[Geoserver-users] GDAL Extention installed, but formats not showing on the list of options
I have a new Centos7 server with Geoserver 2.9-RC1 installed as a Web Archive. I have followed the instructions on http://docs.geoserver.org/latest/en/user/data/raster/gdal.html but am not seeing the GDAL Image Formats on the “New data source” menu. I see no errors in the log. Any help would be appreciated.
Here is some supporting info.
I believe I have GDAL-native setup correctly.
I can run “gdalinfo –version” and it returns “GDAL 1.9.2, released 2012/10/08”.
I run ” /opt/gdal192-CentOS5.8/javainfo/gdalinfo.sh –formats” and get the following.
Supported Formats:
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (rov): Raster Product Format TOC format
ECRGTOC (rov): ECRG TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (rov): CEOS SAR Image
CEOS (rov): CEOS Image
JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+v): ELAS
AIG (rov): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
SDTS (rov): SDTS Raster
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (rov): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (rov): Maptech BSB Nautical Charts
XPM (rwv): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (rov): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
PDS (rov): NASA Planetary Data System
TIL (rov): EarthWatch .TIL
ERS (rw+v): ERMapper .ers Labelled
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
L1B (rov): NOAA Polar Orbiter Level 1b Data Set
FIT (rwv): FIT Image
MrSID (rov): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (rov): MrSID JPEG2000
RMF (rw+v): Raster Matrix Format
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+v): Idrisi Raster A.1
INGR (rw+v): Intergraph Raster
GSAG (rwv): Golden Software ASCII Grid (.grd)
GSBG (rw+v): Golden Software Binary Grid (.grd)
GS7BG (rov): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (rov): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+v): Portable Pixmap Format (netpbm)
DOQ1 (rov): USGS DOQ (Old Style)
DOQ2 (rov): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (rov): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (rov): GSC Geogrid
FAST (rov): EOSAT FAST Format
BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
LAN (rw+v): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (rov): NLAPS Data Format
EIR (rov): Erdas Imagine Raw
DIPEx (rov): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
GTX (rw+v): NOAA Vertical Datum .GTX
LOSLAS (rov): NADCON .los/.las Datum Grid Shift
NTv2 (rw+v): NTv2 Datum Grid Shift
ACE2 (rov): ACE2
SNODAS (rov): Snow Data Assimilation System
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
KMLSUPEROVERLAY (rwv): Kml Super Overlay
XYZ (rwv): ASCII Gridded XYZ
HF2 (rwv): HF2/HFZ heightfield raster
OZI (rov): OziExplorer Image File
CTG (rov): USGS LULC Composite Theme Grid
E00GRID (rov): Arc/Info Export E00 GRID
ZMap (rwv): ZMap Plus Grid
NGSGEOID (rov): NOAA NGS Geoid Height Grids
Usage: gdalinfo [–help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-norat] [-noct] [-mdd domain]* [-checksum] datasetname
I have the data files installed:
ls -l $GDAL_DATA
total 2672
-rwxr-xr-x. 1 root root 1882 Jan 1 2012 compdcs.csv
-rwxr-xr-x. 1 root root 7195 Jan 1 2012 coordinate_axis.csv
-rwxr-xr-x. 1 root root 12025 Jan 1 2012 cubewerx_extra.wkt
-rwxr-xr-x. 1 root root 158260 Jan 1 2012 datum_shift.csv
-rwxr-xr-x. 1 root root 364766 Jan 1 2012 ecw_cs.wkt
-rwxr-xr-x. 1 root root 13898 Jan 1 2012 ellipsoid.csv
-rwxr-xr-x. 1 root root 52 Jan 1 2012 epsg.wkt
-rwxr-xr-x. 1 root root 209629 Jan 1 2012 esri_extra.wkt
-rwxr-xr-x. 1 root root 332546 Jan 1 2012 esri_StatePlane_extra.wkt
-rwxr-xr-x. 1 root root 75845 Jan 1 2012 esri_Wisconsin_extra.wkt
-rwxr-xr-x. 1 root root 49247 Jan 1 2012 gcs.csv
-rwxr-xr-x. 1 root root 513 Jan 1 2012 gcs.override.csv
-rwxr-xr-x. 1 root root 186320 Jan 1 2012 gdal_datum.csv
-rwxr-xr-x. 1 root root 13224 Jan 1 2012 GDALLogoBW.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoColor.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoGS.svg
-rwxr-xr-x. 1 root root 10033 Jan 1 2012 geoccs.csv
-rwxr-xr-x. 1 root root 15804 Jan 1 2012 gt_datum.csv
-rwxr-xr-x. 1 root root 1719 Jan 1 2012 gt_ellips.csv
-rwxr-xr-x. 1 root root 9120 Jan 1 2012 header.dxf
-rwxr-xr-x. 1 root root 60387 Jan 1 2012 nitf_spec.xml
-rwxr-xr-x. 1 root root 6144 Jan 1 2012 nitf_spec.xsd
-rwxr-xr-x. 1 root root 35009 Jan 1 2012 pci_datum.txt
-rwxr-xr-x. 1 root root 3466 Jan 1 2012 pci_ellips.txt
-rwxr-xr-x. 1 root root 566127 Jan 1 2012 pcs.csv
-rwxr-xr-x. 1 root root 1525 Jan 1 2012 pcs.override.csv
-rwxr-xr-x. 1 root root 1664 Jan 1 2012 prime_meridian.csv
-rwxr-xr-x. 1 root root 206531 Jan 1 2012 projop_wparm.csv
-rwxr-xr-x. 1 root root 13553 Jan 1 2012 s57agencies.csv
-rwxr-xr-x. 1 root root 18555 Jan 1 2012 s57attributes_aml.csv
-rwxr-xr-x. 1 root root 7452 Jan 1 2012 s57attributes.csv
-rwxr-xr-x. 1 root root 8981 Jan 1 2012 s57attributes_iw.csv
-rwxr-xr-x. 1 root root 21893 Jan 1 2012 s57expectedinput.csv
-rwxr-xr-x. 1 root root 64289 Jan 1 2012 s57objectclasses_aml.csv
-rwxr-xr-x. 1 root root 31408 Jan 1 2012 s57objectclasses.csv
-rwxr-xr-x. 1 root root 37247 Jan 1 2012 s57objectclasses_iw.csv
-rwxr-xr-x. 1 root root 9216 Jan 1 2012 seed_2d.dgn
-rwxr-xr-x. 1 root root 2048 Jan 1 2012 seed_3d.dgn
-rwxr-xr-x. 1 root root 10619 Jan 1 2012 stateplane.csv
-rwxr-xr-x. 1 root root 12071 Jan 1 2012 trailer.dxf
-rwxr-xr-x. 1 root root 18941 Jan 1 2012 unit_of_measure.csv
-rwxr-xr-x. 1 root root 8152 Jan 1 2012 vertcs.csv
-rwxr-xr-x. 1 root root 908 Jan 1 2012 vertcs.override.csv
ls -l /usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib
total 65184
-rw-r–r–. 1 root root 62983 Sep 16 2013 activation-1.1.jar
-rw-r–r–. 1 root root 4467 Sep 12 2013 aopalliance-1.0.jar
-rw-r–r–. 1 root root 95313 Sep 16 2013 batik-anim-1.7.jar
-rw-r–r–. 1 root root 401858 Sep 16 2013 batik-awt-util-1.7.jar
-rw-r–r–. 1 root root 558892 Sep 16 2013 batik-bridge-1.7.jar
-rw-r–r–. 1 root root 310919 Sep 16 2013 batik-css-1.7.jar
-rw-r–r–. 1 root root 173530 Sep 16 2013 batik-dom-1.7.jar
-rw-r–r–. 1 root root 10257 Sep 16 2013 batik-ext-1.7.jar
-rw-r–r–. 1 root root 242866 Sep 16 2013 batik-gvt-1.7.jar
-rw-r–r–. 1 root root 504741 Sep 16 2013 batik-js-1.7.jar
-rw-r–r–. 1 root root 73119 Sep 16 2013 batik-parser-1.7.jar
-rw-r–r–. 1 root root 60604 Sep 16 2013 batik-script-1.7.jar
-rw-r–r–. 1 root root 601098 Sep 16 2013 batik-svg-dom-1.7.jar
-rw-r–r–. 1 root root 215274 Sep 16 2013 batik-svggen-1.7.jar
-rw-r–r–. 1 root root 121997 Sep 16 2013 batik-transcoder-1.7.jar
-rw-r–r–. 1 root root 128286 Sep 16 2013 batik-util-1.7.jar
-rw-r–r–. 1 root root 30843 Sep 16 2013 batik-xml-1.7.jar
-rw-r–r–. 1 root root 1824421 Sep 12 2013 bcprov-jdk14-1.46.jar
-rw-r–r–. 1 root root 322362 Sep 16 2013 cglib-nodep-2.2.jar
-rw-r–r–. 1 root root 211652 Sep 12 2013 common-2.6.0.jar
-rw-r–r–. 1 root root 188671 Sep 12 2013 commons-beanutils-1.7.0.jar
-rw-r–r–. 1 root root 263965 Mar 21 2014 commons-codec-1.9.jar
-rw-r–r–. 1 root root 588337 Mar 24 08:25 commons-collections-3.2.2.jar
-rw-r–r–. 1 root root 160519 Dec 22 2013 commons-dbcp-1.4.jar
-rw-r–r–. 1 root root 57779 Sep 12 2013 commons-fileupload-1.2.1.jar
-rw-r–r–. 1 root root 305001 Sep 12 2013 commons-httpclient-3.1.jar
-rw-r–r–. 1 root root 163151 Sep 12 2013 commons-io-2.1.jar
-rw-r–r–. 1 root root 299994 Sep 12 2013 commons-jxpath-1.3.jar
-rw-r–r–. 1 root root 284220 Nov 9 2013 commons-lang-2.6.jar
-rw-r–r–. 1 root root 60686 Sep 12 2013 commons-logging-1.1.1.jar
-rw-r–r–. 1 root root 96203 Sep 16 2013 commons-pool-1.5.3.jar
-rw-r–r–. 1 root root 150629 Sep 12 2013 com.noelios.restlet-1.0.8.jar
-rw-r–r–. 1 root root 14072 Sep 12 2013 com.noelios.restlet.ext.servlet-1.0.8.jar
-rw-r–r–. 1 root root 10114 Sep 16 2013 com.noelios.restlet.ext.simple-1.0.8.jar
-rw-r–r–. 1 root root 342540 May 10 2015 core-0.26.jar
-rw-r–r–. 1 root root 1231403 Sep 12 2013 ecore-2.6.1.jar
-rw-r–r–. 1 root root 203035 Sep 12 2013 ehcache-1.6.2.jar
-rw-r–r–. 1 root root 37176 Sep 16 2013 encoder-1.1.jar
-rw-r–r–. 1 root root 86487 Sep 12 2013 ezmorph-1.0.6.jar
-rw-r–r–. 1 root root 924269 Sep 12 2013 freemarker-2.3.18.jar
-rw-r–r–. 1 root root 31693 Aug 28 2015 GeographicLib-Java-1.44.jar
-rw-r–r–. 1 root root 321652 May 3 10:19 geoserver-2.9-RC1-gdal-plugin.zip
-rw-r–r–. 1 root root 2564 May 3 17:15 gs-gdal-2.9-RC1.jar
-rw-r–r–. 1 root root 194137 May 3 17:11 gs-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 181456 May 3 17:11 gs-kml-2.9-RC1.jar
-rw-r–r–. 1 root root 1824051 May 3 17:10 gs-main-2.9-RC1.jar
-rw-r–r–. 1 root root 170214 May 3 17:09 gs-ows-2.9-RC1.jar
-rw-r–r–. 1 root root 115740 May 3 17:09 gs-platform-2.9-RC1.jar
-rw-r–r–. 1 root root 64502 May 3 17:11 gs-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 266528 May 3 17:11 gs-restconfig-2.9-RC1.jar
-rw-r–r–. 1 root root 57595 May 3 17:10 gs-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 46399 May 3 17:10 gs-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 116478 May 3 17:10 gs-wcs1_0-2.9-RC1.jar
-rw-r–r–. 1 root root 144135 May 3 17:10 gs-wcs1_1-2.9-RC1.jar
-rw-r–r–. 1 root root 432798 May 3 17:10 gs-wcs2_0-2.9-RC1.jar
-rw-r–r–. 1 root root 46004 May 3 17:10 gs-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 1425896 May 3 17:11 gs-web-core-2.9-RC1.jar
-rw-r–r–. 1 root root 374083 May 3 17:12 gs-web-demo-2.9-RC1.jar
-rw-r–r–. 1 root root 367266 May 3 17:11 gs-web-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 4422 May 3 17:12 gs-web-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 561505 May 3 17:12 gs-web-sec-core-2.9-RC1.jar
-rw-r–r–. 1 root root 23204 May 3 17:12 gs-web-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 21131 May 3 17:12 gs-web-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 76073 May 3 17:12 gs-web-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 36944 May 3 17:11 gs-web-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 157306 May 3 17:11 gs-web-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 686071 May 3 17:10 gs-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 958309 May 3 17:11 gs-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 207878 May 2 20:17 gt-api-15-RC1.jar
-rw-r–r–. 1 root root 13977 May 2 20:24 gt-app-schema-resolver-15-RC1.jar
-rw-r–r–. 1 root root 23927 May 2 20:19 gt-arcgrid-15-RC1.jar
-rw-r–r–. 1 root root 59903 May 2 20:24 gt-complex-15-RC1.jar
-rw-r–r–. 1 root root 585183 May 2 20:19 gt-coverage-15-RC1.jar
-rw-r–r–. 1 root root 197346 May 2 20:19 gt-cql-15-RC1.jar
-rw-r–r–. 1 root root 88409 May 2 20:19 gt-data-15-RC1.jar
-rw-r–r–. 1 root root 2330229 May 2 20:18 gt-epsg-hsql-15-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 20:25 gt-geojson-15-RC1.jar
-rw-r–r–. 1 root root 31173 May 2 20:19 gt-geotiff-15-RC1.jar
-rw-r–r–. 1 root root 170468 May 2 20:18 gt-graph-15-RC1.jar
-rw-r–r–. 1 root root 35024 May 2 20:24 gt-grid-15-RC1.jar
-rw-r–r–. 1 root root 38722 May 2 20:22 gt-gtopo30-15-RC1.jar
-rw-r–r–. 1 root root 22658 May 2 20:22 gt-image-15-RC1.jar
-rw-r–r–. 1 root root 79294 May 3 17:15 gt-imageio-ext-gdal-15-RC1.jar
-rw-r–r–. 1 root root 374650 May 2 20:22 gt-imagemosaic-15-RC1.jar
-rw-r–r–. 1 root root 219685 May 2 20:21 gt-jdbc-15-RC1.jar
