[Geoserver-users] GDAL extension installation issue
Hello everyone,
I'm quite new to geoserver and have run into trouble installing GDAL
Image Formats as described here:
http://docs.geoserver.org/2.2.5/user/data/raster/gdal.html
I don't get any error messages in the geoserver log file (see below),
but the additional file formats don't show up in the GUI.
I'm running Geoserver 2.2.5 on a Tomcat7 and using JAVA 1.6.0_27
(OpenJDK 64-Bit Server VM).
I'm quite sure that I did everything correctly as described in the
documentation:
-copied the jar-files for the GDAL extension to
/var/lib/tomcat/webapps/geoserver/WEB-INF/lib, changed owner to
tomcat7 and permissions to 644 so tomcat can access it
-copied the files for the CRS definitions
(http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.6/native/gdal/gdal-data.zip)
to /usr/share/gdal/1.9.2/ and defined GDAL_DATA environment variable:
export GDAL_DATA=/usr/share/gdal/1.9.2/
-copied the GDAL native libraries
(gdal192-Ubuntu12-gcc4.6.3-x86_64.tar.gz) to
/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64, set the
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64
gdalinfo --formats
Supported Formats:
  VRT (rw+v): Virtual Raster
  GTiff (rw+v): GeoTIFF
  NITF (rw+v): National Imagery Transmission Format
  RPFTOC (ro): Raster Product Format TOC format
  HFA (rw+v): Erdas Imagine Images (.img)
  SAR_CEOS (ro): CEOS SAR Image
  CEOS (ro): CEOS Image
I need the HFA format which is present.. so I assume the GDAL library
is working.
One thing I don't really understand is:
gdalinfo --version
GDAL 1.7.3, released 2010/11/10
Obviously there is also an older version of GDAL installed. Is that a
problem since I installed the newer files in the JAVA path?
Looking forward for hints on what could have gone wrong!
Kristina
Here is the log file:
2013-03-11 11:35:43,274 INFO [georss.GeoRSSPoller] - destroy() invoked
2013-03-11 11:35:43,276 INFO [geowebcache.GeoWebCacheDispatcher] -
GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2013-03-11 11:35:43,279 INFO [diskquota.DiskQuotaMonitor] - Disk quota
monitor shutting down...
2013-03-11 11:35:43,280 INFO [diskquota.DiskQuotaMonitor] - Shutting
down quota usage monitor...
2013-03-11 11:35:43,280 INFO [diskquota.QuotaUpdatesMonitor] -
Shutting down quota usage monitor...
2013-03-11 11:35:43,280 INFO [diskquota.QueuedQuotaUpdatesConsumer] -
Shutting down quota update background task due to InterruptedException
down quota statistics gathering monitor...
2013-03-11 11:35:43,329 INFO [diskquota.QueuedUsageStatsConsumer] -
Shutting down quota update background task due to interrupted
exception
2013-03-11 11:35:43,330 INFO [storage.BDBQuotaStore] - Requesting to
close quota store...
2013-03-11 11:35:43,373 INFO [storage.BDBQuotaStore] - Quota store closed.
2013-03-11 11:35:43,373 INFO [seed.SeederThreadPoolExecutor] -
Initiating shut down for running and pending seed tasks...
2013-03-11 11:35:43,374 INFO [seed.SeederThreadPoolExecutor] - Seeder
thread pool executor shut down complete.
2013-03-11 11:35:43,375 INFO [storage.StorageBroker] - Destroying StorageBroker
2013-03-11 11:35:45,026 WARN [support.DisposableBeanAdapter] -
Invocation of destroy method failed on bean with name
'geoServerLoader':
org.springframework.beans.factory.BeanCreationNotAllowedException:
Error creating bean with name 'GWCLifeCycleHandler': Singleton bean
creation not allowed while the singletons of this factory are in
destruction (Do not request a bean from a BeanFactory in a destroy
method implementation!)
2013-03-11 11:36:11,225 WARN [config.CustomEditorConfigurer] - Passing
PropertyEditor instances into CustomEditorConfigurer is deprecated:
use PropertyEditorRegistrars or PropertyEditor class names instead.
Offending key [org.geotools.util.Version; offending editor instance:
org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
2013-03-11 11:36:14,846 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /var/lib/tomcat7/webapps/geoserver/data
2013-03-11 11:36:15,722 INFO [org.geoserver] - Loaded style 'tiger_roads'
2013-03-11 11:36:15,729 INFO [org.geoserver] - Loaded style 'capitals'
2013-03-11 11:36:15,731 INFO [org.geoserver] - Loaded style 'population'
2013-03-11 11:36:15,734 INFO [org.geoserver] - Loaded style 'green'
2013-03-11 11:36:15,735 INFO [org.geoserver] - Loaded style 'poi'
2013-03-11 11:36:15,737 INFO [org.geoserver] - Loaded style 'burg'
2013-03-11 11:36:16,555 INFO [org.geoserver] - Loaded style 'raster'
2013-03-11 11:36:16,559 INFO [org.geoserver] - Loaded style 'pophatch'
2013-03-11 11:36:16,562 INFO [org.geoserver] - Loaded style 'simple_roads'
2013-03-11 11:36:16,563 INFO [org.geoserver] - Loaded style 'simple_streams'
2013-03-11 11:36:16,565 INFO [org.geoserver] - Loaded style 'line'
2013-03-11 11:36:16,567 INFO [org.geoserver] - Loaded style 'grass'
2013-03-11 11:36:16,569 INFO [org.geoserver] - Loaded style 'point'
2013-03-11 11:36:16,571 INFO [org.geoserver] - Loaded style 'giant_polygon'
