clue? Looking in the manual it appears the “+” approach is correct: http://freemarker.org/docs/dgui_template_exp.html#dgui_template_exp_arit
Can you report back when you get a working example so we can add it to our docs please?
On 30 October 2017 at 08:22, Uwe Seher <uwe.seher@anonymised.com > wrote:
Hello group!
This does not work:
<#function sum a b>
<#return a + b>
</#function>
Uwe
engaging tech sites, Slashdot.org ! http://sdm.link/slashdot
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Jody Garnett
