Hi Chris,
NOAA has a WMS for the vector ENC.
http://ocs-spatial.ncd.noaa.gov/wmsconnector/com.esri.wms.Esrimap/encdirect?
Service=WMS&Version=1.1.1&Request=GetCapabilities
You can probably use uDig to look at the ENC with other backgrounds with
other overlays. I haven't run across a NOAA raster service for ENC but you
might be able to find one.
randy
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Justin
Deoliveira
Sent: Monday, February 25, 2008 6:13 PM
To: Chris H
Subject: Re: [Geoserver-users] GeoServer and NOAA Raster & Vector Charts
Hi Chris,
Interesting problem!! Unfortunately BSB is a format that
geotools/geoserver does not handle. However doing some searching it
seems that gdal does:
http://home.gdal.org/projects/bsb/index.html
So you have two choices. You can:
(1) Use MapServer
(2) Convert the files to a format that GeoServer can understand like
GeoTIFF. (example on the above page).
Hope that helps. Feel free to keep the questions coming.
-Justin
Chris H wrote:
Greets:
Brand new to the list as I spend the weekend researching map servers. Here
is
the scenario that I am contemplating. A group of us are going sailing down
the eastern seaboard from Canada to the Caribbean and the electronic
navigation system and charts have been acquired. All standard stuff
nothing
fancy.
The problem is that in order to view the charts for planning or discussion
you
need to fire up the electronic charting system which in general do not
provide good high level overviews. They are good for course planning,
tracking and route planning gps integration etc.To overcome this problem as there are several of us onboard is to prepare
a
map server that displays the NOAA BSB Raster and Vector charts as an
overlay
at the appropriate zoom level of the eastern seaboard and caribbean
regions.
This allows for both a high level view as well as detailed view in a
standalone application that can be used in addition too the standard
navigation packages which use the same charts. As everyone will have
putters
on board and I run linux its simple to create an onboard wireless network.
So before I go down this route and spend copious amounts of time learning
all
the details of charts, map servers, java, tomcat, postgis/postgresql etc I
was wondering: first is this even feasible as I see no google data
on "geosever and NOAA BSB raster or vector charts" even though both should
be
supported. Secondly is there perhaps a simpler solution to creating a
functional mapserver used primarily for reviewing and displaying data in
this
standard format and in a multi user environment.
Thanks for any information or insights that you may wish to share.
Best regards
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