2013-03-11 11:36:16,574 INFO [org.geoserver] - Loaded style 'polygon'
2013-03-11 11:36:16,576 INFO [org.geoserver] - Loaded style 'restricted'
2013-03-11 11:36:16,579 INFO [org.geoserver] - Loaded style 'poly_landmarks'
2013-03-11 11:36:16,582 INFO [org.geoserver] - Loaded style 'rain'
2013-03-11 11:36:16,585 INFO [org.geoserver] - Loaded style 'cite_lakes'
2013-03-11 11:36:16,587 INFO [org.geoserver] - Loaded style 'dem'
2013-03-11 11:36:16,590 INFO [org.geoserver] - Loaded default workspace Doliche
2013-03-11 11:36:16,604 INFO [org.geoserver] - Loaded workspace 'sde'
2013-03-11 11:36:16,619 INFO [org.geoserver] - Loaded workspace 'cite'
2013-03-11 11:36:16,628 INFO [org.geoserver] - Loaded workspace
'it.geosolutions'
2013-03-11 11:36:16,631 INFO [org.geoserver] - Loaded workspace 'tiger'
2013-03-11 11:36:16,636 INFO [org.geoserver] - Loaded workspace 'nurc'
2013-03-11 11:36:16,642 INFO [org.geoserver] - Loaded workspace 'topp'
2013-03-11 11:36:16,647 INFO [org.geoserver] - Loaded workspace 'Doliche'
2013-03-11 11:36:16,655 INFO [org.geoserver] - Loaded workspace 'sf'
2013-03-11 11:36:19,497 INFO [org.geoserver] - Loaded store 'nyc', enabled
2013-03-11 11:36:19,512 INFO [org.geoserver] - Loaded data store 'nyc'
2013-03-11 11:36:25,584 WARN [referencing.factory] - Axis elements
found in a wkt definition, the force longitude first axis order hint
might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich",
0.0], UNIT["degree", 0.017453292519943295]],
PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin",
0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor",
1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing",
0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH],
AUTHORITY["EPSG","54004"]]
2013-03-11 11:36:25,989 INFO [org.geoserver] - Loaded feature type
'tiger_roads', enabled
2013-03-11 11:36:26,011 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-03-11 11:36:26,046 INFO [org.geoserver] - Loaded layer 'tiger_roads'
2013-03-11 11:36:26,056 INFO [org.geoserver] - Loaded feature type
'poi', enabled
2013-03-11 11:36:26,057 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-03-11 11:36:26,064 INFO [org.geoserver] - Loaded layer 'poi'
2013-03-11 11:36:26,075 INFO [org.geoserver] - Loaded feature type
'poly_landmarks', enabled
2013-03-11 11:36:26,076 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-03-11 11:36:26,079 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
2013-03-11 11:36:26,088 INFO [org.geoserver] - Loaded feature type
'giant_polygon', enabled
2013-03-11 11:36:26,088 INFO [org.geoserver] - Loaded feature type 'nyc'
2013-03-11 11:36:26,092 INFO [org.geoserver] - Loaded layer 'giant_polygon'
2013-03-11 11:36:27,111 INFO [org.geoserver] - Loaded store 'mosaic', enabled
2013-03-11 11:36:27,117 INFO [org.geoserver] - Loaded coverage store 'mosaic'
2013-03-11 11:36:27,217 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
2013-03-11 11:36:27,248 INFO [org.geoserver] - Loaded coverage 'mosaic'
2013-03-11 11:36:29,865 WARN [imagemosaic.catalog] -
BBOXFilterExtractor::extractBasicProperties(): passed typename is
null, using: mosaic
2013-03-11 11:36:30,710 WARN [imagemosaic.Utils] - Unable to find
sample image for path
/var/lib/tomcat7/webapps/geoserver/data/coverages/mosaic_sample/sample_image
2013-03-11 11:36:30,710 WARN [gce.imagemosaic] - Unable to find sample
image for path file:/var/lib/tomcat7/webapps/geoserver/data/coverages/mosaic_sample/mosaic.shp
2013-03-11 11:36:30,711 INFO [org.geoserver] - Loaded layer 'mosaic'
2013-03-11 11:36:30,742 INFO [org.geoserver] - Loaded store
'img_sample2', disabled
2013-03-11 11:36:30,742 INFO [org.geoserver] - Loaded coverage store
'img_sample2'
2013-03-11 11:36:32,823 INFO [org.geoserver] - Loaded coverage
'Pk50095', disabled
2013-03-11 11:36:32,824 INFO [org.geoserver] - Loaded coverage 'img_sample2'
2013-03-11 11:36:32,827 INFO [org.geoserver] - Loaded layer 'Pk50095'
2013-03-11 11:36:32,843 INFO [org.geoserver] - Loaded store
'worldImageSample', enabled
2013-03-11 11:36:32,843 INFO [org.geoserver] - Loaded coverage store
'worldImageSample'
2013-03-11 11:36:32,849 INFO [org.geoserver] - Loaded coverage
'Img_Sample', enabled
2013-03-11 11:36:32,850 INFO [org.geoserver] - Loaded coverage
'worldImageSample'
2013-03-11 11:36:32,996 INFO [org.geoserver] - Loaded layer 'Img_Sample'
2013-03-11 11:36:33,609 INFO [org.geoserver] - Loaded store
'arcGridSample', enabled
2013-03-11 11:36:33,611 INFO [org.geoserver] - Loaded coverage store
'arcGridSample'
2013-03-11 11:36:33,630 INFO [org.geoserver] - Loaded coverage
'Arc_Sample', enabled
2013-03-11 11:36:33,631 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
2013-03-11 11:36:33,694 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
2013-03-11 11:36:33,728 INFO [org.geoserver] - Loaded store
'taz_shapes', enabled
2013-03-11 11:36:33,728 INFO [org.geoserver] - Loaded data store 'taz_shapes'
2013-03-11 11:36:33,775 INFO [org.geoserver] - Loaded feature type
'tasmania_state_boundaries', enabled
