Justin,
I found the problem to be on the client side:
1. Google Earth never invokes the WCS and learns the coverage of the
layer...so it never flies there...it wants KML and KML only.
2. WorldWind doesn't like the colon between the namespace and layer
names and barfs at it while trying to generate cache directories and
files. This has already been documented.
I am trying to use the WorldWind WMS Browser to add layers from
Geoserver.
Have you heard of any thing like this being reported in the past? I
found a few message boards online (Worldwind boards) that report this.
Thanks!
Ronak
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Monday, May 04, 2009 10:26 AM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] FW: Geoserver WMS and Google Earth
Patel, Ronak Avinash (US SSA) wrote:
I had a question regarding the Geoserver WMS and Google Earth/NASA
World
Wind.
I notice that most of the precanned data inside of Geoserver is not
downloaded by WorldWind nor Google Earth. They both throw errors at
me.
Have you seen that before?
Hmmm... we usually manually test most of the layers from the vanilla
geoserver distro and make sure it works ok with google earth. This issue
may be relevant:
http://jira.codehaus.org/browse/GEOS-2942
What version of gs are you using?
I also experience some images staging correctly inside Geoserver but I
get weird HTTP 404 and other "Path Not Found" errors from Geoserver
when
pulling out those images that staged correctly. *I am using the REST
Interface to stage coverages to Geoserver.*
Are you getting the 404 in Google Earth, accessing KML? If so are you
using the standard KML reflector URL to access?
I see the new layer created inside of Geoserver and I am able to pull
the correct coverage of the raster inside of that layer.Do you have any ideas as to why this sort of problem occurs?
Tough to say. The easiest way to diagnose the problems would be if you
could make a sample of your data available, in which are you able to
reproduce the problem with.
Thanks!
Ronak Patel
Senior Software Engineer
BAE Systems NS
San Diego, CA
Register Now & Save for Velocity, the Web Performance & Operations
Conference from O'Reilly Media. Velocity features a full day of
expert-led, hands-on workshops and two days of sessions from industry
leaders in dedicated Performance & Operations tracks. Use code
vel09scf
and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
