Patel, Ronak Avinash (US SSA) wrote:
I had a question regarding the Geoserver WMS and Google Earth/NASA World Wind.
I notice that most of the precanned data inside of Geoserver is not downloaded by WorldWind nor Google Earth. They both throw errors at me. Have you seen that before?
Hmmm... we usually manually test most of the layers from the vanilla geoserver distro and make sure it works ok with google earth. This issue may be relevant:
http://jira.codehaus.org/browse/GEOS-2942
What version of gs are you using?
I also experience some images staging correctly inside Geoserver but I get weird HTTP 404 and other “Path Not Found” errors from Geoserver when pulling out those images that staged correctly. *I am using the REST Interface to stage coverages to Geoserver.*
Are you getting the 404 in Google Earth, accessing KML? If so are you using the standard KML reflector URL to access?
I see the new layer created inside of Geoserver and I am able to pull the correct coverage of the raster inside of that layer.
Do you have any ideas as to why this sort of problem occurs?
Tough to say. The easiest way to diagnose the problems would be if you could make a sample of your data available, in which are you able to reproduce the problem with.
Thanks!
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Register Now & Save for Velocity, the Web Performance & Operations Conference from O'Reilly Media. Velocity features a full day of expert-led, hands-on workshops and two days of sessions from industry leaders in dedicated Performance & Operations tracks. Use code vel09scf and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