-rw-r–r–. 1 root root 50882 May 2 20:22 gt-jdbc-postgis-15-RC1.jar
-rw-r–r–. 1 root root 1753607 May 2 20:18 gt-main-15-RC1.jar
-rw-r–r–. 1 root root 510990 May 2 20:17 gt-metadata-15-RC1.jar
-rw-r–r–. 1 root root 351036 May 2 20:17 gt-opengis-15-RC1.jar
-rw-r–r–. 1 root root 59087 May 2 20:25 gt-process-15-RC1.jar
-rw-r–r–. 1 root root 176741 May 2 20:25 gt-process-feature-15-RC1.jar
-rw-r–r–. 1 root root 120766 May 2 20:26 gt-process-raster-15-RC1.jar
-rw-r–r–. 1 root root 24551 May 2 20:19 gt-property-15-RC1.jar
-rw-r–r–. 1 root root 1180650 May 2 20:17 gt-referencing-15-RC1.jar
-rw-r–r–. 1 root root 565938 May 2 20:20 gt-render-15-RC1.jar
-rw-r–r–. 1 root root 219407 May 2 20:19 gt-shapefile-15-RC1.jar
-rw-r–r–. 1 root root 9015 May 2 20:23 gt-svg-15-RC1.jar
-rw-r–r–. 1 root root 40093 May 2 20:22 gt-transform-15-RC1.jar
-rw-r–r–. 1 root root 243470 May 2 20:25 gt-wfs-ng-15-RC1.jar
-rw-r–r–. 1 root root 230688 May 2 20:24 gt-wms-15-RC1.jar
-rw-r–r–. 1 root root 651627 May 2 20:21 gt-xml-15-RC1.jar
-rw-r–r–. 1 root root 313002 May 2 20:18 gt-xsd-core-15-RC1.jar
-rw-r–r–. 1 root root 69559 May 2 20:20 gt-xsd-fes-15-RC1.jar
-rw-r–r–. 1 root root 106563 May 2 20:20 gt-xsd-filter-15-RC1.jar
-rw-r–r–. 1 root root 117409 May 2 20:19 gt-xsd-gml2-15-RC1.jar
-rw-r–r–. 1 root root 1553765 May 2 20:19 gt-xsd-gml3-15-RC1.jar
-rw-r–r–. 1 root root 121602 May 2 20:20 gt-xsd-ows-15-RC1.jar
-rw-r–r–. 1 root root 176648 May 2 20:20 gt-xsd-sld-15-RC1.jar
-rw-r–r–. 1 root root 177013 May 2 20:24 gt-xsd-wcs-15-RC1.jar
-rw-r–r–. 1 root root 148574 May 2 20:20 gt-xsd-wfs-15-RC1.jar
-rw-r–r–. 1 root root 2243036 Jun 3 2014 guava-17.0.jar
-rw-r–r–. 1 root root 570913 May 2 21:44 gwc-core-1.9-RC1.jar
-rw-r–r–. 1 root root 92133 May 2 21:46 gwc-diskquota-core-1.9-RC1.jar
-rw-r–r–. 1 root root 54352 May 2 21:46 gwc-diskquota-jdbc-1.9-RC1.jar
-rw-r–r–. 1 root root 35777 May 2 21:46 gwc-georss-1.9-RC1.jar
-rw-r–r–. 1 root root 8627 May 2 21:46 gwc-gmaps-1.9-RC1.jar
-rw-r–r–. 1 root root 21829 May 2 21:46 gwc-kml-1.9-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 21:46 gwc-rest-1.9-RC1.jar
-rw-r–r–. 1 root root 10648 May 2 21:46 gwc-tms-1.9-RC1.jar
-rw-r–r–. 1 root root 5493 May 2 21:46 gwc-ve-1.9-RC1.jar
-rw-r–r–. 1 root root 62487 May 2 21:46 gwc-wms-1.9-RC1.jar
-rw-r–r–. 1 root root 20021 May 2 21:46 gwc-wmts-1.9-RC1.jar
-rw-r–r–. 1 root root 1207393 Sep 12 2013 h2-1.1.119.jar
-rw-r–r–. 1 root root 1466946 May 25 2015 hsqldb-2.3.0.jar
-rw-r–r–. 1 root root 39860 Nov 6 2015 imageio-ext-arcgrid-1.1.13.jar
-rw-r–r–. 1 root root 5151 May 3 17:15 imageio-ext-gdalarcbinarygrid-1.1.13.jar
-rw-r–r–. 1 root root 94016 May 3 17:15 imageio-ext-gdal-bindings-1.9.2.jar
-rw-r–r–. 1 root root 4938 May 3 17:15 imageio-ext-gdaldted-1.1.13.jar
-rw-r–r–. 1 root root 8106 May 3 17:15 imageio-ext-gdalecw-1.1.13.jar
-rw-r–r–. 1 root root 5083 May 3 17:15 imageio-ext-gdalecwjp2-1.1.13.jar
-rw-r–r–. 1 root root 4939 May 3 17:15 imageio-ext-gdalehdr-1.1.13.jar
-rw-r–r–. 1 root root 5037 May 3 17:15 imageio-ext-gdalenvihdr-1.1.13.jar
-rw-r–r–. 1 root root 5033 May 3 17:15 imageio-ext-gdalerdasimg-1.1.13.jar
-rw-r–r–. 1 root root 57744 May 3 17:15 imageio-ext-gdalframework-1.1.13.jar
-rw-r–r–. 1 root root 5006 May 3 17:15 imageio-ext-gdalidrisi-1.1.13.jar
-rw-r–r–. 1 root root 14978 May 3 17:15 imageio-ext-gdalkakadujp2-1.1.13.jar
-rw-r–r–. 1 root root 8703 May 3 17:15 imageio-ext-gdalmrsid-1.1.13.jar
-rw-r–r–. 1 root root 5129 May 3 17:15 imageio-ext-gdalmrsidjp2-1.1.13.jar
-rw-r–r–. 1 root root 4928 May 3 17:15 imageio-ext-gdalnitf-1.1.13.jar
-rw-r–r–. 1 root root 4981 May 3 17:15 imageio-ext-gdalrpftoc-1.1.13.jar
-rw-r–r–. 1 root root 26688 May 3 17:15 imageio-ext-geocore-1.1.13.jar
-rw-r–r–. 1 root root 26911 May 3 17:15 imageio-ext-imagereadmt-1.1.13.jar
-rw-r–r–. 1 root root 19493 Nov 10 2015 imageio-ext-png-1.1.13.jar
-rw-r–r–. 1 root root 52275 Nov 6 2015 imageio-ext-streams-1.1.13.jar
-rw-r–r–. 1 root root 335165 Nov 6 2015 imageio-ext-tiff-1.1.13.jar
-rw-r–r–. 1 root root 40586 Nov 6 2015 imageio-ext-utilities-1.1.13.jar
-rw-r–r–. 1 root root 1117661 Sep 16 2013 itext-2.1.5.jar
-rw-r–r–. 1 root root 258160 Sep 12 2013 jai_codec-1.1.3.jar
-rw-r–r–. 1 root root 1900631 Sep 12 2013 jai_core-1.1.3.jar
-rw-r–r–. 1 root root 1140632 Sep 12 2013 jai_imageio-1.1.jar
-rw-r–r–. 1 root root 178961 Sep 12 2013 jasypt-1.8.jar
-rw-r–r–. 1 root root 619507 Sep 16 2013 JavaAPIforKml-2.2.0.jar
-rw-r–r–. 1 root root 151304 Sep 29 2013 jdom-1.1.3.jar
-rw-r–r–. 1 root root 56702 Sep 12 2013 jettison-1.0.1.jar
-rw-r–r–. 1 root root 11497 Sep 12 2013 jgridshift-1.0.jar
-rw-r–r–. 1 root root 148490 Sep 12 2013 json-lib-2.2.3-jdk15.jar
-rw-r–r–. 1 root root 16046 Sep 16 2013 json-simple-1.1.jar
-rw-r–r–. 1 root root 91347 Sep 12 2013 jsr-275-1.0-beta-2.jar
-rw-r–r–. 1 root root 33031 Jun 9 2014 jsr305-2.0.3.jar
-rw-r–r–. 1 root root 117361 Apr 1 13:34 jt-affine-1.0.9.jar
-rw-r–r–. 1 root root 62676 Apr 1 13:34 jt-algebra-1.0.9.jar
-rw-r–r–. 1 root root 3839 Aug 26 2015 jt-attributeop-1.4.0.jar
-rw-r–r–. 1 root root 16052 Apr 1 13:34 jt-bandcombine-1.0.9.jar
-rw-r–r–. 1 root root 33911 Apr 1 13:34 jt-bandmerge-1.0.9.jar
-rw-r–r–. 1 root root 8477 Apr 1 13:34 jt-bandselect-1.0.9.jar
-rw-r–r–. 1 root root 14196 Apr 1 13:34 jt-binarize-1.0.9.jar
-rw-r–r–. 1 root root 13683 Apr 1 13:34 jt-border-1.0.9.jar
-rw-r–r–. 1 root root 18964 Apr 1 13:34 jt-buffer-1.0.9.jar
-rw-r–r–. 1 root root 18778 Apr 1 13:34 jt-classifier-1.0.9.jar
-rw-r–r–. 1 root root 64473 Apr 1 13:34 jt-colorconvert-1.0.9.jar
-rw-r–r–. 1 root root 38698 Apr 1 13:34 jt-colorindexer-1.0.9.jar
-rw-r–r–. 1 root root 20682 Apr 11 10:01 jt-concurrent-tile-cache-1.0.9.jar
-rw-r–r–. 1 root root 26019 Aug 26 2015 jt-contour-1.4.0.jar
-rw-r–r–. 1 root root 9840 Apr 1 13:34 jt-crop-1.0.9.jar
-rw-r–r–. 1 root root 18401 Apr 1 13:34 jt-errordiffusion-1.0.9.jar
-rw-r–r–. 1 root root 7110 Apr 1 13:34 jt-format-1.0.9.jar
-rw-r–r–. 1 root root 12696 Apr 1 13:34 jt-imagefunction-1.0.9.jar
-rw-r–r–. 1 root root 24170 Apr 1 13:34 jt-iterators-1.0.9.jar
-rw-r–r–. 1 root root 39688 Apr 1 13:34 jt-lookup-1.0.9.jar
-rw-r–r–. 1 root root 31245 Apr 1 13:34 jt-mosaic-1.0.9.jar
-rw-r–r–. 1 root root 7018 Apr 1 13:34 jt-nullop-1.0.9.jar
-rw-r–r–. 1 root root 25802 Apr 1 13:34 jt-orderdither-1.0.9.jar
-rw-r–r–. 1 root root 36758 Apr 1 13:34 jt-piecewise-1.0.9.jar
-rw-r–r–. 1 root root 16779 Aug 26 2015 jt-rangelookup-1.4.0.jar
-rw-r–r–. 1 root root 19233 Apr 1 13:34 jt-rescale-1.0.9.jar
-rw-r–r–. 1 root root 18290 Apr 1 13:34 jt-rlookup-1.0.9.jar
-rw-r–r–. 1 root root 794991 Sep 12 2013 jts-1.13.jar
-rw-r–r–. 1 root root 89274 Apr 1 13:34 jt-scale-1.0.9.jar
-rw-r–r–. 1 root root 34648 Apr 1 13:34 jt-stats-1.0.9.jar
-rw-r–r–. 1 root root 9981 Apr 1 13:34 jt-translate-1.0.9.jar
-rw-r–r–. 1 root root 117852 Apr 1 13:34 jt-utilities-1.0.9.jar
-rw-r–r–. 1 root root 202267 Aug 26 2015 jt-utils-1.4.0.jar
-rw-r–r–. 1 root root 19124 Apr 1 13:34 jt-vectorbin-1.0.9.jar
-rw-r–r–. 1 root root 10574 Aug 26 2015 jt-vectorbinarize-1.4.0.jar
-rw-r–r–. 1 root root 14229 Aug 26 2015 jt-vectorize-1.4.0.jar
-rw-r–r–. 1 root root 65330 Apr 1 13:34 jt-warp-1.0.9.jar
-rw-r–r–. 1 root root 32813 Apr 1 13:34 jt-zonal-1.0.9.jar
-rw-r–r–. 1 root root 19970 Aug 26 2015 jt-zonalstats-1.4.0.jar
-rw-r–r–. 1 root root 571 Sep 18 2013 LICENSE.txt
-rw-r–r–. 1 root root 489884 Apr 29 17:45 log4j-1.2.17.jar
-rw-r–r–. 1 root root 388864 Sep 16 2013 mail-1.4.jar
-rw-r–r–. 1 root root 231977 May 2 20:20 net.opengis.fes-15-RC1.jar
-rw-r–r–. 1 root root 532372 May 2 20:20 net.opengis.ows-15-RC1.jar
-rw-r–r–. 1 root root 661862 May 2 20:21 net.opengis.wcs-15-RC1.jar
-rw-r–r–. 1 root root 429390 May 2 20:20 net.opengis.wfs-15-RC1.jar
-rw-r–r–. 1 root root 48752 Sep 16 2013 org.json-2.0.jar
-rw-r–r–. 1 root root 175177 Sep 12 2013 org.restlet-1.0.8.jar
-rw-r–r–. 1 root root 2180 Sep 12 2013 org.restlet.ext.freemarker-1.0.8.jar
-rw-r–r–. 1 root root 1730 Sep 16 2013 org.restlet.ext.json-1.0.8.jar
-rw-r–r–. 1 root root 4504 Sep 12 2013 org.restlet.ext.spring-1.0.8.jar
-rw-r–r–. 1 root root 225333 Sep 16 2013 org.simpleframework-3.1.3.jar
-rw-r–r–. 1 root root 53222 May 2 20:20 org.w3.xlink-15-RC1.jar
-rw-r–r–. 1 root root 112635 Sep 12 2013 picocontainer-1.2.jar
-rw-r–r–. 1 root root 142870 Oct 14 2013 pngj-2.0.1.jar
-rw-r–r–. 1 root root 648487 Jun 10 2015 postgresql-9.4-1201-jdbc41.jar
-rw-r–r–. 1 root root 566 Jan 23 02:21 README.TXT
-rw-r–r–. 1 root root 25962 Sep 16 2013 slf4j-api-1.6.4.jar
-rw-r–r–. 1 root root 9748 Sep 16 2013 slf4j-log4j12-1.6.4.jar
-rw-r–r–. 1 root root 370067 Mar 23 20:52 spring-aop-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 731562 Mar 23 20:52 spring-beans-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1096773 Mar 23 20:52 spring-context-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 176774 Mar 23 22:00 spring-context-support-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1078771 Mar 23 20:52 spring-core-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 262988 Mar 23 20:52 spring-expression-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 423659 Mar 23 20:52 spring-jdbc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 374411 Mar 23 21:59 spring-ldap-core-2.0.2.RELEASE.jar
-rw-r–r–. 1 root root 473345 Mar 23 20:54 spring-security-config-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 357254 Mar 23 20:54 spring-security-core-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 103988 Mar 23 21:58 spring-security-ldap-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 326872 Mar 23 20:54 spring-security-web-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 265523 Mar 23 20:52 spring-tx-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 767232 Mar 23 20:52 spring-web-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 876937 Mar 23 20:52 spring-webmvc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 179346 Sep 16 2013 stax-1.2.0.jar
-rw-r–r–. 1 root root 26514 Sep 12 2013 stax-api-1.0.1.jar
-rw-r–r–. 1 root root 2198941 Jan 23 03:14 wicket-core-7.1.0.jar
-rw-r–r–. 1 root root 1274149 Jan 23 03:14 wicket-extensions-7.1.0.jar
-rw-r–r–. 1 root root 87937 Jan 23 03:14 wicket-request-7.1.0.jar
-rw-r–r–. 1 root root 376657 Jan 23 03:14 wicket-util-7.1.0.jar
-rw-r–r–. 1 root root 220536 May 7 2015 xml-apis-1.4.01.jar
-rw-r–r–. 1 root root 85686 Sep 16 2013 xml-apis-ext-1.3.04.jar
-rw-r–r–. 1 root root 84091 Sep 16 2013 xml-commons-resolver-1.2.jar
-rw-r–r–. 1 root root 7188 Sep 12 2013 xmlpull-1.1.3.1.jar
-rw-r–r–. 1 root root 119888 Sep 12 2013 xpp3-1.1.3.4.O.jar
-rw-r–r–. 1 root root 24956 Sep 12 2013 xpp3_min-1.1.4c.jar
-rw-r–r–. 1 root root 992820 Sep 12 2013 xsd-2.6.0.jar
-rw-r–r–. 1 root root 531571 Feb 23 2014 xstream-1.4.7.jar
Hi Curtis,
You already said that the log doesn’t report any error.
When GeoServer starts with GDAL jars in place, it should log one of these 2 messages (depending on native libs availability/unavailability).
When successfully loaded:
GDAL Native Library loaded (version: 1.9.2)
When missing:
Failed to load the GDAL native libs. This is not a problem
unless you need to use the GDAL plugins: they won’t be enabled
( *it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path)*
Do your log contains one of them?
