[Geoserver-users] Gdal crash geoserver/tomcat7 on ubuntu server
I am having some issues with a geoserver gdal installation on a ubuntu server
12.04, when i try to save a new ECW store tomcat7 crashes when i restart
tomcat the store in there but if i load a layer it crashes again, to install
gdal plugin i followed the official geoserver guide for my version wich is
2.4.1 (http://docs.geoserver.org/stable/en/user/data/raster/gdal.html)
the server config is:
ubuntu server 12.04 64bit
tomcat7
oracle java 8
geoserver 2.4.1
in the geoserver and catalina logs there is no info about the crash cause,
previously i had openjdk6 but the result was the same.
it may depend on library? permissions? I tried almonst everything...
Anyone has suggestions?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gdal-crash-geoserver-tomcat7-on-ubuntu-server-tp5207154.html
GeoServer 2.4.1 is an old version so I’m not sure to remember which set of libraries is involving.
Anyway, you could double check if you are using the proper version of each dependency, such as:
  • imageio-ext artifacts
  • gdal dependencies
Could you check if all the imageio-ext jars are of the same version? (If my memory serves me right, the imageio-ext version for GS 2.4.1 is 1.1.7).
Could you also check if the standalone java based “gdalinfo” tool (you may find it in the downloaded tar.gz archive… on javainfo/gdalinfo.sh) properly works on your sample dataset?
Wondering if you are fighting against that issue:
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.6/native/gdal/linux/notes_on_ECW_and_JP2ECW.txt
Which have been fixed in 1.1.7.
Did you see any hs_err_pid.log around?
Hope this helps a bit to proceed with your investigations.
Daniele
tomcat7
oracle java 8
geoserver 2.4.1
it may depend on library? permissions? I tried almonst everything…
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
I have the same problemi with GDAL libraries installed on CentOS 7 (TOMCAT
8).
when i try to set up a store, the geoserver (version 2.10.1) crashes and
restart.
the server reports an error in the java-1.8.0-openjdk
is there anyone who can help me to understand the problem?
Thank you
Michele
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gdal-crash-geoserver-tomcat7-on-ubuntu-server-tp5207154p5306021.html
