I'm not sure I understand why you need to have many OWS services
running. Wouldn't it be easier to add a proxy aggregator that distributes
from a single WMS into multiple client configurations?
rkgeorge
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Rahkonen
Jukka
Sent: Thursday, May 10, 2007 12:29 AM
To: Jase; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Two WMS on one geoserver
Are you sure you can't differentiate your WMS service enough by looking it
through different SLD's? But if you do need hundreds of separate WMS
services then perhaps you could have a look on the UMN MapServer side, I
believe it would be much easier to do there.
-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: Jase
Lähetetty: to 10.5.2007 2:39
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Two WMS on one geoserver
We have a need for many more than just a few WMS on one GeoServer,
looking for something a bit equivilent to ArcIMS Map Services in which we
can set up as many as needed for different target data and configurations.
Multiple deployments would be ok if we only had need for a few, but it would
quickly become a management nightmare with dozens if not hundreds required.
We are trying to find options to work around the problem because apart from
a SOAP/WSDL interface for WFS Geoserver provides everything we need and
more.
aaime wrote:
geo.serv@anonymised.com ha scritto:
No, we do not provide support for this kind of configuration.
Yet, if they do serve different kind of data, you can deploy
geoserver in your web container multiple times and effectively
have multiple separated geoservers working side by side.Anyways, I'm curious. Can you describe your use case a little more?
That is, why do you need different WMS? Security issues? Just wondering.Hope this helps.
Andrea Aim
View this message in context:
http://www.nabble.com/Two-WMS-on-one-geoserver-tf2838731.html#a10404818
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