2013-03-11 11:36:33,776 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-03-11 11:36:33,788 INFO [org.geoserver] - Loaded layer
2013-03-11 11:36:33,792 INFO [org.geoserver] - Loaded feature type
'tasmania_roads', enabled
2013-03-11 11:36:33,792 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-03-11 11:36:33,800 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
2013-03-11 11:36:33,815 INFO [org.geoserver] - Loaded feature type
'tasmania_water_bodies', enabled
2013-03-11 11:36:33,815 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-03-11 11:36:33,818 INFO [org.geoserver] - Loaded layer
2013-03-11 11:36:33,822 INFO [org.geoserver] - Loaded feature type
'tasmania_cities', enabled
2013-03-11 11:36:33,831 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2013-03-11 11:36:33,839 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
2013-03-11 11:36:33,860 INFO [org.geoserver] - Loaded store
'states_shapefile', enabled
2013-03-11 11:36:33,861 INFO [org.geoserver] - Loaded data store
'states_shapefile'
2013-03-11 11:36:34,759 INFO [org.geoserver] - Loaded feature type
'states', enabled
2013-03-11 11:36:34,760 INFO [org.geoserver] - Loaded feature type
'states_shapefile'
2013-03-11 11:36:34,775 INFO [org.geoserver] - Loaded layer 'states'
2013-03-11 11:36:34,811 INFO [org.geoserver] - Loaded store 'sfdem', enabled
2013-03-11 11:36:34,812 INFO [org.geoserver] - Loaded coverage store 'sfdem'
2013-03-11 11:36:34,865 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
2013-03-11 11:36:35,042 INFO [org.geoserver] - Loaded layer 'sfdem'
2013-03-11 11:36:35,049 INFO [org.geoserver] - Loaded store 'sf', enabled
2013-03-11 11:36:35,049 INFO [org.geoserver] - Loaded data store 'sf'
2013-03-11 11:36:35,075 INFO [org.geoserver] - Loaded feature type
'roads', enabled
2013-03-11 11:36:35,076 INFO [org.geoserver] - Loaded feature type 'sf'
2013-03-11 11:36:35,079 INFO [org.geoserver] - Loaded layer 'roads'
2013-03-11 11:36:35,091 INFO [org.geoserver] - Loaded feature type
'streams', enabled
2013-03-11 11:36:35,092 INFO [org.geoserver] - Loaded feature type 'sf'
2013-03-11 11:36:35,097 INFO [org.geoserver] - Loaded layer 'streams'
2013-03-11 11:36:35,111 INFO [org.geoserver] - Loaded feature type
'bugsites', enabled
2013-03-11 11:36:35,111 INFO [org.geoserver] - Loaded feature type 'sf'
2013-03-11 11:36:35,116 INFO [org.geoserver] - Loaded layer 'bugsites'
2013-03-11 11:36:35,122 INFO [org.geoserver] - Loaded feature type
'restricted', enabled
2013-03-11 11:36:35,122 INFO [org.geoserver] - Loaded feature type 'sf'
2013-03-11 11:36:35,131 INFO [org.geoserver] - Loaded layer 'restricted'
2013-03-11 11:36:35,138 INFO [org.geoserver] - Loaded feature type
'archsites', enabled
2013-03-11 11:36:35,138 INFO [org.geoserver] - Loaded feature type 'sf'
2013-03-11 11:36:35,144 INFO [org.geoserver] - Loaded layer 'archsites'
2013-03-11 11:36:35,160 INFO [org.geoserver] - Loaded layer group 'spearfish'
2013-03-11 11:36:35,163 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
2013-03-11 11:36:35,171 INFO [org.geoserver] - Loaded layer group 'tasmania'
2013-03-11 11:36:36,090 INFO [storage.DefaultStorageFinder] -
2013-03-11 11:36:36,090 INFO [storage.DefaultStorageFinder] - ***
Reverting to java.io.tmpdir null for storage. Please set
GEOWEBCACHE_CACHE_DIR. ***
2013-03-11 11:36:36,092 INFO [config.XMLConfiguration] - Will look for
geowebcache.xml in '/tmp/tomcat7-tomcat7-tmp/geowebcache'
2013-03-11 11:36:39,350 INFO [jdbc.JDBCMBWrapper] - MetaStore database
is version 120
2013-03-11 11:36:39,502 INFO [org.geoserver] - Loaded service 'wcs', enabled
2013-03-11 11:36:39,548 INFO [org.geoserver] - Loaded service 'wfs', enabled
2013-03-11 11:36:39,628 INFO [org.geoserver] - Loaded service 'wms', enabled
2013-03-11 11:36:39,635 INFO [gwc.config] - Initializing GeoServer
specific GWC configuration from gwc-gs.xml
2013-03-11 11:36:40,479 INFO [gwc.layer] - Initializing GWC
configuration based on GeoServer's Catalog
2013-03-11 11:36:40,479 INFO [gwc.layer] - GeoServer TileLayer store
base directory is: /var/lib/tomcat7/webapps/geoserver/data/gwc-layers
2013-03-11 11:36:40,487 INFO [gwc.layer] - Loading tile layers from
2013-03-11 11:36:40,652 INFO [gwc.layer] - GWC configuration based on
GeoServer's Catalog loaded successfuly
2013-03-11 11:36:40,653 WARN [config.XMLConfiguration] - Found no
configuration file in config directory, will create one at
'/tmp/tomcat7-tomcat7-tmp/geowebcache/geowebcache.xml' from template
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/gwc-core-1.3-RC5.jar!/geowebcache_empty.xml
2013-03-11 11:36:40,870 INFO [config.XMLConfiguration] - Configuration
file validated fine.
2013-03-11 11:36:40,889 INFO [config.XMLConfiguration] - Initializing
GridSets from /tmp/tomcat7-tomcat7-tmp/geowebcache
layers from /tmp/tomcat7-tomcat7-tmp/geowebcache
2013-03-11 11:36:40,889 INFO [layer.TileLayerDispatcher] -
Configuration /tmp/tomcat7-tomcat7-tmp/geowebcache contained no
layers.
