[Geoserver-users] FW: Dutch projection problem
  _____
Van: Wim Blanken [mailto:w.blanken@anonymised.com]
Verzonden: maandag 12 februari 2007 17:58
Aan: 'geoserver-users@lists.sourceforge.net'
Onderwerp: Dutch projection problem
Hello list,
I am using Geoserver 1.4.0 to serve KML. There is however a bug in the
reprojection from epsg:28992 to WGS84.
The map is about 30-50 meters wrong mostly to the north.
In Mapserver I could simply repair the parameters in the proj. tekstfile
(sterea instead of stere). In Geoserver however I do not see this parameter.
It has something to do with the Oublique_stereographic projection. It should
be Double_stereographic I believe but that option is not valid in the
epgs.properties file I believe.
Anybody any ideas how to fix this in Geoserver?
With regards,
Wim Blanken
The Netherlands
