[Geoserver-users] FW: gs:Contour error
Sent: Friday, October 11, 2013 3:24 PM
To: ‘Alessio Fabiani’
Subject: RE: [Geoserver-users] gs:Contour error
Hy Alesso!
I’ve downloaded the latest version, with the appropriate WPS, and the problem is the same.
Build Information
  • Version 2.4.0
  • Git Revision 6ca656addbb3fa3b47cc409b6d035f90e04c11f9
  • Build Date 18-Sep-2013 20:42
  • GeoTools Version 10-RC2 (rev 5481f4202bd33093b4f41a8ae480ec23a9997e0f)
I’ve try to use the WPS request builder. I selected the gs:Contour process and the sf:sfdem raster layer ….
From: alessio.fabiani@anonymised.com [mailto:alessio.fabiani@anonymised.com] On Behalf Of Alessio Fabiani
Sent: Tuesday, October 08, 2013 4:34 PM
To: Holb Endre
Cc: geoserver-users
Subject: Re: [Geoserver-users] gs:Contour error
As far as I remember there should be an issue in that GeoServer version with the Contour rendering transformation which is fixed on 2.4.x version.
I’m not completely sure, have to verify, but in the meantime you may want to test the latest GeoServer version to see if it’s working fine.
-A.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Tue, Oct 8, 2013 at 4:02 PM, Holb Endre <holb.endre@anonymised.com> wrote:
Hy!
I’m trying to apply gs:Contour WPS process with the WPS request builder. My Geoserver version 2.3.1. I’ve downloaded the approriate WPS extension.
I use the original sf:sfdem raster file. This raster file is ok with the original dem sld style. But when I execute the process the result is an error :
filled input parameters: data, interval
Process failed during execution
java.lang.IllegalArgumentException: The input argument(s) may not be null.
Can you help me?
Thenks
Endre Holb a developer
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
On Mon, Oct 14, 2013 at 2:14 PM, Holb Endre <holb.endre@anonymised.com> wrote:
Version 2.4.0 ****
Git Revision 6ca656addbb3fa3b47cc409b6d035f90e04c11f9 ****
Build Date 18-Sep-2013 20:42 ****
The GeoTools version for 2.4.0 should be 10.0, not 10.0-RC2.
Wondering if there was a problem with the release, or if you mixed into the
normale 2.4.0 release some old plugin?
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