2013-03-11 11:36:41,107 INFO [storage.EntityStoreBuilder] - Neither
disk quota page store' cache memory percent nor cache size was
provided. Defaulting to 25% Heap Size
2013-03-11 11:36:49,479 INFO [storage.BDBQuotaStore] - Berkeley DB JE
Disk Quota page store configured at
/tmp/tomcat7-tomcat7-tmp/geowebcache/diskquota_page_store
2013-03-11 11:36:49,482 INFO [storage.BDBQuotaStore] - Quota Store
initialized. Global quota: 0,0 B
2013-03-11 11:36:49,492 INFO [diskquota.ConfigLoader] - DiskQuota
configuration not found:
/tmp/tomcat7-tomcat7-tmp/geowebcache/geowebcache-diskquota.xml
2013-03-11 11:36:49,501 INFO [diskquota.DiskQuotaMonitor] - Setting up
disk quota periodic enforcement task
2013-03-11 11:36:49,505 INFO [diskquota.DiskQuotaMonitor] - 0 layers
configured with their own quotas.
2013-03-11 11:36:49,506 INFO [diskquota.DiskQuotaMonitor] - 22 layers
attached to global quota 500,0 MB
2013-03-11 11:36:49,544 INFO [diskquota.DiskQuotaMonitor] - Disk quota
periodic enforcement task set up every 10 SECONDS
2013-03-11 11:36:49,884 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/gwc/service/**] onto handler 'dispatcher'
2013-03-11 11:36:49,926 INFO [geowebcache.GeoWebCacheDispatcher] -
Invoked setServletPrefix(gwc)
2013-03-11 11:36:49,955 INFO [georss.GeoRSSPoller] - Initializing
GeoRSS poller in a background job...
2013-03-11 11:36:49,956 INFO [georss.GeoRSSPoller] - No enabled GeoRSS
feeds found, poller will not run.
2013-03-11 11:36:50,980 INFO [rest.RESTDispatcher] - Created
RESTDispatcher with 13 paths
2013-03-11 11:36:51,074 INFO [wms.WMSService] - Will NOT recombine
tiles for non-tiling clients.
2013-03-11 11:36:51,074 INFO [wms.WMSService] - Will proxy requests to
backend that are not getmap or getcapabilities.
2013-03-11 11:36:51,158 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/ows/**] onto handler 'dispatcher'
[/ows] onto handler 'dispatcher'
2013-03-11 11:36:51,182 INFO [org.geoserver] - GeoServer configuration
lock is enabled
2013-03-11 11:36:51,468 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wcs] onto handler 'dispatcher'
[/wcs/**] onto handler 'dispatcher'
2013-03-11 11:36:57,534 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wfs/*] onto handler 'dispatcher'
[/TestWfsPost] onto handler 'wfsTestServlet'
[/wfs] onto handler 'dispatcher'
2013-03-11 11:37:30,119 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wms/*] onto handler 'dispatcher'
[/wms] onto handler 'dispatcher'
2013-03-11 11:37:30,227 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/kml] onto handler 'dispatcher'
2013-03-11 11:37:30,228 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/kml/*] onto handler 'dispatcher'
2013-03-11 11:37:30,230 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/animate] onto handler 'dispatcher'
2013-03-11 11:37:30,231 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/animate/*] onto handler 'dispatcher'
Dear Kristina,
see my observations inline below...
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Mar 11, 2013 at 3:42 PM, Kristina Knoppe
<k_knop03@anonymised.com> wrote:
Hello everyone,
Mind you, we usually recommend Oracle JDK.
documentation:
gdalinfo --formats
Supported Formats:
is working.
gdalinfo --version
Well, it looks like you already have GDAL installed somewhere in your
path and the current install is not pick up by GeoServer.
I would also try to use the -Djava.library.path switch to tell
GeoServer where to get the dynamic libs.
It might help to remove also precedent GDAL installations from the server.
Let us know if you make any progresses.
Kristina
exception
'geoServerLoader':
'it.geosolutions'
'poi', enabled
null, using: mosaic
'img_sample2'
'Pk50095', disabled
'worldImageSample'
'worldImageSample'
'arcGridSample'
'states_shapefile'
'states', enabled
'states_shapefile'
'roads', enabled
'streams', enabled
'bugsites', enabled
is version 120
layers.
lock is enabled
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave(TM): Endpoint Security, Q1 2013 and "remains a good choice" in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
Dear Simone,
thanks for your answer!
I just used OpenJDK because it was installed on the system. Will it
make a difference which Java JDK I use?
I removed the old version and installed GDAL 1.9.1, couldn't find a
newer version in the repositories and compiling failed for some
reason...
About the -Djava.library.path: Where can I set it? I read [1] that
instead you can set the JAVA_OPTS environment variable which I did:
echo $JAVA_OPTS
-Djava.library.path=/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64
Still, there are no changes and i'm beginning to get desperate...
-Kristina
[1] http://stackoverflow.com/questions/6150428/native-libraries-not-found-in-tomcat
2013/3/11 Simone Giannecchini <simone.giannecchini@anonymised.com>:
Dear Kristina,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
documentation:
gdalinfo --formats
Supported Formats:
is working.
gdalinfo --version
Kristina
exception
'geoServerLoader':
'it.geosolutions'
'poi', enabled
null, using: mosaic
'img_sample2'
'Pk50095', disabled
'worldImageSample'
'worldImageSample'
'arcGridSample'
'states_shapefile'
'states', enabled
'states_shapefile'
'roads', enabled
'streams', enabled
'bugsites', enabled
is version 120
layers.
lock is enabled
Hi Kristina,
please, read below for answers to some of your questions and additional questions on my side.
On Tue, Mar 12, 2013 at 11:50 AM, Kristina Knoppe <k_knop03@anonymised.com> wrote:
Dear Simone,
You mean the 1.7.3 right?
and installed GDAL 1.9.1, couldn’t find a
reason…
Did you also try again with the previously downloaded 1.9.2 once 1.7.3 has been removed?
echo $JAVA_OPTS
Can you paste a few info?
  • The list of jars contained on your tomcat/webapps/geoserver/WEB-INF/lib
  • The list of libs contained on your java.library.path.
  • a “gdalinfo --version” command output
  • the full geoserver log
Please, let us know.
