[Geoserver-users] freemarker
I'm trying to use ftl files in order to customize a getFeatureInfo output, but since it was very easy to do it for KML styling, I get a problem when I try to acces simply the value of an attribute with a formula like :
            ${attributename.value}
that I used with KML. It seems that in a getFeatureInfo customization, we can't access the specific value of an attribute in that way ... am I wrong ?
Regards
Laurent
Hi Laurent,
I wouldn't also mind on getting some further information on freemarker/geoserver. Actually, I am doing quite a same in these days than you. With the help of the getFeaureInfo I am embedding some html in the current page. I did it as follows:
<#list features as feature>
  <#list feature.attributes as attribute>
    <#if attribute.name='yourattributename'>
do something with ${attribute.value}
</#if>
  </#list>
</#list>
Seem to be working, although I don't quite get it. Can't it be done easier?
mika
laurent pierrre kirjoitti:
Regards
Laurent
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
Hi Mika,
Yes that's a good idea although I was trying to use the same way as for KML.
Laurent
Le 15 avr. 08 à 22:04, Lehtonen, Mika a écrit :
Hi Laurent,
</#if>
</#list>
</#list>
mika
Regards
Laurent
Hi Laurent,
Unfortunately it does not work quite the same as with KML. The reason is because with KML, the input to the template is a single feature, as with GetFeautreInfo, its a number of features. So first you must iterate through the features, and then get attributes. SOmethign like this:
  'ATTRIBUTENAME' = ${feature.ATTRIBUTENAME.value}
</#list>
Hope that helps. There is more info available here:
http://geoserver.org/display/GEOSDOC/GetFeatureInfo+templates
-Justin
laurent pierrre wrote:
Regards
Laurent
!DSPAM:4007,4805071e186641030819293!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
2008/4/16 Justin Deoliveira <jdeolive@anonymised.com>:
Hi Laurent,
‘ATTRIBUTENAME’ = ${feature.ATTRIBUTENAME.value}
</#list>
Sure it helps :slight_smile: Thanks
Laurent
