Hi Andrea
I tried attaching the server.log but the email group rejected it. Trying again.
Our GeoServer version is 2.7.2. I’m storing the granules in a database. I viewed the database table called missionid2_coaid3_aoiid1_ruleid4_thresholdid23 and it looks like it was created and everything was stored correctly. What’s interesting is I can manually go into GeoServer and create the layer that failed.
Login to geoserver
Select Layers
Click Add New Resource
Select the workspace and store
I can see the Layer Name that failed. (screenshot attached)
Hit publish
Choose the correct styling in the Publishing tab
Enable Time dimension in the Dimensions tab
Select Save and the layer is now created. (see attached screenshot)
server.log (41.4 KB)
On Sat, Nov 14, 2015 at 1:20 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@…1196…> wrote:
Hi
I’m using the image mosaic plugin and I get the following error from the GTDataStoreGranuleCatalog class intermittently.
BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
Do you have the full stack trace?
What version of GeoServer is giving you these errors?
If I try to recreate the image mosaic overlay it’ll work fine. Do you have any idea why this would be happening?
My indexer.properties file contains the following
TimeAttribute = validtime
ElevationAttribute = elevation
Envelope2D = 119.00390624999999,0.3515625,129.00390625,10.3515625
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date,elevation:Double
PropertyCollectors = TimestampFileNameExtractorSPItimeregex,DoubleFileNameExtractorSPIelevationregex
Where are you storing the collected granules? If it’s a database, can you share your datastore.properties?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