Best Regards,
Daniele
Still, there are no changes and i’m beginning to get desperate…
-Kristina
Dear Kristina,
see my observations inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hello everyone,
I’m quite new to geoserver and have run into trouble installing GDAL
I don’t get any error messages in the geoserver log file (see below),
but the additional file formats don’t show up in the GUI.
I’m running Geoserver 2.2.5 on a Tomcat7 and using JAVA 1.6.0_27
I’m quite sure that I did everything correctly as described in the
documentation:
gdalinfo --formats
Supported Formats:
I need the HFA format which is present… so I assume the GDAL library
is working.
One thing I don’t really understand is:
gdalinfo --version
Kristina
monitor shutting down…
down quota usage monitor…
Shutting down quota usage monitor…
down quota statistics gathering monitor…
exception
close quota store…
Initiating shut down for running and pending seed tasks…
‘geoServerLoader’:
Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean
  • GEOSERVER_DATA_DIR: /var/lib/tomcat7/webapps/geoserver/data
2013-03-11 11:36:15,722 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2013-03-11 11:36:15,729 INFO [org.geoserver] - Loaded style ‘capitals’
2013-03-11 11:36:15,731 INFO [org.geoserver] - Loaded style ‘population’
2013-03-11 11:36:15,734 INFO [org.geoserver] - Loaded style ‘green’
2013-03-11 11:36:15,735 INFO [org.geoserver] - Loaded style ‘poi’
2013-03-11 11:36:15,737 INFO [org.geoserver] - Loaded style ‘burg’
2013-03-11 11:36:16,555 INFO [org.geoserver] - Loaded style ‘raster’
2013-03-11 11:36:16,559 INFO [org.geoserver] - Loaded style ‘pophatch’
2013-03-11 11:36:16,562 INFO [org.geoserver] - Loaded style ‘simple_roads’
2013-03-11 11:36:16,563 INFO [org.geoserver] - Loaded style ‘simple_streams’
2013-03-11 11:36:16,565 INFO [org.geoserver] - Loaded style ‘line’
2013-03-11 11:36:16,567 INFO [org.geoserver] - Loaded style ‘grass’
2013-03-11 11:36:16,569 INFO [org.geoserver] - Loaded style ‘point’
2013-03-11 11:36:16,571 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2013-03-11 11:36:16,574 INFO [org.geoserver] - Loaded style ‘polygon’
2013-03-11 11:36:16,576 INFO [org.geoserver] - Loaded style ‘restricted’
2013-03-11 11:36:16,579 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2013-03-11 11:36:16,582 INFO [org.geoserver] - Loaded style ‘rain’
2013-03-11 11:36:16,585 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2013-03-11 11:36:16,587 INFO [org.geoserver] - Loaded style ‘dem’
2013-03-11 11:36:16,604 INFO [org.geoserver] - Loaded workspace ‘sde’
2013-03-11 11:36:16,619 INFO [org.geoserver] - Loaded workspace ‘cite’
‘it.geosolutions’
2013-03-11 11:36:16,631 INFO [org.geoserver] - Loaded workspace ‘tiger’
2013-03-11 11:36:16,636 INFO [org.geoserver] - Loaded workspace ‘nurc’
2013-03-11 11:36:16,642 INFO [org.geoserver] - Loaded workspace ‘topp’
2013-03-11 11:36:16,647 INFO [org.geoserver] - Loaded workspace ‘Doliche’
2013-03-11 11:36:16,655 INFO [org.geoserver] - Loaded workspace ‘sf’
2013-03-11 11:36:19,497 INFO [org.geoserver] - Loaded store ‘nyc’, enabled
2013-03-11 11:36:19,512 INFO [org.geoserver] - Loaded data store ‘nyc’
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”,
SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”,
0.0], UNIT[“degree”, 0.017453292519943295]],
PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”,
0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”,
1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”,
0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH],
AUTHORITY[“EPSG”,“54004”]]
‘tiger_roads’, enabled
2013-03-11 11:36:26,011 INFO [org.geoserver] - Loaded feature type ‘nyc’
2013-03-11 11:36:26,046 INFO [org.geoserver] - Loaded layer ‘tiger_roads’
‘poi’, enabled
2013-03-11 11:36:26,057 INFO [org.geoserver] - Loaded feature type ‘nyc’
2013-03-11 11:36:26,064 INFO [org.geoserver] - Loaded layer ‘poi’
‘poly_landmarks’, enabled
2013-03-11 11:36:26,076 INFO [org.geoserver] - Loaded feature type ‘nyc’
2013-03-11 11:36:26,079 INFO [org.geoserver] - Loaded layer ‘poly_landmarks’
‘giant_polygon’, enabled
2013-03-11 11:36:26,088 INFO [org.geoserver] - Loaded feature type ‘nyc’
2013-03-11 11:36:26,092 INFO [org.geoserver] - Loaded layer ‘giant_polygon’
2013-03-11 11:36:27,111 INFO [org.geoserver] - Loaded store ‘mosaic’, enabled
2013-03-11 11:36:27,117 INFO [org.geoserver] - Loaded coverage store ‘mosaic’
2013-03-11 11:36:27,217 INFO [org.geoserver] - Loaded coverage ‘mosaic’, enabled
2013-03-11 11:36:27,248 INFO [org.geoserver] - Loaded coverage ‘mosaic’
null, using: mosaic
2013-03-11 11:36:30,711 INFO [org.geoserver] - Loaded layer ‘mosaic’
‘img_sample2’, disabled
‘img_sample2’
‘Pk50095’, disabled
2013-03-11 11:36:32,824 INFO [org.geoserver] - Loaded coverage ‘img_sample2’
2013-03-11 11:36:32,827 INFO [org.geoserver] - Loaded layer ‘Pk50095’
‘worldImageSample’, enabled
‘worldImageSample’
‘Img_Sample’, enabled
‘worldImageSample’
2013-03-11 11:36:32,996 INFO [org.geoserver] - Loaded layer ‘Img_Sample’
‘arcGridSample’, enabled
‘arcGridSample’
‘Arc_Sample’, enabled
2013-03-11 11:36:33,631 INFO [org.geoserver] - Loaded coverage ‘arcGridSample’
2013-03-11 11:36:33,694 INFO [org.geoserver] - Loaded layer ‘Arc_Sample’
‘taz_shapes’, enabled
