[Geoserver-users] FW: Extension points
Thanks Dave.
So I would just have to implement the REST support Interfaces? It looks
like they are based off of RESTLet.
Is this the best way to implement extensions to the three services, Web
Map Service, Web Coverage Service, and Web Feature Service to
communicate with a custom service?
Or, should I be doing something else? Is there any document explaining
what the cgi parameters for a WMS, WFS, or WCS would be?
Ronak Patel
-----Original Message-----
From: David Winslow [mailto:dwinslow@anonymised.com]
Sent: Thursday, February 05, 2009 1:28 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] FW: Extension points
You could implement an OWS-style service using that extension endpoint
(even the core services that GeoServer provides are simply leveraging
that extension point). Another alternative, if you are more interested
in hierarchical-looking URLs, is a plugin based on the REST support
module, scheduled to be a supported module for the next release.
A tutorial about OWS-like extensions:
http://geoserver.org/display/GEOSDOC/3+A+Simple+PlugIn
The current documentation for the REST support module:
http://geoserver.org/display/GEOS/GSIP+32+-+REST+support+module
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Thu, 2009-02-05 at 12:13 -0800, Patel, Ronak Avinash (US SSA) wrote:
Hello,
I'm developing a custom backend SOAP/REST Web Service that I need
Geoserver to interface to. I was thinking of implementing the
GetMapProducer extension point for the WMS capability.
I was wondering if there are other extension points available for the
WFS and WCS capabilities of Geoserver. If there are, could someone
please point me to them?
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Create and Deploy Rich Internet Apps outside the browser with
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and
code to
build responsive, highly engaging applications that combine the power
of local
resources and data with the reach of the web. Download the Adobe AIR
SDK and
Ajax docs to start building applications
today-http://p.sf.net/sfu/adobe-com
_______________________________________________ Geoserver-users
mailing list Geoserver-users@lists.sourceforge.net
If you want to extend the existing OGC services then the REST extension is probably not the way to go. As you noted, with WMS you can extend the available output formats in a GetMap request. There are additional extension points for WFS GetFeature, and WCS GetCoverage.
Extending the services further would probably involve implementing your own OWS service (as david pointed out), or possibly overriding the existing ones. But in this case it would really depend on how you want to extend. Do you have some particular cases in mind?
Thanks Dave.
Ronak Patel
From: David Winslow [mailto:dwinslow@anonymised.com] Sent: Thursday, February 05, 2009 1:28 PM
Hope this helps.
David Winslow
Hello,
Ronak Patel
BAE Systems NS
San Diego, CA
Adobe(R)AIR(TM)
code to
of local
SDK and
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Justin Deoliveira