Which logging level did you setup in GeoServer?
You may consider raising it to check if something more is logged.
Please, let us know.
Daniele
On Fri, May 27, 2016 at 2:24 AM, Curtis Mack <curtis.mack@anonymised.com> wrote:
Supported Formats:
ELAS (rw+v): ELAS
DIPEx (rov): DIPEx
ACE2 (rov): ACE2
ls -l $GDAL_DATA
total 2672
total 65184
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
-rw-r--r--. 1 root root 321652 May 3 10:19
Did you mean to extract the files in this archive to the WEB-INF/lib
directory of your GeoServer installation?
Also, what does the javainfo -formats command show?
Brad
Thanks for the reply Daniele,
I had the default logging level set, and a clean restart showed no reference to GDAL in the log.
What logging level do you suggest?
I turned my logging level to “Verbose” and restarted.
I did not see any of the nicely formatted messages you mention, but I did find this.
2016-05-27 13:45:50,390 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2016-05-27 13:45:50,392 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
2016-05-27 13:45:50,417 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2016-05-27 13:45:50,418 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2016-05-27 13:45:50,420 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2016-05-27 13:45:50,421 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2016-05-27 13:45:50,421 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2016-05-27 13:45:50,422 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2016-05-27 13:45:50,422 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
Here is the entire verbose boot log:
2016-05-27 14:40:51,099 DEBUG [geoserver.logging] - FINISHED CONFIGURING GEOSERVER LOGGING -------------------------
2016-05-27 14:40:51,101 INFO [context.ContextLoader] - Root WebApplicationContext: initialization started
2016-05-27 14:40:51,967 INFO [support.XmlWebApplicationContext] - Refreshing Root WebApplicationContext: startup date [Fri May 27 14:40:51 PDT 2016]; root of context hierarchy
2016-05-27 14:40:52,233 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gdal-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:52,452 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:52,524 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]
2016-05-27 14:40:52,615 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-servlet.xml]
2016-05-27 14:40:52,643 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-core-context.xml]
2016-05-27 14:40:52,711 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-georss-context.xml]
2016-05-27 14:40:52,741 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-gmaps-context.xml]
2016-05-27 14:40:52,799 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-kmlservice-context.xml]
2016-05-27 14:40:52,829 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-rest-context.xml]
2016-05-27 14:40:52,890 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-tmsservice-context.xml]
2016-05-27 14:40:52,928 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-virtualearth-context.xml]
2016-05-27 14:40:52,953 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-wmsservice-context.xml]
2016-05-27 14:40:53,007 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-wmtsservice-context.xml]
2016-05-27 14:40:53,033 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-diskquota-context.xml]
2016-05-27 14:40:53,066 INFO [support.DefaultListableBeanFactory] - Overriding bean definition for bean ‘gwcFacade’ with a different definition: replacing [Generic bean: class [org.geoserver.gwc.GWC]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]] with [Generic bean: class [org.geoserver.gwc.GWC]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]]
2016-05-27 14:40:53,086 INFO [support.DefaultListableBeanFactory] - Overriding bean definition for bean ‘gwcInitializer’ with a different definition: replacing [Generic bean: class [org.geoserver.gwc.config.GWCInitializer]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]] with [Generic bean: class [org.geoserver.gwc.config.GWCInitializer]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]]
2016-05-27 14:40:53,088 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-kml-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,134 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,194 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-rest-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,221 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-restconfig-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,283 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-sec-jdbc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,290 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-sec-ldap-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,316 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,353 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs1_0-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,383 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs1_1-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,411 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs2_0-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,459 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-core-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,493 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-demo-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,520 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-gwc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,556 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-rest-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,580 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-core-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,605 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-jdbc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,638 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-ldap-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,645 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wcs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,675 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wfs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,695 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wms-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,716 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wfs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,783 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wms-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,845 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/applicationSecurityContext.xml]
2016-05-27 14:40:54,405 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-restconfig-2.9-RC1.jar!/applicationSecurityContext.xml]
2016-05-27 14:40:56,560 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceStore’ of type [class org.geoserver.platform.resource.ResourceStoreFactory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,579 TRACE [geoserver.platform] - No resourceStoreImpl beans found, falling back to DataDirectoryResourceStore
2016-05-27 14:40:56,580 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘nullLockProvider’ of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,586 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘lockProvider’ of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,611 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:40:56,612 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘dataDirectoryResourceStore’ of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,612 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceStore’ of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,704 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:40:56,705 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceLoader’ of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,903 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceGMapsProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,905 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceMGMapsProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,906 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceKMLProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,907 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceTMSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,921 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceVEProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,923 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceWMSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,923 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceWMTSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,926 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs100Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,927 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs111Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,961 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs20Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,974 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘authenticatedAuthorizer’ of type [class org.springframework.beans.factory.config.FieldRetrievingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,975 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘workspaceAdminAuthorizer’ of type [class org.springframework.beans.factory.config.FieldRetrievingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,976 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsService’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,977 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsService20’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,094 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsSqlViewKvpParser’ of type [class org.geoserver.ows.kvp.ViewParamsKvpParser] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,115 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘org.springframework.beans.factory.config.MethodInvokingFactoryBean#0’ of type [class org.springframework.beans.factory.config.MethodInvokingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,117 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wmsService2’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,118 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘extensions’ of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,219 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘dataDirectory’ of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,449 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘geoJSONPGetFeatureResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,450 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jsonPDescribeFeatureTypeResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,450 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘geoJSONPFeatureInfoResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,451 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jsonPDescribeLayerResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,464 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wmsSVGStrategyExclusionFilter’ of type [class org.geoserver.wms.svg.SVGStrategyExclusionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,466 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsXStreamPersisterInitializer’ of type [class org.geoserver.wfs.WFSXStreamPersisterInitializer] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,534 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jdbcSecurityProvider’ of type [class org.geoserver.security.jdbc.JDBCSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,560 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘ldapSecurityProvider’ of type [class org.geoserver.security.ldap.LDAPSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,563 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘xmlSecurityProvider’ of type [class org.geoserver.security.xml.XMLSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,564 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘j2eeSecurityProvider’ of type [class org.geoserver.security.impl.J2eeSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,581 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘basicAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerBasicAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,584 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘digestAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerDigestAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,585 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘roleFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRoleProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,587 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘sslFilterProvider’ of type [class org.geoserver.security.filter.GeoServerSSLProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,604 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘j2eeAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerJ2eeAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,606 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘requestHeaderFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRequestHeaderAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,607 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘exceptionTranslationFilterProvider’ of type [class org.geoserver.security.filter.GeoServerExceptionTranslationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,609 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘usernamePasswordFilterProvider’ of type [class org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,623 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘x509FilterProvider’ of type [class org.geoserver.security.filter.GeoServerX509CertificateAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,626 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘contextPersistenceProvider’ of type [class org.geoserver.security.filter.GeoServerSecurityContextPersistenceProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,628 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘rememberMeFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRememberMeAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,630 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘anonymousFilterProvider’ of type [class org.geoserver.security.filter.GeoServerAnonymousAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,632 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘logoutFilterProvider’ of type [class org.geoserver.security.filter.GeoServerLogoutProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,647 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘securityInterceptorFilterProvider’ of type [class org.geoserver.security.filter.GeoServerSecurityInterceptorProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,651 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘credentialsFromRequestHeaderSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerCredentialsFromRequestHeaderProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,655 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘urlMasterPasswordProvider’ of type [class org.geoserver.security.password.URLMasterPasswordProvider$SecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,739 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘authenticationManager’ of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:58,317 INFO [org.geoserver] - Loaded style ‘poi’
2016-05-27 14:40:58,343 INFO [org.geoserver] - Loaded style ‘grass’
2016-05-27 14:40:58,348 INFO [org.geoserver] - Loaded style ‘population’
2016-05-27 14:40:58,351 INFO [org.geoserver] - Loaded style ‘dem’
2016-05-27 14:40:58,365 INFO [org.geoserver] - Loaded style ‘restricted’
2016-05-27 14:40:58,369 INFO [org.geoserver] - Loaded style ‘pophatch’
2016-05-27 14:40:58,374 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2016-05-27 14:40:58,381 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2016-05-27 14:40:58,386 INFO [org.geoserver] - Loaded style ‘raster’
2016-05-27 14:40:58,401 INFO [org.geoserver] - Loaded style ‘generic’
2016-05-27 14:40:58,415 INFO [org.geoserver] - Loaded style ‘simple_streams’
2016-05-27 14:40:58,421 INFO [org.geoserver] - Loaded style ‘burg’
2016-05-27 14:40:58,426 INFO [org.geoserver] - Loaded style ‘green’
2016-05-27 14:40:58,430 INFO [org.geoserver] - Loaded style ‘capitals’
2016-05-27 14:40:58,435 INFO [org.geoserver] - Loaded style ‘polygon’
2016-05-27 14:40:58,452 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2016-05-27 14:40:58,455 INFO [org.geoserver] - Loaded style ‘point’
2016-05-27 14:40:58,460 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2016-05-27 14:40:58,478 INFO [org.geoserver] - Loaded style ‘simple_roads’
2016-05-27 14:40:58,482 INFO [org.geoserver] - Loaded style ‘line’
2016-05-27 14:40:58,487 INFO [org.geoserver] - Loaded style ‘rain’
2016-05-27 14:40:58,526 INFO [org.geoserver] - Loaded default workspace pdmp
2016-05-27 14:40:58,547 INFO [org.geoserver] - Loaded workspace ‘pdmp’
2016-05-27 14:40:58,572 INFO [org.geoserver] - Loaded style ‘BlueYellowRedColors7’
2016-05-27 14:40:58,965 INFO [org.geoserver] - Loaded store ‘anyrisk_pop’, enabled
2016-05-27 14:40:58,988 INFO [org.geoserver] - Loaded coverage store ‘anyrisk_pop’
2016-05-27 14:40:59,070 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:40:59,160 TRACE [geotools.resources] - Loaded resources for English from bundle “org.geotools.resources.i18n”.
2016-05-27 14:40:59,232 INFO [geotools.factory] - Factory implementations for category CRSFactory:
org.geotools.referencing.factory.ReferencingObjectFactory
2016-05-27 14:40:59,244 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:40:59,244 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:40:59,251 INFO [geotools.factory] - Factory implementations for category DatumFactory:
org.geotools.referencing.factory.DatumAliases
2016-05-27 14:40:59,252 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:40:59,252 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:40:59,277 INFO [geotools.factory] - Factory implementations for category MathTransformFactory:
org.geotools.referencing.operation.DefaultMathTransformFactory
2016-05-27 14:40:59,278 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:40:59,501 DEBUG [referencing.factory] - Loading datum aliases from “jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gt-referencing-15-RC1.jar!/org/geotools/referencing/factory/DatumAliasesTable.txt”.
2016-05-27 14:41:00,170 INFO [geotools.factory] - Factory implementations for category MathTransformProvider:
org.geotools.referencing.operation.projection.Mercator1SPGoogle$Provider
org.geotools.referencing.operation.transform.LogarithmicTransform1D$Provider
org.geotools.referencing.operation.transform.ExponentialTransform1D$Provider
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderAffine
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderLongitudeRotation
org.geotools.referencing.operation.transform.GeocentricTranslation$Provider
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderSevenParam
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderFrameRotation
org.geotools.referencing.operation.transform.GeocentricTransform$Provider
org.geotools.referencing.operation.transform.GeocentricTransform$ProviderInverse
org.geotools.referencing.operation.transform.MolodenskiTransform$Provider
org.geotools.referencing.operation.transform.MolodenskiTransform$ProviderAbridged
org.geotools.referencing.operation.transform.NADCONTransform$Provider
org.geotools.referencing.operation.transform.NTv2Transform$Provider
org.geotools.referencing.operation.transform.SimilarityTransformProvider
org.geotools.referencing.operation.transform.WarpTransform2D$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$SphericalProvider
org.geotools.referencing.operation.projection.PlateCarree$Provider
org.geotools.referencing.operation.projection.Mercator1SP$Provider
org.geotools.referencing.operation.projection.Mercator2SP$Provider
org.geotools.referencing.operation.projection.MercatorPseudoProvider
org.geotools.referencing.operation.projection.TransverseMercator$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider_SouthOrientated
org.geotools.referencing.operation.projection.ObliqueMercator$Provider
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_TwoPoint
org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider
org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider_TwoPoint
org.geotools.referencing.operation.projection.AlbersEqualArea$Provider
org.geotools.referencing.operation.projection.LambertConformal1SP$Provider
org.geotools.referencing.operation.projection.LambertConformal2SP$Provider
org.geotools.referencing.operation.projection.LambertConformalBelgium$Provider
org.geotools.referencing.operation.projection.LambertAzimuthalEqualArea$Provider
org.geotools.referencing.operation.projection.Orthographic$Provider
org.geotools.referencing.operation.projection.Stereographic$Provider
org.geotools.referencing.operation.projection.ObliqueStereographic$Provider
org.geotools.referencing.operation.projection.PolarStereographic$ProviderA
org.geotools.referencing.operation.projection.PolarStereographic$ProviderB
org.geotools.referencing.operation.projection.PolarStereographic$ProviderNorth
org.geotools.referencing.operation.projection.PolarStereographic$ProviderSouth
org.geotools.referencing.operation.projection.NewZealandMapGrid$Provider
org.geotools.referencing.operation.projection.Krovak$Provider
org.geotools.referencing.operation.projection.CassiniSoldner$Provider
org.geotools.referencing.operation.projection.EquidistantConic$Provider
org.geotools.referencing.operation.projection.Polyconic$Provider
org.geotools.referencing.operation.projection.Robinson$Provider
org.geotools.referencing.operation.projection.WinkelTripel$WinkelProvider
org.geotools.referencing.operation.projection.WinkelTripel$AitoffProvider
org.geotools.referencing.operation.projection.EckertIV$Provider
org.geotools.referencing.operation.projection.Mollweide$MollweideProvider
org.geotools.referencing.operation.projection.Mollweide$WagnerIVProvider
org.geotools.referencing.operation.projection.Gnomonic$Provider
org.geotools.referencing.operation.projection.WorldVanDerGrintenI$Provider
org.geotools.referencing.operation.projection.Sinusoidal$Provider
org.geotools.referencing.operation.projection.GeneralOblique$Provider
org.geotools.referencing.operation.projection.MeteosatSG$Provider
org.geotools.referencing.operation.projection.GeostationarySatellite$Provider
org.geotools.referencing.operation.projection.RotatedPole$Provider
2016-05-27 14:41:00,549 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,551 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:41:00,551 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:41:00,552 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:41:00,552 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:41:00,552 TRACE [geotools.factory] - ENTRY (CSFactory, CS_FACTORY)
2016-05-27 14:41:00,554 INFO [geotools.factory] - Factory implementations for category CSFactory:
2016-05-27 14:41:00,555 TRACE [geotools.factory] - RETURN (CSFactory, CS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:00,570 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:41:00,570 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:00,571 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,574 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,574 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,621 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,621 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,622 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:00,624 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,625 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,625 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:00,625 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,626 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,652 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,652 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,712 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,713 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,717 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,718 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,782 INFO [geotools.factory] - Factory implementations for category CRSAuthorityFactory:
org.vfny.geoserver.crs.GeoserverCustomWKTFactory
org.vfny.geoserver.crs.GeoserverOverridingWKTFactory
org.geotools.referencing.factory.epsg.FactoryUsingWKT
org.geotools.referencing.factory.epsg.LongitudeFirstFactory
org.geotools.referencing.factory.epsg.CartesianAuthorityFactory
org.geotools.referencing.factory.wms.AutoCRSFactory
org.geotools.referencing.factory.wms.WebCRSFactory
org.geotools.referencing.factory.URN_AuthorityFactory
org.geotools.referencing.factory.HTTP_AuthorityFactory
org.geotools.referencing.factory.HTTP_URI_AuthorityFactory
org.geotools.referencing.factory.epsg.LongitudeFirstEpsgDecorator
2016-05-27 14:41:00,790 INFO [referencing.factory] - Using “file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/org/vfny/geoserver/crs/override_epsg.properties” as EPSG factory.