2013-03-11 11:36:33,728 INFO [org.geoserver] - Loaded data store ‘taz_shapes’
‘tasmania_state_boundaries’, enabled
2013-03-11 11:36:33,776 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
‘tasmania_roads’, enabled
2013-03-11 11:36:33,792 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2013-03-11 11:36:33,800 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
‘tasmania_water_bodies’, enabled
2013-03-11 11:36:33,815 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
‘tasmania_cities’, enabled
2013-03-11 11:36:33,831 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
2013-03-11 11:36:33,839 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
‘states_shapefile’, enabled
‘states_shapefile’
‘states’, enabled
‘states_shapefile’
2013-03-11 11:36:34,775 INFO [org.geoserver] - Loaded layer ‘states’
2013-03-11 11:36:34,811 INFO [org.geoserver] - Loaded store ‘sfdem’, enabled
2013-03-11 11:36:34,812 INFO [org.geoserver] - Loaded coverage store ‘sfdem’
2013-03-11 11:36:34,865 INFO [org.geoserver] - Loaded coverage ‘sfdem’, enabled
2013-03-11 11:36:35,042 INFO [org.geoserver] - Loaded layer ‘sfdem’
2013-03-11 11:36:35,049 INFO [org.geoserver] - Loaded store ‘sf’, enabled
2013-03-11 11:36:35,049 INFO [org.geoserver] - Loaded data store ‘sf’
‘roads’, enabled
2013-03-11 11:36:35,076 INFO [org.geoserver] - Loaded feature type ‘sf’
2013-03-11 11:36:35,079 INFO [org.geoserver] - Loaded layer ‘roads’
‘streams’, enabled
2013-03-11 11:36:35,092 INFO [org.geoserver] - Loaded feature type ‘sf’
2013-03-11 11:36:35,097 INFO [org.geoserver] - Loaded layer ‘streams’
‘bugsites’, enabled
2013-03-11 11:36:35,111 INFO [org.geoserver] - Loaded feature type ‘sf’
2013-03-11 11:36:35,116 INFO [org.geoserver] - Loaded layer ‘bugsites’
‘restricted’, enabled
2013-03-11 11:36:35,122 INFO [org.geoserver] - Loaded feature type ‘sf’
2013-03-11 11:36:35,131 INFO [org.geoserver] - Loaded layer ‘restricted’
‘archsites’, enabled
2013-03-11 11:36:35,138 INFO [org.geoserver] - Loaded feature type ‘sf’
2013-03-11 11:36:35,144 INFO [org.geoserver] - Loaded layer ‘archsites’
2013-03-11 11:36:35,160 INFO [org.geoserver] - Loaded layer group ‘spearfish’
2013-03-11 11:36:35,163 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
2013-03-11 11:36:35,171 INFO [org.geoserver] - Loaded layer group ‘tasmania’
geowebcache.xml in ‘/tmp/tomcat7-tomcat7-tmp/geowebcache’
is version 120
2013-03-11 11:36:39,502 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
2013-03-11 11:36:39,548 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2013-03-11 11:36:39,628 INFO [org.geoserver] - Loaded service ‘wms’, enabled
configuration based on GeoServer’s Catalog
GeoServer’s Catalog loaded successfuly
‘/tmp/tomcat7-tomcat7-tmp/geowebcache/geowebcache.xml’ from template
layers.
disk quota page store’ cache memory percent nor cache size was
[/gwc/service/] onto handler ‘dispatcher’
GeoRSS poller in a background job…
[/ows/
[/ows] onto handler ‘dispatcher’
lock is enabled
[/wcs] onto handler ‘dispatcher’
[/wcs/**] onto handler ‘dispatcher’
[/wfs/] onto handler ‘dispatcher’
[/TestWfsPost] onto handler ‘wfsTestServlet’
[/wfs] onto handler ‘dispatcher’
[/wms/
[/wms] onto handler ‘dispatcher’
[/kml] onto handler ‘dispatcher’
[/kml/] onto handler ‘dispatcher’
[/animate] onto handler ‘dispatcher’
[/animate/
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
Ing. Daniele Romagnoli
Senior Software Engineer
Hey,
I finally made it work. Somehow, the access permissions were not
granted to the *.so files -.- so they could not be executed.
Thank you both for the quick answers :slight_smile:
-Kristina
2013/3/12 Daniele Romagnoli <daniele.romagnoli@anonymised.com>:
Hi Kristina,
wrote:
Dear Simone,
reason...
been removed?
echo $JAVA_OPTS
- The list of jars contained on your tomcat/webapps/geoserver/WEB-INF/lib
- The list of libs contained on your java.library.path.
- a "gdalinfo --version" command output
- the full geoserver log
Best Regards,
Daniele
-Kristina
[1]
> Dear Kristina,
> Regards,
> Simone Giannecchini
> more information.
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
>> Hello everyone,
>> documentation:
>> gdalinfo --formats
>> Supported Formats:
>> is working.
>> gdalinfo --version
> server.
>> Cheers,
>> Kristina
>> exception
>> closed.
>> StorageBroker
>> 'geoServerLoader':
>> 'tiger_roads'
>> 'population'
>> 'simple_roads'
>> 'simple_streams'
>> 'giant_polygon'
>> 'restricted'
>> 'poly_landmarks'
>> 'cite_lakes'
>> Doliche
>> 'it.geosolutions'
>> 'Doliche'
>> enabled
>> 'nyc'
>> 'tiger_roads'
>> 'poi', enabled
>> 'nyc'
>> 'nyc'
>> 'poly_landmarks'
>> 'nyc'
>> 'giant_polygon'
>> enabled
>> 'mosaic'
>> 'mosaic', enabled
>> null, using: mosaic
>> image for path
>> 'img_sample2'
>> 'Pk50095', disabled
>> 'img_sample2'
>> 'worldImageSample'
>> 'worldImageSample'
>> 'Img_Sample'
>> 'arcGridSample'
>> 'arcGridSample'
>> 'Arc_Sample'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_roads'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_cities'
>> 'states_shapefile'
>> 'states', enabled
>> 'states_shapefile'
>> enabled
>> 'sfdem'
>> enabled
>> enabled
>> 'roads', enabled
>> 'streams', enabled
>> 'bugsites', enabled
>> 'restricted'
>> 'spearfish'
>> 'tiger-ny'
>> 'tasmania'
>> is version 120
>> enabled
>> enabled
>> enabled
>> layers.
