Hi list,
Due to my problems with PDF support in 1.3.2 I am doing a fresh
reinstalled on my server. In my machine is working fine so it must had
to do something with tomcat getting confused with previous geoservers
or something.
I restarted, deleted temp files but no luck...
Finally I had to remove my version of geoserver, restart tomcat and
install a fresh new geoserver... so if someone is getting into
troubles on something similar be careful with tomcat...
Now I can use PDF and it works great.
With KML it is working when using KML but when I use KMZ Google Earth
complains that the XML is not well-formed, there is some unmatch tags
(what is true). I am investigating, but I think it has to do with
layers that do not get data after the SLD is processed.
Thanks!
Javier.
I will look into the unclosed-tag issue.
Brent Owens
(The Open Planning Project)
Javier de la Torre wrote:
Hi list,
or something.
Thanks!
Javier.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
I believe at least part of it is mixed KMScore responses. Javier is getting 6 layers, and 3 are KML and 3 are ground overlays. If he does just KML it works better because all are KML. One problem is that the image names are wrong, layer4 (correct since there are 3 KML layers already) refers layer4.png, but layer1.png is the one produced. That may be an additional error to the unformed KML. Brent, I'll forward along the requests Javier got to me.
Chris
Brent Owens
Hi list,
or something.
Thanks!
Javier.
!DSPAM:1003,44b51789324412051017194!
Chris Holmes
http://topp.openplans.org
ok that makes sense. I will fix the problem when justin is finished merging.
Brent Owens
Chris
Brent Owens
Hi list,
or something.
Thanks!
Javier.
Ok I think I fixed the problem. Javier, I will send you a patch tomorrow to try it out.
Brent Owens
Chris
Brent Owens
Hi list,
or something.
Thanks!
Javier.