2016-05-27 14:41:00,815 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:00,816 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:00,816 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] ThreadedEpsgFactory.
2016-05-27 14:41:00,829 DEBUG [factory.epsg] - Building new data source for org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
2016-05-27 14:41:00,865 DEBUG [factory.epsg] - Building backing store for org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
2016-05-27 14:41:00,879 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,880 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:03,217 INFO [referencing.factory] - Connected to EPSG database “jdbc:hsqldb:file:/usr/share/apache-tomcat-7.0.68/temp/Geotools/Databases/HSQL/v8.6.0.0/EPSG;shutdown=true;readonly=true” on “HSQL Database Engine”.
2016-05-27 14:41:03,290 TRACE [geotools.factory] - RETURN (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): found implementation ThreadedHsqlEpsgFactory.
2016-05-27 14:41:03,320 TRACE [geotools.resources] - Loaded resources for English from bundle “org.geotools.resources.i18n”.
2016-05-27 14:41:03,409 INFO [referencing.factory] - Using “/var/lib/geoserver_data/user_projections/epsg.properties” as EPSG factory.
2016-05-27 14:41:03,424 DEBUG [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
2016-05-27 14:41:03,429 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:03,429 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:03,429 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:03,430 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:03,448 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:03,448 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:03,449 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:03,449 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:03,475 DEBUG [referencing.factory] - Failure in the primary factory: No code “EPSG:2927” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”. Now trying the fallback factory…
2016-05-27 14:41:04,192 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:04,192 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:04,216 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:41:04,216 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:04,327 INFO [org.geoserver] - Loaded coverage ‘anyrisk_pop’, enabled
2016-05-27 14:41:04,357 INFO [org.geoserver] - Loaded coverage ‘anyrisk_pop’
2016-05-27 14:41:04,568 DEBUG [gce.imagemosaic] - Unable to load kakadu JPEG2000 reader spi
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2k.JP2KKakaduImageReaderSpi
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1858)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1701)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.geotools.gce.imagemosaic.ImageMosaicFormatFactory.hasJP2Kakadu(ImageMosaicFormatFactory.java:185)
at org.geotools.gce.imagemosaic.ImageMosaicFormatFactory.(ImageMosaicFormatFactory.java:63)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
at org.geotools.factory.FactoryRegistry.register(FactoryRegistry.java:826)
at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:772)
at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:750)
at org.geotools.coverage.grid.io.GridFormatFinder.scanForPlugins(GridFormatFinder.java:122)
at org.geotools.coverage.grid.io.GridFormatFinder.getAvailableFormats(GridFormatFinder.java:85)
at org.geotools.coverage.grid.io.GridFormatFinder.getFormatArray(GridFormatFinder.java:144)
at org.geoserver.data.util.CoverageStoreUtils.(CoverageStoreUtils.java:45)
at org.geoserver.catalog.ResourcePool.getGridCoverageFormat(ResourcePool.java:1626)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getFormat(CoverageStoreInfoImpl.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:147)
at com.sun.proxy.$Proxy11.getFormat(Unknown Source)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1385)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1342)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1337)
at org.geoserver.wms.WMSValidator.validate(WMSValidator.java:45)
at org.geoserver.catalog.impl.CatalogImpl$CatalogValidatorVisitor.visit(CatalogImpl.java:1724)
at org.geoserver.catalog.impl.LayerInfoImpl.accept(LayerInfoImpl.java:237)
at org.geoserver.catalog.impl.CatalogImpl.postValidate(CatalogImpl.java:1675)
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:690)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:622)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:437)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:223)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:109)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:140)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1143)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:296)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5068)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5584)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1091)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1980)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2016-05-27 14:41:04,602 INFO [geotools.factory] - Factory implementations for category GridFormatFactorySpi:
org.geotools.gce.arcgrid.ArcGridFormatFactory
org.geotools.gce.geotiff.GeoTiffFormatFactorySpi
org.geotools.gce.gtopo30.GTopo30FormatFactory
org.geotools.gce.image.WorldImageFormatFactory
org.geotools.coverageio.gdal.mrsid.MrSIDFormatFactory
org.geotools.coverageio.gdal.jp2kak.JP2KFormatFactory
org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDFormatFactory
org.geotools.coverageio.gdal.jp2ecw.JP2ECWFormatFactory
org.geotools.coverageio.gdal.ecw.ECWFormatFactory
org.geotools.coverageio.gdal.dted.DTEDFormatFactory
org.geotools.coverageio.gdal.erdasimg.ErdasImgFormatFactory
org.geotools.coverageio.gdal.idrisi.IDRISIFormatFactory
org.geotools.coverageio.gdal.nitf.NITFFormatFactory
org.geotools.coverageio.gdal.ehdr.EsriHdrFormatFactory
org.geotools.coverageio.gdal.envihdr.EnviHdrFormatFactory
org.geotools.coverageio.gdal.aig.AIGFormatFactory
org.geotools.coverageio.gdal.rpftoc.RPFTOCFormatFactory
2016-05-27 14:41:04,603 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2016-05-27 14:41:04,603 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2016-05-27 14:41:04,609 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2016-05-27 14:41:04,612 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2016-05-27 14:41:04,613 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2016-05-27 14:41:04,613 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2016-05-27 14:41:04,614 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2016-05-27 14:41:04,614 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
2016-05-27 14:41:04,699 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
2016-05-27 14:41:05,412 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:41:05,413 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:41:05,413 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:41:05,413 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:41:05,417 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,417 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,418 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,418 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,420 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,421 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,421 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,422 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,439 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,439 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,440 INFO [geotools.factory] - Factory implementations for category CSAuthorityFactory:
2016-05-27 14:41:05,442 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,442 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,442 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,443 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,445 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,446 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,446 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,447 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,447 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,447 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,448 INFO [geotools.factory] - Factory implementations for category DatumAuthorityFactory:
2016-05-27 14:41:05,449 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,465 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,465 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,466 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,473 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,474 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,475 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,488 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,488 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,489 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,490 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,490 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,490 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,491 INFO [geotools.factory] - Factory implementations for category CoordinateOperationAuthorityFactory:
org.vfny.geoserver.crs.GeoserverWKTOperationFactory
org.geotools.referencing.factory.epsg.CoordinateOperationFactoryUsingWKT
2016-05-27 14:41:05,492 INFO [referencing.factory] - user_projections/epsg_operations.properties was not found, using the default set of coordinate operation overrides (normally empty)
2016-05-27 14:41:05,494 INFO [referencing.factory] - Using “file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/org/vfny/geoserver/crs/epsg_operations.properties” as EPSG factory.
2016-05-27 14:41:05,497 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,498 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,498 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,498 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,519 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,520 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,520 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,520 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,522 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,524 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,542 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,545 DEBUG [referencing.factory] - Failure in the primary factory: No code “EPSG:4269” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”. Now trying the fallback factory…
2016-05-27 14:41:05,767 DEBUG [imageio.geotiff] - Logging tiePoints:
Tie point
Raster Space point (0.0, 0.0, 0.0)
Model Space point (-2.8629725402267642E7, 8514374.688731242, 0.0)
Logging pixScales:
Pixel Scale
scaleX=1000.0 is set? true
scaleY=1000.0 is set? true
scaleZ=0.0 is set? false
2016-05-27 14:41:05,833 INFO [org.geoserver] - Loaded layer ‘anyrisk_pop’
2016-05-27 14:41:06,439 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:06,529 INFO [config.XMLFileResourceProvider] - Found configuration file in gwc
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - ********************************************************************************
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
2016-05-27 14:41:07,196 DEBUG [grid.GridSetBroker] - Adding EPSG:4326
2016-05-27 14:41:07,205 DEBUG [grid.GridSetBroker] - Adding EPSG:900913 grid set for Spherical Mercator / GoogleMapsCompatible
2016-05-27 14:41:07,205 DEBUG [grid.GridSetBroker] - Adding GlobalCRS84Pixel
2016-05-27 14:41:07,206 DEBUG [grid.GridSetBroker] - Adding GlobalCRS84Scale
2016-05-27 14:41:07,206 DEBUG [grid.GridSetBroker] - Adding GoogleCRS84Quad
2016-05-27 14:41:07,317 DEBUG [layer.TileLayerDispatcher] - Thread initLayers(), initializing
2016-05-27 14:41:07,317 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2016-05-27 14:41:07,318 INFO [gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
2016-05-27 14:41:07,320 INFO [gwc.layer] - Loading tile layers from gwc-layers
2016-05-27 14:41:07,320 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:07,399 DEBUG [gwc.layer] - Loaded tile layer ‘pdmp:anyrisk_pop’
2016-05-27 14:41:07,507 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:07,538 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2016-05-27 14:41:07,539 DEBUG [layer.TileLayerDispatcher] - Reading service information.
2016-05-27 14:41:07,539 INFO [config.XMLConfiguration] - Initializing GridSets from gwc
2016-05-27 14:41:07,539 INFO [config.XMLConfiguration] - Initializing layers from gwc
2016-05-27 14:41:07,539 INFO [layer.TileLayerDispatcher] - Configuration gwc contained no layers.
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - Java environment variable GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - Servlet context parameter GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - System environment variable GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,579 DEBUG [storage.DefaultStorageFinder] - Java environment variable GEOSERVER_DATA_DIR is unset
2016-05-27 14:41:07,579 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************
2016-05-27 14:41:07,579 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /var/lib/geoserver_data, using it as the default prefix. ***
2016-05-27 14:41:07,600 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,606 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,606 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Configuring Expire After Access eviction policy
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Configuring Scheduled Task for cache eviction
2016-05-27 14:41:07,705 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,706 DEBUG [memory.MemoryBlobStore] - Setting cache provided
2016-05-27 14:41:07,706 DEBUG [memory.MemoryBlobStore] - CacheProvider already configured
2016-05-27 14:41:07,710 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,710 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,710 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,790 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:07,834 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
2016-05-27 14:41:07,896 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
2016-05-27 14:41:07,902 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2016-05-27 14:41:07,902 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2016-05-27 14:41:07,903 INFO [diskquota.DiskQuotaMonitor] - 1 layers attached to global quota 500.0 MB
2016-05-27 14:41:07,968 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2016-05-27 14:41:07,972 DEBUG [diskquota.DiskQuotaMonitor] - pdmp:anyrisk_pop has no saved used quota information,traversing layer cache to compute its disk usage.
2016-05-27 14:41:08,718 INFO [geotools.image] - Warp/affine reduction enabled: true
2016-05-27 14:41:08,915 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wcs’, available services were
2016-05-27 14:41:08,931 INFO [org.geoserver] - Loaded service ‘wcs’, disabled
2016-05-27 14:41:09,004 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wfs’, available services were [WCSInfoImpl[WCS]]
2016-05-27 14:41:09,018 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2016-05-27 14:41:09,069 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wms’, available services were [WCSInfoImpl[WCS], WFSInfoImpl[WFS]]
2016-05-27 14:41:09,077 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2016-05-27 14:41:09,127 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2016-05-27 14:41:09,153 DEBUG [gwc.config] - GWC GeoServer specific configuration loaded from gwc-gs.xml
2016-05-27 14:41:09,153 DEBUG [guava.GuavaCacheProvider] - Reset Cache internally
2016-05-27 14:41:09,154 DEBUG [guava.GuavaCacheProvider] - Flushing cache
2016-05-27 14:41:09,154 DEBUG [guava.GuavaCacheProvider] - Removing Layers
2016-05-27 14:41:09,176 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:09,177 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:09,186 INFO [image.jai] - Native acceleration disabled for “Mosaic” operation.
2016-05-27 14:41:09,206 INFO [image.jai] - Native acceleration disabled for “Warp” operation.
2016-05-27 14:41:09,583 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler ‘dispatcher’
2016-05-27 14:41:09,692 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2016-05-27 14:41:09,762 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2016-05-27 14:41:09,877 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2016-05-27 14:41:10,098 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 15 paths
2016-05-27 14:41:10,146 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/rest/**] onto handler ‘gwcRestDispatcher’
2016-05-27 14:41:10,195 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2016-05-27 14:41:10,195 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2016-05-27 14:41:10,298 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/**] onto handler ‘geowebcacheDispatcher’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/demo/**] onto handler ‘geowebcacheDispatcher’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/proxy/**] onto handler ‘gwcProxyDispatcher’
2016-05-27 14:41:14,606 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2016-05-27 14:41:14,640 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2016-05-27 14:41:14,640 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon/**/*] onto handler ‘kmlIconService’
2016-05-27 14:41:15,073 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:41:15,177 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler ‘dispatcher’
2016-05-27 14:41:15,177 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2016-05-27 14:41:15,197 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/styles/**] onto handler ‘filePublisher’
2016-05-27 14:41:15,197 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/www/**] onto handler ‘filePublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/schemas/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/j_acegi_security_check] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/login] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/j_spring_security_check] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,245 INFO [org.geoserver] - GeoServer configuration lock is enabled
2016-05-27 14:41:15,737 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/rest] onto handler ‘restWrapper’
2016-05-27 14:41:15,737 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/rest/**] onto handler ‘restWrapper’
2016-05-27 14:41:15,746 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2016-05-27 14:41:15,746 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
2016-05-27 14:41:16,766 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/temp/**] onto handler ‘filePublisher’
2016-05-27 14:41:16,822 INFO [concurrent.ScheduledExecutorFactoryBean] - Initializing ExecutorService ‘wcs111timerFactory’
2016-05-27 14:41:19,689 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2016-05-27 14:41:19,701 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
2016-05-27 14:41:19,701 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2016-05-27 14:41:20,188 DEBUG [geotools.xml] - building schema for schema: http://www.opengis.net/gml/3.2
2016-05-27 14:41:31,753 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2016-05-27 14:41:31,753 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
2016-05-27 14:41:31,840 TRACE [geotools.factory] - ENTRY (GridCoverageFactory)
2016-05-27 14:41:31,840 TRACE [geotools.factory] - RETURN (GridCoverageFactory): found implementation GridCoverageFactory.