>> lock is enabled
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
information.
Hi, it's me again :-/
I thought I succsessfully installed the GDAL extension, but I got a
new problem now:
I can add new data stores, but if I change, for example the name and
hit save, nothing happens (no returning to the store main page) and
the changes are not saved.
Another - and far worse - problem is that I can't publish DGAL image
format-based stores. If I chose the store, nothing happens, I used my
browser's web console and got this:
Request-URL: http://giv-knoppe.uni-muenster.de:8081/geoserver/web/?wicket:interface=:41:selector:storesDropDown::IBehaviorListener:0:&random=0.6918369396632039
Request-Methode: POST
Status-Code: HTTP/1.1 500 Internal Server Error
If I try to publish non-GDAL stores the publishing menu pops up, but
when saving it I get this:
Error persisting CoverageInfoImpl[mosaic] to
/var/lib/tomcat7/webapps/geoserver/data/workspaces/nurc/mosaic/mosaic/coverage.xml
Since I've had problems with access rights and ownership before, here
is how it is set up currently:
all xml files and and relevant subfolders/files in here are set to
755 and owned by tomcat7, group is tomcat7
This is what is in the logfile if I try to create a GDAL-based layer:
2013-03-20 10:08:03,267 DEBUG [ows.OWSHandlerMapping] - No handler
mapping found for [/web/]
2013-03-20 10:08:03,268 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:03,269 DEBUG [org.geoserver] - Thread 46 locking in mode WRITE
2013-03-20 10:08:03,269 DEBUG [org.geoserver] - Thread 46 got the lock
in mode WRITE
2013-03-20 10:08:03,340 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/css/blueprint/screen.css
to file (URI is not hierarchical), falling back to the inputstream for
polling
2013-03-20 10:08:03,341 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/css/blueprint/print.css
polling
2013-03-20 10:08:03,343 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/css/geoserver.css
polling
2013-03-20 10:08:03,344 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/css/blueprint/ie.css
polling
2013-03-20 10:08:03,346 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/js/jquery-1.2.6.min.js
polling
2013-03-20 10:08:03,347 DEBUG [geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/js/jquery.inline-info.js
polling
2013-03-20 10:08:03,432 DEBUG [org.geoserver] - Thread 46 releasing
the lock in mode WRITE
2013-03-20 10:08:03,432 DEBUG [geoserver.filters] - Compressing output
for mimetype: text/html;charset=UTF-8
2013-03-20 10:08:04,852 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:04,853 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:04,853 DEBUG [org.geoserver] - Thread 47 locking in mode WRITE
2013-03-20 10:08:04,853 DEBUG [org.geoserver] - Thread 47 got the lock
in mode WRITE
2013-03-20 10:08:04,860 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,861 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,863 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,864 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,866 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,867 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:04,887 DEBUG [org.geoserver] - Thread 47 releasing
2013-03-20 10:08:04,887 DEBUG [geoserver.filters] - Compressing output
2013-03-20 10:08:06,857 DEBUG [diskquota.CacheCleanerTask] - DiskQuota
disabled, ignoring run...
2013-03-20 10:08:07,408 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:07,415 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:07,416 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:07,417 DEBUG [org.geoserver] - Thread 48 locking in mode WRITE
2013-03-20 10:08:07,417 DEBUG [org.geoserver] - Thread 48 got the lock
in mode WRITE
2013-03-20 10:08:07,425 DEBUG [org.geoserver] - Thread 48 releasing
2013-03-20 10:08:12,954 DEBUG [ows.OWSHandlerMapping] - No handler
2013-03-20 10:08:12,955 DEBUG [org.geoserver] - Thread 49 locking in mode WRITE
2013-03-20 10:08:12,955 DEBUG [org.geoserver] - Thread 49 got the lock
in mode WRITE
2013-03-20 10:08:12,962 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:12,963 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:12,964 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:12,971 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:12,973 DEBUG [geoserver.web] - cannot convert url:
polling
2013-03-20 10:08:12,974 DEBUG [geoserver.web] - cannot convert url:
polling
Again, i appreciate any help!
-Kristina
2013/3/12 Kristina Knoppe <k_knop03@anonymised.com>:
Hey,
-Kristina
Hi Kristina,
wrote:
Dear Simone,
reason...
been removed?
echo $JAVA_OPTS
Best Regards,
Daniele
-Kristina
[1]
> Dear Kristina,
> Regards,
> Simone Giannecchini
> more information.
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
>> Hello everyone,
>> documentation:
>> gdalinfo --formats
>> Supported Formats:
>> is working.
>> gdalinfo --version
> server.
>> Cheers,
>> Kristina
>> exception
>> closed.
>> StorageBroker
>> 'geoServerLoader':
>> 'tiger_roads'
>> 'population'
>> 'simple_roads'
>> 'simple_streams'
>> 'giant_polygon'
>> 'restricted'
>> 'poly_landmarks'
>> 'cite_lakes'
>> Doliche
>> 'it.geosolutions'
>> 'Doliche'
>> enabled
>> 'nyc'
>> 'tiger_roads'
>> 'poi', enabled
>> 'nyc'
>> 'nyc'
>> 'poly_landmarks'
>> 'nyc'
>> 'giant_polygon'
>> enabled
>> 'mosaic'
>> 'mosaic', enabled
>> null, using: mosaic
>> image for path
>> 'img_sample2'
>> 'Pk50095', disabled
>> 'img_sample2'
>> 'worldImageSample'
>> 'worldImageSample'
>> 'Img_Sample'
>> 'arcGridSample'
>> 'arcGridSample'
>> 'Arc_Sample'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_roads'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_cities'
>> 'states_shapefile'
>> 'states', enabled
>> 'states_shapefile'
>> enabled
>> 'sfdem'
>> enabled
>> enabled
>> 'roads', enabled
>> 'streams', enabled
>> 'bugsites', enabled
>> 'restricted'
>> 'spearfish'
>> 'tiger-ny'
>> 'tasmania'
>> is version 120
>> enabled
>> enabled
>> enabled
>> layers.
>> lock is enabled
information.
Hi, it’s me again :-/
new problem now:
Another - and far worse - problem is that I can’t publish DGAL image
browser’s web console and got this:
Since I’ve had problems with access rights and ownership before, here
in mode WRITE
polling
polling
polling
polling
polling
polling
in mode WRITE
polling
polling
polling
polling
polling
polling
disabled, ignoring run…
in mode WRITE
in mode WRITE
polling
polling
polling
polling
polling
polling
-Kristina
Hey,
-Kristina
Hi Kristina,
wrote:
Dear Simone,
reason…
been removed?
echo $JAVA_OPTS
Best Regards,
Daniele
-Kristina
[1]
Dear Kristina,
Simone Giannecchini
more information.
@simogeo
Founder/Director
<k_knop03@anonymised.com94…> wrote:
Hello everyone,
documentation:
gdalinfo --formats
Supported Formats:
is working.
gdalinfo --version
server.
Kristina
exception
close quota store…
closed.
StorageBroker
‘geoServerLoader’:
org.geoserver.platform.util.VersionPropertyEditor@anonymised.com5484…
‘tiger_roads’
‘population’
‘simple_roads’
‘simple_streams’
‘giant_polygon’
‘restricted’
‘poly_landmarks’
‘cite_lakes’
Doliche
‘it.geosolutions’
‘Doliche’
enabled
‘nyc’
‘tiger_roads’
‘poi’, enabled
‘nyc’
‘nyc’
‘poly_landmarks’
‘nyc’
‘giant_polygon’
enabled
‘mosaic’
‘mosaic’, enabled
null, using: mosaic
image for path
‘img_sample2’
‘Pk50095’, disabled
‘img_sample2’
‘worldImageSample’
‘worldImageSample’
‘Img_Sample’
‘arcGridSample’
‘arcGridSample’
‘Arc_Sample’
‘taz_shapes’
‘taz_shapes’
‘taz_shapes’
‘tasmania_roads’
‘taz_shapes’
‘taz_shapes’
‘tasmania_cities’
‘states_shapefile’
‘states’, enabled
‘states_shapefile’
enabled
‘sfdem’
enabled
enabled
‘roads’, enabled
‘streams’, enabled
‘bugsites’, enabled
‘restricted’
‘spearfish’
‘tiger-ny’
‘tasmania’
is version 120
enabled
enabled
enabled
layers.
[/ows/
lock is enabled
[/wms/
[/animate/
information.
Ciao Kristina,
sorry this fell of my radar for a bit.
It looks like GeoServer is not able to write the configuration files
inside its own data directory.
Two things:
-1- I would remove the default layers from GeoServer
-2- it looks like you are using GeoServer with the data_dir left
internal to the tomcat webapp dir. I would move the data dir to a
different location so that in case you update GeoServer you don't
loose it.
This way it might also be easier to give the GeoServer process the
proper rights and avoide these problems.
For more info check these links:
-http://docs.geoserver.org/stable/en/user/datadirectory/index.html
-http://docs.geoserver.org/stable/en/user/datadirectory/data-dir-setting.html
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Wed, Mar 20, 2013 at 10:09 AM, Kristina Knoppe
new problem now:
in mode WRITE
polling
polling
polling
polling
polling
polling
in mode WRITE
polling
polling
polling
polling
polling
polling
in mode WRITE
in mode WRITE
polling
polling
polling
polling
polling
polling
-Kristina
Hey,
-Kristina
Hi Kristina,
wrote:
Dear Simone,
reason...
been removed?
echo $JAVA_OPTS
Best Regards,
Daniele
-Kristina
[1]
> Dear Kristina,
> Regards,
> Simone Giannecchini
> more information.
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
>> Hello everyone,
>> documentation:
>> gdalinfo --formats
>> Supported Formats:
>> is working.
>> gdalinfo --version
> server.
>> Cheers,
>> Kristina
>> exception
>> closed.
>> StorageBroker
>> 'geoServerLoader':
>> 'tiger_roads'
>> 'population'
>> 'simple_roads'
>> 'simple_streams'
>> 'giant_polygon'
>> 'restricted'
>> 'poly_landmarks'
>> 'cite_lakes'
>> Doliche
>> 'it.geosolutions'
>> 'Doliche'
>> enabled
>> 'nyc'
>> 'tiger_roads'
>> 'poi', enabled
>> 'nyc'
>> 'nyc'
>> 'poly_landmarks'
>> 'nyc'
>> 'giant_polygon'
>> enabled
>> 'mosaic'
>> 'mosaic', enabled
>> null, using: mosaic
>> image for path
>> 'img_sample2'
>> 'Pk50095', disabled
>> 'img_sample2'
>> 'worldImageSample'
>> 'worldImageSample'
>> 'Img_Sample'
>> 'arcGridSample'
>> 'arcGridSample'
>> 'Arc_Sample'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_roads'
>> 'taz_shapes'
>> 'taz_shapes'
>> 'tasmania_cities'
>> 'states_shapefile'
>> 'states', enabled
>> 'states_shapefile'
>> enabled
>> 'sfdem'
>> enabled
>> enabled
>> 'roads', enabled
>> 'streams', enabled
>> 'bugsites', enabled
>> 'restricted'
>> 'spearfish'
>> 'tiger-ny'
>> 'tasmania'
>> is version 120
>> enabled
>> enabled
>> enabled
>> layers.
>> lock is enabled
information.
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