2016-05-27 14:41:31,988 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
2016-05-27 14:41:31,989 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/openlayers/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/options.png] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/openlayers3/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,299 INFO [context.ContextLoader] - Root WebApplicationContext: initialization completed in 41198 ms
2016-05-27 14:41:33,517 INFO [geoserver.security] - Start reloading user/groups for service named default
2016-05-27 14:41:33,523 INFO [geoserver.security] - Reloading user/groups successful for service named default
2016-05-27 14:41:34,282 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7628…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7629…, org.geoserver.security.filter.GeoServerRememberMeAuthenticationFilter@…7630…, org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter@…7631…, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@…7632…, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@…7633…, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@…7634…]
2016-05-27 14:41:34,287 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7635…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7636…, org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter@…7637…]
2016-05-27 14:41:34,330 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7638…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7639…, org.geoserver.security.filter.GeoServerLogoutFilter@…7640…]
2016-05-27 14:41:34,403 DEBUG [security.RESTfulDefinitionSource] - Line 1: /**:GET=ADMIN
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET firstColonIndex= 3
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /:GET antPath= / methods= GET
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - methodList = [GET]
2016-05-27 14:41:34,406 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [GET]
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - Line 1: /**:POST,DELETE,PUT=ADMIN
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT firstColonIndex= 3
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /:POST,DELETE,PUT antPath= / methods= POST,DELETE,PUT
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - methodList = [POST, DELETE, PUT]
2016-05-27 14:41:34,407 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [POST, DELETE, PUT]
2016-05-27 14:41:34,408 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7641…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7642…, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@…7643…, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@…7644…, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@…7645…, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@…7646…]
2016-05-27 14:41:34,437 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7647…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7648…, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@…7649…, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@…7650…, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@…7651…]
2016-05-27 14:41:34,443 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@…7652…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@…7653…, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@…7654…, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@…7655…, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@…7656…, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@…7657…]
2016-05-27 14:41:34,469 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
2016-05-27 14:41:34,481 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - AuthenticationCache removing all entries
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - Cache entries #: 0
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - AuthenticationCache removed all entries
2016-05-27 14:44:13,398 INFO [servlet.DispatcherServlet] - FrameworkServlet ‘dispatcher’: initialization started
2016-05-27 14:44:13,417 INFO [support.XmlWebApplicationContext] - Refreshing WebApplicationContext for namespace ‘dispatcher-servlet’: startup date [Fri May 27 14:44:13 PDT 2016]; parent: Root WebApplicationContext
2016-05-27 14:44:13,420 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from ServletContext resource [/WEB-INF/dispatcher-servlet.xml]
2016-05-27 14:44:14,147 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web] onto handler ‘wicket’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/index.html] onto handler ‘filePublisher’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web/**] onto handler ‘wicket’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Root mapping to handler ‘filePublisher’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web/resources/**] onto handler ‘wicket’
2016-05-27 14:44:14,494 INFO [servlet.DispatcherServlet] - FrameworkServlet ‘dispatcher’: initialization completed in 1096 ms
2016-05-27 14:44:14,590 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/, QueryString: null’; against ‘/web/**’
2016-05-27 14:44:14,602 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2016-05-27 14:44:15,479 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,480 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,494 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,707 DEBUG [org.geoserver] - Thread 31 locking in mode READ
2016-05-27 14:44:15,707 DEBUG [org.geoserver] - Thread 31 got the lock in mode READ
2016-05-27 14:44:18,024 DEBUG [geoserver.security] - Bad credentials
org.springframework.security.authentication.BadCredentialsException: Bad credentials
at org.springframework.security.authentication.dao.DaoAuthenticationProvider.additionalAuthenticationChecks(DaoAuthenticationProvider.java:98)
at org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:165)
at org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:82)
at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1478)
at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.(SecurityHomePageContentProvider.java:105)
at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
at org.apache.wicket.Component.beforeRender(Component.java:1017)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
at org.apache.wicket.Page.onBeforeRender(Page.java:801)
at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
at org.apache.wicket.Component.render(Component.java:2304)
at org.apache.wicket.Page.renderPage(Page.java:1018)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1078)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
2016-05-27 14:44:18,395 INFO [geoserver.security] - Strong cryptography is available
From: dany.geotools@…84… [mailto:dany.geotools@…84…] On Behalf Of Daniele Romagnoli
Sent: Friday, May 27, 2016 12:49 AM
To: Curtis Mack
Subject: Re: [Geoserver-users] GDAL Extention installed, but formats not showing on the list of options
Hi Curtis,
You already said that the log doesn’t report any error.
When GeoServer starts with GDAL jars in place, it should log one of these 2 messages (depending on native libs availability/unavailability).
When successfully loaded:
GDAL Native Library loaded (version: 1.9.2)
When missing:
Failed to load the GDAL native libs. This is not a problem
unless you need to use the GDAL plugins: they won’t be enabled
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path)
Do your log contains one of them?
Which logging level did you setup in GeoServer?
You may consider raising it to check if something more is logged.
Please, let us know.
Daniele
On Fri, May 27, 2016 at 2:24 AM, Curtis Mack <curtis.mack@…7620…> wrote:
I have a new Centos7 server with Geoserver 2.9-RC1 installed as a Web Archive. I have followed the instructions on http://docs.geoserver.org/latest/en/user/data/raster/gdal.html but am not seeing the GDAL Image Formats on the “New data source” menu. I see no errors in the log. Any help would be appreciated.
Here is some supporting info.
I believe I have GDAL-native setup correctly.
I can run “gdalinfo –version” and it returns “GDAL 1.9.2, released 2012/10/08”.
I run ” /opt/gdal192-CentOS5.8/javainfo/gdalinfo.sh –formats” and get the following.
Supported Formats:
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (rov): Raster Product Format TOC format
ECRGTOC (rov): ECRG TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (rov): CEOS SAR Image
CEOS (rov): CEOS Image
JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+v): ELAS
AIG (rov): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
SDTS (rov): SDTS Raster
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (rov): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (rov): Maptech BSB Nautical Charts
XPM (rwv): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (rov): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
PDS (rov): NASA Planetary Data System
TIL (rov): EarthWatch .TIL
ERS (rw+v): ERMapper .ers Labelled
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
L1B (rov): NOAA Polar Orbiter Level 1b Data Set
FIT (rwv): FIT Image
MrSID (rov): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (rov): MrSID JPEG2000
RMF (rw+v): Raster Matrix Format
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+v): Idrisi Raster A.1
INGR (rw+v): Intergraph Raster
GSAG (rwv): Golden Software ASCII Grid (.grd)
GSBG (rw+v): Golden Software Binary Grid (.grd)
GS7BG (rov): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (rov): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+v): Portable Pixmap Format (netpbm)
DOQ1 (rov): USGS DOQ (Old Style)
DOQ2 (rov): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (rov): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (rov): GSC Geogrid
FAST (rov): EOSAT FAST Format
BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
LAN (rw+v): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (rov): NLAPS Data Format
EIR (rov): Erdas Imagine Raw
DIPEx (rov): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
GTX (rw+v): NOAA Vertical Datum .GTX
LOSLAS (rov): NADCON .los/.las Datum Grid Shift
NTv2 (rw+v): NTv2 Datum Grid Shift
ACE2 (rov): ACE2
SNODAS (rov): Snow Data Assimilation System
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
KMLSUPEROVERLAY (rwv): Kml Super Overlay
XYZ (rwv): ASCII Gridded XYZ
HF2 (rwv): HF2/HFZ heightfield raster
OZI (rov): OziExplorer Image File
CTG (rov): USGS LULC Composite Theme Grid
E00GRID (rov): Arc/Info Export E00 GRID
ZMap (rwv): ZMap Plus Grid
NGSGEOID (rov): NOAA NGS Geoid Height Grids
Usage: gdalinfo [–help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-norat] [-noct] [-mdd domain]* [-checksum] datasetname
I have the data files installed:
ls -l $GDAL_DATA
total 2672
-rwxr-xr-x. 1 root root 1882 Jan 1 2012 compdcs.csv
-rwxr-xr-x. 1 root root 7195 Jan 1 2012 coordinate_axis.csv
-rwxr-xr-x. 1 root root 12025 Jan 1 2012 cubewerx_extra.wkt
-rwxr-xr-x. 1 root root 158260 Jan 1 2012 datum_shift.csv
-rwxr-xr-x. 1 root root 364766 Jan 1 2012 ecw_cs.wkt
-rwxr-xr-x. 1 root root 13898 Jan 1 2012 ellipsoid.csv
-rwxr-xr-x. 1 root root 52 Jan 1 2012 epsg.wkt
-rwxr-xr-x. 1 root root 209629 Jan 1 2012 esri_extra.wkt
-rwxr-xr-x. 1 root root 332546 Jan 1 2012 esri_StatePlane_extra.wkt
-rwxr-xr-x. 1 root root 75845 Jan 1 2012 esri_Wisconsin_extra.wkt
-rwxr-xr-x. 1 root root 49247 Jan 1 2012 gcs.csv
-rwxr-xr-x. 1 root root 513 Jan 1 2012 gcs.override.csv
-rwxr-xr-x. 1 root root 186320 Jan 1 2012 gdal_datum.csv
-rwxr-xr-x. 1 root root 13224 Jan 1 2012 GDALLogoBW.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoColor.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoGS.svg
-rwxr-xr-x. 1 root root 10033 Jan 1 2012 geoccs.csv
-rwxr-xr-x. 1 root root 15804 Jan 1 2012 gt_datum.csv
-rwxr-xr-x. 1 root root 1719 Jan 1 2012 gt_ellips.csv
-rwxr-xr-x. 1 root root 9120 Jan 1 2012 header.dxf
-rwxr-xr-x. 1 root root 60387 Jan 1 2012 nitf_spec.xml
-rwxr-xr-x. 1 root root 6144 Jan 1 2012 nitf_spec.xsd
-rwxr-xr-x. 1 root root 35009 Jan 1 2012 pci_datum.txt
-rwxr-xr-x. 1 root root 3466 Jan 1 2012 pci_ellips.txt
-rwxr-xr-x. 1 root root 566127 Jan 1 2012 pcs.csv
-rwxr-xr-x. 1 root root 1525 Jan 1 2012 pcs.override.csv
-rwxr-xr-x. 1 root root 1664 Jan 1 2012 prime_meridian.csv
-rwxr-xr-x. 1 root root 206531 Jan 1 2012 projop_wparm.csv
-rwxr-xr-x. 1 root root 13553 Jan 1 2012 s57agencies.csv
-rwxr-xr-x. 1 root root 18555 Jan 1 2012 s57attributes_aml.csv
-rwxr-xr-x. 1 root root 7452 Jan 1 2012 s57attributes.csv
-rwxr-xr-x. 1 root root 8981 Jan 1 2012 s57attributes_iw.csv
-rwxr-xr-x. 1 root root 21893 Jan 1 2012 s57expectedinput.csv
-rwxr-xr-x. 1 root root 64289 Jan 1 2012 s57objectclasses_aml.csv
-rwxr-xr-x. 1 root root 31408 Jan 1 2012 s57objectclasses.csv
-rwxr-xr-x. 1 root root 37247 Jan 1 2012 s57objectclasses_iw.csv
-rwxr-xr-x. 1 root root 9216 Jan 1 2012 seed_2d.dgn
-rwxr-xr-x. 1 root root 2048 Jan 1 2012 seed_3d.dgn
-rwxr-xr-x. 1 root root 10619 Jan 1 2012 stateplane.csv
-rwxr-xr-x. 1 root root 12071 Jan 1 2012 trailer.dxf
-rwxr-xr-x. 1 root root 18941 Jan 1 2012 unit_of_measure.csv
-rwxr-xr-x. 1 root root 8152 Jan 1 2012 vertcs.csv
-rwxr-xr-x. 1 root root 908 Jan 1 2012 vertcs.override.csv
ls -l /usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib
total 65184
-rw-r–r–. 1 root root 62983 Sep 16 2013 activation-1.1.jar
-rw-r–r–. 1 root root 4467 Sep 12 2013 aopalliance-1.0.jar
-rw-r–r–. 1 root root 95313 Sep 16 2013 batik-anim-1.7.jar
-rw-r–r–. 1 root root 401858 Sep 16 2013 batik-awt-util-1.7.jar
-rw-r–r–. 1 root root 558892 Sep 16 2013 batik-bridge-1.7.jar
-rw-r–r–. 1 root root 310919 Sep 16 2013 batik-css-1.7.jar
-rw-r–r–. 1 root root 173530 Sep 16 2013 batik-dom-1.7.jar
-rw-r–r–. 1 root root 10257 Sep 16 2013 batik-ext-1.7.jar
-rw-r–r–. 1 root root 242866 Sep 16 2013 batik-gvt-1.7.jar
-rw-r–r–. 1 root root 504741 Sep 16 2013 batik-js-1.7.jar
-rw-r–r–. 1 root root 73119 Sep 16 2013 batik-parser-1.7.jar
-rw-r–r–. 1 root root 60604 Sep 16 2013 batik-script-1.7.jar
-rw-r–r–. 1 root root 601098 Sep 16 2013 batik-svg-dom-1.7.jar
-rw-r–r–. 1 root root 215274 Sep 16 2013 batik-svggen-1.7.jar
-rw-r–r–. 1 root root 121997 Sep 16 2013 batik-transcoder-1.7.jar
-rw-r–r–. 1 root root 128286 Sep 16 2013 batik-util-1.7.jar
-rw-r–r–. 1 root root 30843 Sep 16 2013 batik-xml-1.7.jar
-rw-r–r–. 1 root root 1824421 Sep 12 2013 bcprov-jdk14-1.46.jar
-rw-r–r–. 1 root root 322362 Sep 16 2013 cglib-nodep-2.2.jar
-rw-r–r–. 1 root root 211652 Sep 12 2013 common-2.6.0.jar
-rw-r–r–. 1 root root 188671 Sep 12 2013 commons-beanutils-1.7.0.jar
-rw-r–r–. 1 root root 263965 Mar 21 2014 commons-codec-1.9.jar
-rw-r–r–. 1 root root 588337 Mar 24 08:25 commons-collections-3.2.2.jar
-rw-r–r–. 1 root root 160519 Dec 22 2013 commons-dbcp-1.4.jar
-rw-r–r–. 1 root root 57779 Sep 12 2013 commons-fileupload-1.2.1.jar
-rw-r–r–. 1 root root 305001 Sep 12 2013 commons-httpclient-3.1.jar
-rw-r–r–. 1 root root 163151 Sep 12 2013 commons-io-2.1.jar
-rw-r–r–. 1 root root 299994 Sep 12 2013 commons-jxpath-1.3.jar
-rw-r–r–. 1 root root 284220 Nov 9 2013 commons-lang-2.6.jar
-rw-r–r–. 1 root root 60686 Sep 12 2013 commons-logging-1.1.1.jar
-rw-r–r–. 1 root root 96203 Sep 16 2013 commons-pool-1.5.3.jar
-rw-r–r–. 1 root root 150629 Sep 12 2013 com.noelios.restlet-1.0.8.jar
-rw-r–r–. 1 root root 14072 Sep 12 2013 com.noelios.restlet.ext.servlet-1.0.8.jar
-rw-r–r–. 1 root root 10114 Sep 16 2013 com.noelios.restlet.ext.simple-1.0.8.jar
-rw-r–r–. 1 root root 342540 May 10 2015 core-0.26.jar
-rw-r–r–. 1 root root 1231403 Sep 12 2013 ecore-2.6.1.jar
-rw-r–r–. 1 root root 203035 Sep 12 2013 ehcache-1.6.2.jar
-rw-r–r–. 1 root root 37176 Sep 16 2013 encoder-1.1.jar
-rw-r–r–. 1 root root 86487 Sep 12 2013 ezmorph-1.0.6.jar
-rw-r–r–. 1 root root 924269 Sep 12 2013 freemarker-2.3.18.jar
-rw-r–r–. 1 root root 31693 Aug 28 2015 GeographicLib-Java-1.44.jar
-rw-r–r–. 1 root root 321652 May 3 10:19 geoserver-2.9-RC1-gdal-plugin.zip
-rw-r–r–. 1 root root 2564 May 3 17:15 gs-gdal-2.9-RC1.jar
-rw-r–r–. 1 root root 194137 May 3 17:11 gs-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 181456 May 3 17:11 gs-kml-2.9-RC1.jar
-rw-r–r–. 1 root root 1824051 May 3 17:10 gs-main-2.9-RC1.jar
-rw-r–r–. 1 root root 170214 May 3 17:09 gs-ows-2.9-RC1.jar
-rw-r–r–. 1 root root 115740 May 3 17:09 gs-platform-2.9-RC1.jar
-rw-r–r–. 1 root root 64502 May 3 17:11 gs-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 266528 May 3 17:11 gs-restconfig-2.9-RC1.jar
-rw-r–r–. 1 root root 57595 May 3 17:10 gs-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 46399 May 3 17:10 gs-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 116478 May 3 17:10 gs-wcs1_0-2.9-RC1.jar
-rw-r–r–. 1 root root 144135 May 3 17:10 gs-wcs1_1-2.9-RC1.jar
-rw-r–r–. 1 root root 432798 May 3 17:10 gs-wcs2_0-2.9-RC1.jar
-rw-r–r–. 1 root root 46004 May 3 17:10 gs-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 1425896 May 3 17:11 gs-web-core-2.9-RC1.jar
-rw-r–r–. 1 root root 374083 May 3 17:12 gs-web-demo-2.9-RC1.jar
-rw-r–r–. 1 root root 367266 May 3 17:11 gs-web-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 4422 May 3 17:12 gs-web-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 561505 May 3 17:12 gs-web-sec-core-2.9-RC1.jar
-rw-r–r–. 1 root root 23204 May 3 17:12 gs-web-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 21131 May 3 17:12 gs-web-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 76073 May 3 17:12 gs-web-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 36944 May 3 17:11 gs-web-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 157306 May 3 17:11 gs-web-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 686071 May 3 17:10 gs-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 958309 May 3 17:11 gs-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 207878 May 2 20:17 gt-api-15-RC1.jar
-rw-r–r–. 1 root root 13977 May 2 20:24 gt-app-schema-resolver-15-RC1.jar
-rw-r–r–. 1 root root 23927 May 2 20:19 gt-arcgrid-15-RC1.jar
-rw-r–r–. 1 root root 59903 May 2 20:24 gt-complex-15-RC1.jar
-rw-r–r–. 1 root root 585183 May 2 20:19 gt-coverage-15-RC1.jar
-rw-r–r–. 1 root root 197346 May 2 20:19 gt-cql-15-RC1.jar
-rw-r–r–. 1 root root 88409 May 2 20:19 gt-data-15-RC1.jar
-rw-r–r–. 1 root root 2330229 May 2 20:18 gt-epsg-hsql-15-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 20:25 gt-geojson-15-RC1.jar
-rw-r–r–. 1 root root 31173 May 2 20:19 gt-geotiff-15-RC1.jar
-rw-r–r–. 1 root root 170468 May 2 20:18 gt-graph-15-RC1.jar
-rw-r–r–. 1 root root 35024 May 2 20:24 gt-grid-15-RC1.jar
-rw-r–r–. 1 root root 38722 May 2 20:22 gt-gtopo30-15-RC1.jar
-rw-r–r–. 1 root root 22658 May 2 20:22 gt-image-15-RC1.jar
-rw-r–r–. 1 root root 79294 May 3 17:15 gt-imageio-ext-gdal-15-RC1.jar
-rw-r–r–. 1 root root 374650 May 2 20:22 gt-imagemosaic-15-RC1.jar
-rw-r–r–. 1 root root 219685 May 2 20:21 gt-jdbc-15-RC1.jar
-rw-r–r–. 1 root root 50882 May 2 20:22 gt-jdbc-postgis-15-RC1.jar
-rw-r–r–. 1 root root 1753607 May 2 20:18 gt-main-15-RC1.jar
-rw-r–r–. 1 root root 510990 May 2 20:17 gt-metadata-15-RC1.jar
-rw-r–r–. 1 root root 351036 May 2 20:17 gt-opengis-15-RC1.jar
-rw-r–r–. 1 root root 59087 May 2 20:25 gt-process-15-RC1.jar
-rw-r–r–. 1 root root 176741 May 2 20:25 gt-process-feature-15-RC1.jar
-rw-r–r–. 1 root root 120766 May 2 20:26 gt-process-raster-15-RC1.jar
-rw-r–r–. 1 root root 24551 May 2 20:19 gt-property-15-RC1.jar
-rw-r–r–. 1 root root 1180650 May 2 20:17 gt-referencing-15-RC1.jar
-rw-r–r–. 1 root root 565938 May 2 20:20 gt-render-15-RC1.jar
-rw-r–r–. 1 root root 219407 May 2 20:19 gt-shapefile-15-RC1.jar
-rw-r–r–. 1 root root 9015 May 2 20:23 gt-svg-15-RC1.jar
-rw-r–r–. 1 root root 40093 May 2 20:22 gt-transform-15-RC1.jar
-rw-r–r–. 1 root root 243470 May 2 20:25 gt-wfs-ng-15-RC1.jar
-rw-r–r–. 1 root root 230688 May 2 20:24 gt-wms-15-RC1.jar
-rw-r–r–. 1 root root 651627 May 2 20:21 gt-xml-15-RC1.jar
-rw-r–r–. 1 root root 313002 May 2 20:18 gt-xsd-core-15-RC1.jar
-rw-r–r–. 1 root root 69559 May 2 20:20 gt-xsd-fes-15-RC1.jar
-rw-r–r–. 1 root root 106563 May 2 20:20 gt-xsd-filter-15-RC1.jar
-rw-r–r–. 1 root root 117409 May 2 20:19 gt-xsd-gml2-15-RC1.jar
-rw-r–r–. 1 root root 1553765 May 2 20:19 gt-xsd-gml3-15-RC1.jar
-rw-r–r–. 1 root root 121602 May 2 20:20 gt-xsd-ows-15-RC1.jar
-rw-r–r–. 1 root root 176648 May 2 20:20 gt-xsd-sld-15-RC1.jar
-rw-r–r–. 1 root root 177013 May 2 20:24 gt-xsd-wcs-15-RC1.jar
-rw-r–r–. 1 root root 148574 May 2 20:20 gt-xsd-wfs-15-RC1.jar
-rw-r–r–. 1 root root 2243036 Jun 3 2014 guava-17.0.jar
-rw-r–r–. 1 root root 570913 May 2 21:44 gwc-core-1.9-RC1.jar
-rw-r–r–. 1 root root 92133 May 2 21:46 gwc-diskquota-core-1.9-RC1.jar
-rw-r–r–. 1 root root 54352 May 2 21:46 gwc-diskquota-jdbc-1.9-RC1.jar
-rw-r–r–. 1 root root 35777 May 2 21:46 gwc-georss-1.9-RC1.jar
-rw-r–r–. 1 root root 8627 May 2 21:46 gwc-gmaps-1.9-RC1.jar
-rw-r–r–. 1 root root 21829 May 2 21:46 gwc-kml-1.9-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 21:46 gwc-rest-1.9-RC1.jar
-rw-r–r–. 1 root root 10648 May 2 21:46 gwc-tms-1.9-RC1.jar
-rw-r–r–. 1 root root 5493 May 2 21:46 gwc-ve-1.9-RC1.jar
-rw-r–r–. 1 root root 62487 May 2 21:46 gwc-wms-1.9-RC1.jar
-rw-r–r–. 1 root root 20021 May 2 21:46 gwc-wmts-1.9-RC1.jar
-rw-r–r–. 1 root root 1207393 Sep 12 2013 h2-1.1.119.jar
-rw-r–r–. 1 root root 1466946 May 25 2015 hsqldb-2.3.0.jar
-rw-r–r–. 1 root root 39860 Nov 6 2015 imageio-ext-arcgrid-1.1.13.jar
-rw-r–r–. 1 root root 5151 May 3 17:15 imageio-ext-gdalarcbinarygrid-1.1.13.jar
-rw-r–r–. 1 root root 94016 May 3 17:15 imageio-ext-gdal-bindings-1.9.2.jar
-rw-r–r–. 1 root root 4938 May 3 17:15 imageio-ext-gdaldted-1.1.13.jar
-rw-r–r–. 1 root root 8106 May 3 17:15 imageio-ext-gdalecw-1.1.13.jar
-rw-r–r–. 1 root root 5083 May 3 17:15 imageio-ext-gdalecwjp2-1.1.13.jar
-rw-r–r–. 1 root root 4939 May 3 17:15 imageio-ext-gdalehdr-1.1.13.jar
-rw-r–r–. 1 root root 5037 May 3 17:15 imageio-ext-gdalenvihdr-1.1.13.jar
-rw-r–r–. 1 root root 5033 May 3 17:15 imageio-ext-gdalerdasimg-1.1.13.jar
-rw-r–r–. 1 root root 57744 May 3 17:15 imageio-ext-gdalframework-1.1.13.jar
-rw-r–r–. 1 root root 5006 May 3 17:15 imageio-ext-gdalidrisi-1.1.13.jar
-rw-r–r–. 1 root root 14978 May 3 17:15 imageio-ext-gdalkakadujp2-1.1.13.jar
-rw-r–r–. 1 root root 8703 May 3 17:15 imageio-ext-gdalmrsid-1.1.13.jar
-rw-r–r–. 1 root root 5129 May 3 17:15 imageio-ext-gdalmrsidjp2-1.1.13.jar
-rw-r–r–. 1 root root 4928 May 3 17:15 imageio-ext-gdalnitf-1.1.13.jar
-rw-r–r–. 1 root root 4981 May 3 17:15 imageio-ext-gdalrpftoc-1.1.13.jar
-rw-r–r–. 1 root root 26688 May 3 17:15 imageio-ext-geocore-1.1.13.jar
-rw-r–r–. 1 root root 26911 May 3 17:15 imageio-ext-imagereadmt-1.1.13.jar
-rw-r–r–. 1 root root 19493 Nov 10 2015 imageio-ext-png-1.1.13.jar
-rw-r–r–. 1 root root 52275 Nov 6 2015 imageio-ext-streams-1.1.13.jar
-rw-r–r–. 1 root root 335165 Nov 6 2015 imageio-ext-tiff-1.1.13.jar
-rw-r–r–. 1 root root 40586 Nov 6 2015 imageio-ext-utilities-1.1.13.jar
-rw-r–r–. 1 root root 1117661 Sep 16 2013 itext-2.1.5.jar
-rw-r–r–. 1 root root 258160 Sep 12 2013 jai_codec-1.1.3.jar
-rw-r–r–. 1 root root 1900631 Sep 12 2013 jai_core-1.1.3.jar
-rw-r–r–. 1 root root 1140632 Sep 12 2013 jai_imageio-1.1.jar
-rw-r–r–. 1 root root 178961 Sep 12 2013 jasypt-1.8.jar
-rw-r–r–. 1 root root 619507 Sep 16 2013 JavaAPIforKml-2.2.0.jar
-rw-r–r–. 1 root root 151304 Sep 29 2013 jdom-1.1.3.jar
-rw-r–r–. 1 root root 56702 Sep 12 2013 jettison-1.0.1.jar
-rw-r–r–. 1 root root 11497 Sep 12 2013 jgridshift-1.0.jar
-rw-r–r–. 1 root root 148490 Sep 12 2013 json-lib-2.2.3-jdk15.jar
-rw-r–r–. 1 root root 16046 Sep 16 2013 json-simple-1.1.jar
-rw-r–r–. 1 root root 91347 Sep 12 2013 jsr-275-1.0-beta-2.jar
-rw-r–r–. 1 root root 33031 Jun 9 2014 jsr305-2.0.3.jar
-rw-r–r–. 1 root root 117361 Apr 1 13:34 jt-affine-1.0.9.jar
-rw-r–r–. 1 root root 62676 Apr 1 13:34 jt-algebra-1.0.9.jar
-rw-r–r–. 1 root root 3839 Aug 26 2015 jt-attributeop-1.4.0.jar
-rw-r–r–. 1 root root 16052 Apr 1 13:34 jt-bandcombine-1.0.9.jar
-rw-r–r–. 1 root root 33911 Apr 1 13:34 jt-bandmerge-1.0.9.jar
-rw-r–r–. 1 root root 8477 Apr 1 13:34 jt-bandselect-1.0.9.jar
-rw-r–r–. 1 root root 14196 Apr 1 13:34 jt-binarize-1.0.9.jar
-rw-r–r–. 1 root root 13683 Apr 1 13:34 jt-border-1.0.9.jar
-rw-r–r–. 1 root root 18964 Apr 1 13:34 jt-buffer-1.0.9.jar
-rw-r–r–. 1 root root 18778 Apr 1 13:34 jt-classifier-1.0.9.jar
-rw-r–r–. 1 root root 64473 Apr 1 13:34 jt-colorconvert-1.0.9.jar
-rw-r–r–. 1 root root 38698 Apr 1 13:34 jt-colorindexer-1.0.9.jar
-rw-r–r–. 1 root root 20682 Apr 11 10:01 jt-concurrent-tile-cache-1.0.9.jar
-rw-r–r–. 1 root root 26019 Aug 26 2015 jt-contour-1.4.0.jar
-rw-r–r–. 1 root root 9840 Apr 1 13:34 jt-crop-1.0.9.jar
-rw-r–r–. 1 root root 18401 Apr 1 13:34 jt-errordiffusion-1.0.9.jar
-rw-r–r–. 1 root root 7110 Apr 1 13:34 jt-format-1.0.9.jar
-rw-r–r–. 1 root root 12696 Apr 1 13:34 jt-imagefunction-1.0.9.jar
-rw-r–r–. 1 root root 24170 Apr 1 13:34 jt-iterators-1.0.9.jar
-rw-r–r–. 1 root root 39688 Apr 1 13:34 jt-lookup-1.0.9.jar
-rw-r–r–. 1 root root 31245 Apr 1 13:34 jt-mosaic-1.0.9.jar
-rw-r–r–. 1 root root 7018 Apr 1 13:34 jt-nullop-1.0.9.jar
-rw-r–r–. 1 root root 25802 Apr 1 13:34 jt-orderdither-1.0.9.jar
-rw-r–r–. 1 root root 36758 Apr 1 13:34 jt-piecewise-1.0.9.jar
-rw-r–r–. 1 root root 16779 Aug 26 2015 jt-rangelookup-1.4.0.jar
-rw-r–r–. 1 root root 19233 Apr 1 13:34 jt-rescale-1.0.9.jar
-rw-r–r–. 1 root root 18290 Apr 1 13:34 jt-rlookup-1.0.9.jar
-rw-r–r–. 1 root root 794991 Sep 12 2013 jts-1.13.jar
-rw-r–r–. 1 root root 89274 Apr 1 13:34 jt-scale-1.0.9.jar
-rw-r–r–. 1 root root 34648 Apr 1 13:34 jt-stats-1.0.9.jar
-rw-r–r–. 1 root root 9981 Apr 1 13:34 jt-translate-1.0.9.jar
-rw-r–r–. 1 root root 117852 Apr 1 13:34 jt-utilities-1.0.9.jar
-rw-r–r–. 1 root root 202267 Aug 26 2015 jt-utils-1.4.0.jar
-rw-r–r–. 1 root root 19124 Apr 1 13:34 jt-vectorbin-1.0.9.jar
-rw-r–r–. 1 root root 10574 Aug 26 2015 jt-vectorbinarize-1.4.0.jar
-rw-r–r–. 1 root root 14229 Aug 26 2015 jt-vectorize-1.4.0.jar
-rw-r–r–. 1 root root 65330 Apr 1 13:34 jt-warp-1.0.9.jar
-rw-r–r–. 1 root root 32813 Apr 1 13:34 jt-zonal-1.0.9.jar
-rw-r–r–. 1 root root 19970 Aug 26 2015 jt-zonalstats-1.4.0.jar
-rw-r–r–. 1 root root 571 Sep 18 2013 LICENSE.txt
-rw-r–r–. 1 root root 489884 Apr 29 17:45 log4j-1.2.17.jar
-rw-r–r–. 1 root root 388864 Sep 16 2013 mail-1.4.jar
-rw-r–r–. 1 root root 231977 May 2 20:20 net.opengis.fes-15-RC1.jar
-rw-r–r–. 1 root root 532372 May 2 20:20 net.opengis.ows-15-RC1.jar
-rw-r–r–. 1 root root 661862 May 2 20:21 net.opengis.wcs-15-RC1.jar
-rw-r–r–. 1 root root 429390 May 2 20:20 net.opengis.wfs-15-RC1.jar
-rw-r–r–. 1 root root 48752 Sep 16 2013 org.json-2.0.jar
-rw-r–r–. 1 root root 175177 Sep 12 2013 org.restlet-1.0.8.jar
-rw-r–r–. 1 root root 2180 Sep 12 2013 org.restlet.ext.freemarker-1.0.8.jar
-rw-r–r–. 1 root root 1730 Sep 16 2013 org.restlet.ext.json-1.0.8.jar
-rw-r–r–. 1 root root 4504 Sep 12 2013 org.restlet.ext.spring-1.0.8.jar
-rw-r–r–. 1 root root 225333 Sep 16 2013 org.simpleframework-3.1.3.jar
-rw-r–r–. 1 root root 53222 May 2 20:20 org.w3.xlink-15-RC1.jar
-rw-r–r–. 1 root root 112635 Sep 12 2013 picocontainer-1.2.jar
-rw-r–r–. 1 root root 142870 Oct 14 2013 pngj-2.0.1.jar
-rw-r–r–. 1 root root 648487 Jun 10 2015 postgresql-9.4-1201-jdbc41.jar
-rw-r–r–. 1 root root 566 Jan 23 02:21 README.TXT
-rw-r–r–. 1 root root 25962 Sep 16 2013 slf4j-api-1.6.4.jar
-rw-r–r–. 1 root root 9748 Sep 16 2013 slf4j-log4j12-1.6.4.jar
-rw-r–r–. 1 root root 370067 Mar 23 20:52 spring-aop-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 731562 Mar 23 20:52 spring-beans-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1096773 Mar 23 20:52 spring-context-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 176774 Mar 23 22:00 spring-context-support-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1078771 Mar 23 20:52 spring-core-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 262988 Mar 23 20:52 spring-expression-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 423659 Mar 23 20:52 spring-jdbc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 374411 Mar 23 21:59 spring-ldap-core-2.0.2.RELEASE.jar
-rw-r–r–. 1 root root 473345 Mar 23 20:54 spring-security-config-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 357254 Mar 23 20:54 spring-security-core-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 103988 Mar 23 21:58 spring-security-ldap-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 326872 Mar 23 20:54 spring-security-web-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 265523 Mar 23 20:52 spring-tx-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 767232 Mar 23 20:52 spring-web-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 876937 Mar 23 20:52 spring-webmvc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 179346 Sep 16 2013 stax-1.2.0.jar
-rw-r–r–. 1 root root 26514 Sep 12 2013 stax-api-1.0.1.jar
-rw-r–r–. 1 root root 2198941 Jan 23 03:14 wicket-core-7.1.0.jar
-rw-r–r–. 1 root root 1274149 Jan 23 03:14 wicket-extensions-7.1.0.jar
-rw-r–r–. 1 root root 87937 Jan 23 03:14 wicket-request-7.1.0.jar
-rw-r–r–. 1 root root 376657 Jan 23 03:14 wicket-util-7.1.0.jar
-rw-r–r–. 1 root root 220536 May 7 2015 xml-apis-1.4.01.jar
-rw-r–r–. 1 root root 85686 Sep 16 2013 xml-apis-ext-1.3.04.jar
-rw-r–r–. 1 root root 84091 Sep 16 2013 xml-commons-resolver-1.2.jar
-rw-r–r–. 1 root root 7188 Sep 12 2013 xmlpull-1.1.3.1.jar
-rw-r–r–. 1 root root 119888 Sep 12 2013 xpp3-1.1.3.4.O.jar
-rw-r–r–. 1 root root 24956 Sep 12 2013 xpp3_min-1.1.4c.jar
-rw-r–r–. 1 root root 992820 Sep 12 2013 xsd-2.6.0.jar
-rw-r–r–. 1 root root 531571 Feb 23 2014 xstream-1.4.7.jar
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hi Curtis,
I would also check your’s Tomcat catalina log.
Daniele
On Fri, May 27, 2016 at 11:51 PM, Curtis Mack <curtis.mack@anonymised.com> wrote:
Thanks for the reply Daniele,
I had the default logging level set, and a clean restart showed no reference to GDAL in the log.
What logging level do you suggest?
I turned my logging level to “Verbose” and restarted.
I did not see any of the nicely formatted messages you mention, but I did find this.
2016-05-27 13:45:50,390 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2016-05-27 13:45:50,391 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2016-05-27 13:45:50,392 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
2016-05-27 13:45:50,417 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2016-05-27 13:45:50,418 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2016-05-27 13:45:50,420 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2016-05-27 13:45:50,421 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2016-05-27 13:45:50,421 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2016-05-27 13:45:50,422 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2016-05-27 13:45:50,422 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
Here is the entire verbose boot log:
2016-05-27 14:40:51,099 DEBUG [geoserver.logging] - FINISHED CONFIGURING GEOSERVER LOGGING -------------------------
2016-05-27 14:40:51,101 INFO [context.ContextLoader] - Root WebApplicationContext: initialization started
2016-05-27 14:40:51,967 INFO [support.XmlWebApplicationContext] - Refreshing Root WebApplicationContext: startup date [Fri May 27 14:40:51 PDT 2016]; root of context hierarchy
2016-05-27 14:40:52,233 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gdal-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:52,452 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:52,524 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]
2016-05-27 14:40:52,615 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-servlet.xml]
2016-05-27 14:40:52,643 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-core-context.xml]
2016-05-27 14:40:52,711 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-georss-context.xml]
2016-05-27 14:40:52,741 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-gmaps-context.xml]
2016-05-27 14:40:52,799 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-kmlservice-context.xml]
2016-05-27 14:40:52,829 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-rest-context.xml]
2016-05-27 14:40:52,890 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-tmsservice-context.xml]
2016-05-27 14:40:52,928 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-virtualearth-context.xml]
2016-05-27 14:40:52,953 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-wmsservice-context.xml]
2016-05-27 14:40:53,007 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-wmtsservice-context.xml]
2016-05-27 14:40:53,033 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-diskquota-context.xml]
2016-05-27 14:40:53,066 INFO [support.DefaultListableBeanFactory] - Overriding bean definition for bean ‘gwcFacade’ with a different definition: replacing [Generic bean: class [org.geoserver.gwc.GWC]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]] with [Generic bean: class [org.geoserver.gwc.GWC]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]]
2016-05-27 14:40:53,086 INFO [support.DefaultListableBeanFactory] - Overriding bean definition for bean ‘gwcInitializer’ with a different definition: replacing [Generic bean: class [org.geoserver.gwc.config.GWCInitializer]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/geowebcache-geoserver-context.xml]] with [Generic bean: class [org.geoserver.gwc.config.GWCInitializer]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-gwc-2.9-RC1.jar!/applicationContext.xml]]
2016-05-27 14:40:53,088 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-kml-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,134 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,194 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-rest-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,221 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-restconfig-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,283 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-sec-jdbc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,290 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-sec-ldap-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,316 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,353 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs1_0-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,383 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs1_1-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,411 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wcs2_0-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,459 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-core-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,493 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-demo-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,520 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-gwc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,556 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-rest-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,580 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-core-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,605 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-jdbc-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,638 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-sec-ldap-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,645 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wcs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,675 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wfs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,695 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-web-wms-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,716 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wfs-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,783 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-wms-2.9-RC1.jar!/applicationContext.xml]
2016-05-27 14:40:53,845 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/applicationSecurityContext.xml]
2016-05-27 14:40:54,405 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from URL [jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-restconfig-2.9-RC1.jar!/applicationSecurityContext.xml]
2016-05-27 14:40:56,560 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceStore’ of type [class org.geoserver.platform.resource.ResourceStoreFactory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,579 TRACE [geoserver.platform] - No resourceStoreImpl beans found, falling back to DataDirectoryResourceStore
2016-05-27 14:40:56,580 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘nullLockProvider’ of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,586 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘lockProvider’ of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,611 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:40:56,612 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘dataDirectoryResourceStore’ of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,612 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceStore’ of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,704 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:40:56,705 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘resourceLoader’ of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,903 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceGMapsProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,905 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceMGMapsProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,906 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceKMLProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,907 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceTMSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,921 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceVEProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,923 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceWMSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,923 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘gwcServiceWMTSProxy’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,926 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs100Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,927 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs111Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,961 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wcs20Service’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,974 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘authenticatedAuthorizer’ of type [class org.springframework.beans.factory.config.FieldRetrievingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,975 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘workspaceAdminAuthorizer’ of type [class org.springframework.beans.factory.config.FieldRetrievingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,976 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsService’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:56,977 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsService20’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,094 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsSqlViewKvpParser’ of type [class org.geoserver.ows.kvp.ViewParamsKvpParser] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,115 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘org.springframework.beans.factory.config.MethodInvokingFactoryBean#0’ of type [class org.springframework.beans.factory.config.MethodInvokingFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,117 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wmsService2’ of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,118 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘extensions’ of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,219 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘dataDirectory’ of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,449 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘geoJSONPGetFeatureResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,450 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jsonPDescribeFeatureTypeResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,450 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘geoJSONPFeatureInfoResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,451 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jsonPDescribeLayerResponseEF’ of type [class org.geoserver.wfs.json.JSONPExtensionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,464 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wmsSVGStrategyExclusionFilter’ of type [class org.geoserver.wms.svg.SVGStrategyExclusionFilter] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,466 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘wfsXStreamPersisterInitializer’ of type [class org.geoserver.wfs.WFSXStreamPersisterInitializer] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,534 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘jdbcSecurityProvider’ of type [class org.geoserver.security.jdbc.JDBCSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,560 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘ldapSecurityProvider’ of type [class org.geoserver.security.ldap.LDAPSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,563 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘xmlSecurityProvider’ of type [class org.geoserver.security.xml.XMLSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,564 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘j2eeSecurityProvider’ of type [class org.geoserver.security.impl.J2eeSecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,581 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘basicAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerBasicAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,584 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘digestAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerDigestAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,585 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘roleFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRoleProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,587 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘sslFilterProvider’ of type [class org.geoserver.security.filter.GeoServerSSLProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,604 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘j2eeAuthSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerJ2eeAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,606 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘requestHeaderFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRequestHeaderAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,607 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘exceptionTranslationFilterProvider’ of type [class org.geoserver.security.filter.GeoServerExceptionTranslationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,609 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘usernamePasswordFilterProvider’ of type [class org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,623 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘x509FilterProvider’ of type [class org.geoserver.security.filter.GeoServerX509CertificateAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,626 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘contextPersistenceProvider’ of type [class org.geoserver.security.filter.GeoServerSecurityContextPersistenceProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,628 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘rememberMeFilterProvider’ of type [class org.geoserver.security.filter.GeoServerRememberMeAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,630 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘anonymousFilterProvider’ of type [class org.geoserver.security.filter.GeoServerAnonymousAuthenticationProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,632 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘logoutFilterProvider’ of type [class org.geoserver.security.filter.GeoServerLogoutProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,647 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘securityInterceptorFilterProvider’ of type [class org.geoserver.security.filter.GeoServerSecurityInterceptorProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,651 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘credentialsFromRequestHeaderSecurityProvider’ of type [class org.geoserver.security.filter.GeoServerCredentialsFromRequestHeaderProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,655 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘urlMasterPasswordProvider’ of type [class org.geoserver.security.password.URLMasterPasswordProvider$SecurityProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:57,739 INFO [support.PostProcessorRegistrationDelegate$BeanPostProcessorChecker] - Bean ‘authenticationManager’ of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
2016-05-27 14:40:58,317 INFO [org.geoserver] - Loaded style ‘poi’
2016-05-27 14:40:58,343 INFO [org.geoserver] - Loaded style ‘grass’
2016-05-27 14:40:58,348 INFO [org.geoserver] - Loaded style ‘population’
2016-05-27 14:40:58,351 INFO [org.geoserver] - Loaded style ‘dem’
2016-05-27 14:40:58,365 INFO [org.geoserver] - Loaded style ‘restricted’
2016-05-27 14:40:58,369 INFO [org.geoserver] - Loaded style ‘pophatch’
2016-05-27 14:40:58,374 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2016-05-27 14:40:58,381 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2016-05-27 14:40:58,386 INFO [org.geoserver] - Loaded style ‘raster’
2016-05-27 14:40:58,401 INFO [org.geoserver] - Loaded style ‘generic’
2016-05-27 14:40:58,415 INFO [org.geoserver] - Loaded style ‘simple_streams’
2016-05-27 14:40:58,421 INFO [org.geoserver] - Loaded style ‘burg’
2016-05-27 14:40:58,426 INFO [org.geoserver] - Loaded style ‘green’
2016-05-27 14:40:58,430 INFO [org.geoserver] - Loaded style ‘capitals’
2016-05-27 14:40:58,435 INFO [org.geoserver] - Loaded style ‘polygon’
2016-05-27 14:40:58,452 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2016-05-27 14:40:58,455 INFO [org.geoserver] - Loaded style ‘point’
2016-05-27 14:40:58,460 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2016-05-27 14:40:58,478 INFO [org.geoserver] - Loaded style ‘simple_roads’
2016-05-27 14:40:58,482 INFO [org.geoserver] - Loaded style ‘line’
2016-05-27 14:40:58,487 INFO [org.geoserver] - Loaded style ‘rain’
2016-05-27 14:40:58,526 INFO [org.geoserver] - Loaded default workspace pdmp
2016-05-27 14:40:58,547 INFO [org.geoserver] - Loaded workspace ‘pdmp’
2016-05-27 14:40:58,572 INFO [org.geoserver] - Loaded style ‘BlueYellowRedColors7’
2016-05-27 14:40:58,965 INFO [org.geoserver] - Loaded store ‘anyrisk_pop’, enabled
2016-05-27 14:40:58,988 INFO [org.geoserver] - Loaded coverage store ‘anyrisk_pop’
2016-05-27 14:40:59,070 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:40:59,160 TRACE [geotools.resources] - Loaded resources for English from bundle “org.geotools.resources.i18n”.
2016-05-27 14:40:59,232 INFO [geotools.factory] - Factory implementations for category CRSFactory:
org.geotools.referencing.factory.ReferencingObjectFactory
2016-05-27 14:40:59,244 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:40:59,244 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:40:59,251 INFO [geotools.factory] - Factory implementations for category DatumFactory:
org.geotools.referencing.factory.DatumAliases
2016-05-27 14:40:59,252 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:40:59,252 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:40:59,277 INFO [geotools.factory] - Factory implementations for category MathTransformFactory:
org.geotools.referencing.operation.DefaultMathTransformFactory
2016-05-27 14:40:59,278 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:40:59,501 DEBUG [referencing.factory] - Loading datum aliases from “jar:file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gt-referencing-15-RC1.jar!/org/geotools/referencing/factory/DatumAliasesTable.txt”.
2016-05-27 14:41:00,170 INFO [geotools.factory] - Factory implementations for category MathTransformProvider:
org.geotools.referencing.operation.projection.Mercator1SPGoogle$Provider
org.geotools.referencing.operation.transform.LogarithmicTransform1D$Provider
org.geotools.referencing.operation.transform.ExponentialTransform1D$Provider
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderAffine
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderLongitudeRotation
org.geotools.referencing.operation.transform.GeocentricTranslation$Provider
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderSevenParam
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderFrameRotation
org.geotools.referencing.operation.transform.GeocentricTransform$Provider
org.geotools.referencing.operation.transform.GeocentricTransform$ProviderInverse
org.geotools.referencing.operation.transform.MolodenskiTransform$Provider
org.geotools.referencing.operation.transform.MolodenskiTransform$ProviderAbridged
org.geotools.referencing.operation.transform.NADCONTransform$Provider
org.geotools.referencing.operation.transform.NTv2Transform$Provider
org.geotools.referencing.operation.transform.SimilarityTransformProvider
org.geotools.referencing.operation.transform.WarpTransform2D$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$SphericalProvider
org.geotools.referencing.operation.projection.PlateCarree$Provider
org.geotools.referencing.operation.projection.Mercator1SP$Provider
org.geotools.referencing.operation.projection.Mercator2SP$Provider
org.geotools.referencing.operation.projection.MercatorPseudoProvider
org.geotools.referencing.operation.projection.TransverseMercator$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider_SouthOrientated
org.geotools.referencing.operation.projection.ObliqueMercator$Provider
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_TwoPoint
org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider
org.geotools.referencing.operation.projection.HotineObliqueMercator$Provider_TwoPoint
org.geotools.referencing.operation.projection.AlbersEqualArea$Provider
org.geotools.referencing.operation.projection.LambertConformal1SP$Provider
org.geotools.referencing.operation.projection.LambertConformal2SP$Provider
org.geotools.referencing.operation.projection.LambertConformalBelgium$Provider
org.geotools.referencing.operation.projection.LambertAzimuthalEqualArea$Provider
org.geotools.referencing.operation.projection.Orthographic$Provider
org.geotools.referencing.operation.projection.Stereographic$Provider
org.geotools.referencing.operation.projection.ObliqueStereographic$Provider
org.geotools.referencing.operation.projection.PolarStereographic$ProviderA
org.geotools.referencing.operation.projection.PolarStereographic$ProviderB
org.geotools.referencing.operation.projection.PolarStereographic$ProviderNorth
org.geotools.referencing.operation.projection.PolarStereographic$ProviderSouth
org.geotools.referencing.operation.projection.NewZealandMapGrid$Provider
org.geotools.referencing.operation.projection.Krovak$Provider
org.geotools.referencing.operation.projection.CassiniSoldner$Provider
org.geotools.referencing.operation.projection.EquidistantConic$Provider
org.geotools.referencing.operation.projection.Polyconic$Provider
org.geotools.referencing.operation.projection.Robinson$Provider
org.geotools.referencing.operation.projection.WinkelTripel$WinkelProvider
org.geotools.referencing.operation.projection.WinkelTripel$AitoffProvider
org.geotools.referencing.operation.projection.EckertIV$Provider
org.geotools.referencing.operation.projection.Mollweide$MollweideProvider
org.geotools.referencing.operation.projection.Mollweide$WagnerIVProvider
org.geotools.referencing.operation.projection.Gnomonic$Provider
org.geotools.referencing.operation.projection.WorldVanDerGrintenI$Provider
org.geotools.referencing.operation.projection.Sinusoidal$Provider
org.geotools.referencing.operation.projection.GeneralOblique$Provider
org.geotools.referencing.operation.projection.MeteosatSG$Provider
org.geotools.referencing.operation.projection.GeostationarySatellite$Provider
org.geotools.referencing.operation.projection.RotatedPole$Provider
2016-05-27 14:41:00,549 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,551 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:41:00,551 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:41:00,552 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:41:00,552 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:41:00,552 TRACE [geotools.factory] - ENTRY (CSFactory, CS_FACTORY)
2016-05-27 14:41:00,554 INFO [geotools.factory] - Factory implementations for category CSFactory:
2016-05-27 14:41:00,555 TRACE [geotools.factory] - RETURN (CSFactory, CS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:00,570 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:41:00,570 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:00,571 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,574 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,574 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,621 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,621 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,622 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:00,624 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,625 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,625 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:00,625 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,626 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,652 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,652 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,712 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,713 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,717 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,718 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:00,782 INFO [geotools.factory] - Factory implementations for category CRSAuthorityFactory:
org.vfny.geoserver.crs.GeoserverCustomWKTFactory
org.vfny.geoserver.crs.GeoserverOverridingWKTFactory
org.geotools.referencing.factory.epsg.FactoryUsingWKT
org.geotools.referencing.factory.epsg.LongitudeFirstFactory
org.geotools.referencing.factory.epsg.CartesianAuthorityFactory
org.geotools.referencing.factory.wms.AutoCRSFactory
org.geotools.referencing.factory.wms.WebCRSFactory
org.geotools.referencing.factory.URN_AuthorityFactory
org.geotools.referencing.factory.HTTP_AuthorityFactory
org.geotools.referencing.factory.HTTP_URI_AuthorityFactory
org.geotools.referencing.factory.epsg.LongitudeFirstEpsgDecorator
2016-05-27 14:41:00,790 INFO [referencing.factory] - Using “file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/org/vfny/geoserver/crs/override_epsg.properties” as EPSG factory.
2016-05-27 14:41:00,815 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:00,816 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:00,816 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] ThreadedEpsgFactory.
2016-05-27 14:41:00,829 DEBUG [factory.epsg] - Building new data source for org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
2016-05-27 14:41:00,865 DEBUG [factory.epsg] - Building backing store for org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
2016-05-27 14:41:00,879 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:00,880 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:03,217 INFO [referencing.factory] - Connected to EPSG database “jdbc:hsqldb:file:/usr/share/apache-tomcat-7.0.68/temp/Geotools/Databases/HSQL/v8.6.0.0/EPSG;shutdown=true;readonly=true” on “HSQL Database Engine”.
2016-05-27 14:41:03,290 TRACE [geotools.factory] - RETURN (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): found implementation ThreadedHsqlEpsgFactory.
2016-05-27 14:41:03,320 TRACE [geotools.resources] - Loaded resources for English from bundle “org.geotools.resources.i18n”.
2016-05-27 14:41:03,409 INFO [referencing.factory] - Using “/var/lib/geoserver_data/user_projections/epsg.properties” as EPSG factory.
2016-05-27 14:41:03,424 DEBUG [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
2016-05-27 14:41:03,429 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:03,429 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:03,429 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:03,430 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:03,448 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:03,448 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:03,449 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:03,449 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:03,475 DEBUG [referencing.factory] - Failure in the primary factory: No code “EPSG:2927” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”. Now trying the fallback factory…
2016-05-27 14:41:04,192 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:04,192 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:04,216 TRACE [geotools.factory] - ENTRY (CRSFactory, CRS_FACTORY)
2016-05-27 14:41:04,216 TRACE [geotools.factory] - RETURN (CRSFactory, CRS_FACTORY): found implementation ReferencingObjectFactory.
2016-05-27 14:41:04,327 INFO [org.geoserver] - Loaded coverage ‘anyrisk_pop’, enabled
2016-05-27 14:41:04,357 INFO [org.geoserver] - Loaded coverage ‘anyrisk_pop’
2016-05-27 14:41:04,568 DEBUG [gce.imagemosaic] - Unable to load kakadu JPEG2000 reader spi
java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.jp2k.JP2KKakaduImageReaderSpi
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1858)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1701)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.geotools.gce.imagemosaic.ImageMosaicFormatFactory.hasJP2Kakadu(ImageMosaicFormatFactory.java:185)
at org.geotools.gce.imagemosaic.ImageMosaicFormatFactory.(ImageMosaicFormatFactory.java:63)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
at org.geotools.factory.FactoryRegistry.register(FactoryRegistry.java:826)
at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:772)
at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:750)
at org.geotools.coverage.grid.io.GridFormatFinder.scanForPlugins(GridFormatFinder.java:122)
at org.geotools.coverage.grid.io.GridFormatFinder.getAvailableFormats(GridFormatFinder.java:85)
at org.geotools.coverage.grid.io.GridFormatFinder.getFormatArray(GridFormatFinder.java:144)
at org.geoserver.data.util.CoverageStoreUtils.(CoverageStoreUtils.java:45)
at org.geoserver.catalog.ResourcePool.getGridCoverageFormat(ResourcePool.java:1626)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getFormat(CoverageStoreInfoImpl.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:147)
at com.sun.proxy.$Proxy11.getFormat(Unknown Source)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1385)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1342)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1337)
at org.geoserver.wms.WMSValidator.validate(WMSValidator.java:45)
at org.geoserver.catalog.impl.CatalogImpl$CatalogValidatorVisitor.visit(CatalogImpl.java:1724)
at org.geoserver.catalog.impl.LayerInfoImpl.accept(LayerInfoImpl.java:237)
at org.geoserver.catalog.impl.CatalogImpl.postValidate(CatalogImpl.java:1675)
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:690)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:622)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:437)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:223)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:109)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:140)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1143)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:296)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5068)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5584)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1091)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1980)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
2016-05-27 14:41:04,602 INFO [geotools.factory] - Factory implementations for category GridFormatFactorySpi:
org.geotools.gce.arcgrid.ArcGridFormatFactory
org.geotools.gce.geotiff.GeoTiffFormatFactorySpi
org.geotools.gce.gtopo30.GTopo30FormatFactory
org.geotools.gce.image.WorldImageFormatFactory
org.geotools.coverageio.gdal.mrsid.MrSIDFormatFactory
org.geotools.coverageio.gdal.jp2kak.JP2KFormatFactory
org.geotools.coverageio.gdal.jp2mrsid.JP2MrSIDFormatFactory
org.geotools.coverageio.gdal.jp2ecw.JP2ECWFormatFactory
org.geotools.coverageio.gdal.ecw.ECWFormatFactory
org.geotools.coverageio.gdal.dted.DTEDFormatFactory
org.geotools.coverageio.gdal.erdasimg.ErdasImgFormatFactory
org.geotools.coverageio.gdal.idrisi.IDRISIFormatFactory
org.geotools.coverageio.gdal.nitf.NITFFormatFactory
org.geotools.coverageio.gdal.ehdr.EsriHdrFormatFactory
org.geotools.coverageio.gdal.envihdr.EnviHdrFormatFactory
org.geotools.coverageio.gdal.aig.AIGFormatFactory
org.geotools.coverageio.gdal.rpftoc.RPFTOCFormatFactory
2016-05-27 14:41:04,603 DEBUG [gdal.envihdr] - EnviHdrFormatFactory is not availaible.
2016-05-27 14:41:04,603 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
2016-05-27 14:41:04,604 DEBUG [gdal.rpftoc] - RPFTOCFormatFactory is not availaible.
2016-05-27 14:41:04,609 DEBUG [gdal.nitf] - NITFFormatFactory is not availaible.
2016-05-27 14:41:04,612 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
2016-05-27 14:41:04,613 DEBUG [gdal.jp2k] - JP2KFormatFactory is not availaible.
2016-05-27 14:41:04,613 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not availaible.
2016-05-27 14:41:04,614 DEBUG [gdal.ecw] - ECWFormatFactory is not availaible.
2016-05-27 14:41:04,614 DEBUG [gdal.dted] - DTEDFormatFactory is not availaible.
2016-05-27 14:41:04,699 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
2016-05-27 14:41:05,412 TRACE [geotools.factory] - ENTRY (DatumFactory, DATUM_FACTORY)
2016-05-27 14:41:05,413 TRACE [geotools.factory] - RETURN (DatumFactory, DATUM_FACTORY): found implementation DatumAliases.
2016-05-27 14:41:05,413 TRACE [geotools.factory] - ENTRY (MathTransformFactory, MATH_TRANSFORM_FACTORY)
2016-05-27 14:41:05,413 TRACE [geotools.factory] - RETURN (MathTransformFactory, MATH_TRANSFORM_FACTORY): found implementation DefaultMathTransformFactory.
2016-05-27 14:41:05,417 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,417 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,418 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,418 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,420 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,421 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,421 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,422 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,439 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,439 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,440 INFO [geotools.factory] - Factory implementations for category CSAuthorityFactory:
2016-05-27 14:41:05,442 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,442 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,442 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,443 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,445 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,446 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,446 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,447 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,447 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,447 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,448 INFO [geotools.factory] - Factory implementations for category DatumAuthorityFactory:
2016-05-27 14:41:05,449 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,465 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,465 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,466 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,473 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,474 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,475 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,488 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,488 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory will not timeout
2016-05-27 14:41:05,489 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,490 TRACE [geotools.factory] - RETURN (ReferencingFactoryContainer): found implementation ReferencingFactoryContainer.
2016-05-27 14:41:05,490 TRACE [geotools.factory] - ENTRY (ReferencingFactoryContainer)
2016-05-27 14:41:05,490 DEBUG [referencing.factory] - The EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not timeout
2016-05-27 14:41:05,491 INFO [geotools.factory] - Factory implementations for category CoordinateOperationAuthorityFactory:
org.vfny.geoserver.crs.GeoserverWKTOperationFactory
org.geotools.referencing.factory.epsg.CoordinateOperationFactoryUsingWKT
2016-05-27 14:41:05,492 INFO [referencing.factory] - user_projections/epsg_operations.properties was not found, using the default set of coordinate operation overrides (normally empty)
2016-05-27 14:41:05,494 INFO [referencing.factory] - Using “file:/usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib/gs-main-2.9-RC1.jar!/org/vfny/geoserver/crs/epsg_operations.properties” as EPSG factory.
2016-05-27 14:41:05,497 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,498 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,498 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,498 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,519 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,520 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,520 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,520 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,522 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,522 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,524 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,524 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - ENTRY (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
2016-05-27 14:41:05,542 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - CHECK (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last] AbstractEpsgMediator.
2016-05-27 14:41:05,542 TRACE [geotools.factory] - THROW (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
2016-05-27 14:41:05,545 DEBUG [referencing.factory] - Failure in the primary factory: No code “EPSG:4269” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”. Now trying the fallback factory…
2016-05-27 14:41:05,767 DEBUG [imageio.geotiff] - Logging tiePoints:
Tie point
Raster Space point (0.0, 0.0, 0.0)
Model Space point (-2.8629725402267642E7, 8514374.688731242, 0.0)
Logging pixScales:
Pixel Scale
scaleX=1000.0 is set? true
scaleY=1000.0 is set? true
scaleZ=0.0 is set? false
2016-05-27 14:41:05,833 INFO [org.geoserver] - Loaded layer ‘anyrisk_pop’
2016-05-27 14:41:06,439 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:06,529 INFO [config.XMLFileResourceProvider] - Found configuration file in gwc
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - ********************************************************************************
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
2016-05-27 14:41:06,855 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
2016-05-27 14:41:07,196 DEBUG [grid.GridSetBroker] - Adding EPSG:4326
2016-05-27 14:41:07,205 DEBUG [grid.GridSetBroker] - Adding EPSG:900913 grid set for Spherical Mercator / GoogleMapsCompatible
2016-05-27 14:41:07,205 DEBUG [grid.GridSetBroker] - Adding GlobalCRS84Pixel
2016-05-27 14:41:07,206 DEBUG [grid.GridSetBroker] - Adding GlobalCRS84Scale
2016-05-27 14:41:07,206 DEBUG [grid.GridSetBroker] - Adding GoogleCRS84Quad
2016-05-27 14:41:07,317 DEBUG [layer.TileLayerDispatcher] - Thread initLayers(), initializing
2016-05-27 14:41:07,317 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2016-05-27 14:41:07,318 INFO [gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
2016-05-27 14:41:07,320 INFO [gwc.layer] - Loading tile layers from gwc-layers
2016-05-27 14:41:07,320 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:07,399 DEBUG [gwc.layer] - Loaded tile layer ‘pdmp:anyrisk_pop’
2016-05-27 14:41:07,507 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:07,538 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2016-05-27 14:41:07,539 DEBUG [layer.TileLayerDispatcher] - Reading service information.
2016-05-27 14:41:07,539 INFO [config.XMLConfiguration] - Initializing GridSets from gwc
2016-05-27 14:41:07,539 INFO [config.XMLConfiguration] - Initializing layers from gwc
2016-05-27 14:41:07,539 INFO [layer.TileLayerDispatcher] - Configuration gwc contained no layers.
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - Java environment variable GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - Servlet context parameter GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,578 DEBUG [storage.DefaultStorageFinder] - System environment variable GEOWEBCACHE_CACHE_DIR is unset
2016-05-27 14:41:07,579 DEBUG [storage.DefaultStorageFinder] - Java environment variable GEOSERVER_DATA_DIR is unset
2016-05-27 14:41:07,579 INFO [storage.DefaultStorageFinder] - **************************************************************************************************************************
2016-05-27 14:41:07,579 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOSERVER_DATA_DIR set to /var/lib/geoserver_data, using it as the default prefix. ***
2016-05-27 14:41:07,600 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,606 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,606 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Configuring Expire After Access eviction policy
2016-05-27 14:41:07,689 DEBUG [guava.GuavaCacheProvider] - Configuring Scheduled Task for cache eviction
2016-05-27 14:41:07,705 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,706 DEBUG [memory.MemoryBlobStore] - Setting cache provided
2016-05-27 14:41:07,706 DEBUG [memory.MemoryBlobStore] - CacheProvider already configured
2016-05-27 14:41:07,710 DEBUG [memory.MemoryBlobStore] - Setting the wrapped store
2016-05-27 14:41:07,710 DEBUG [guava.GuavaCacheProvider] - Cache is already reset
2016-05-27 14:41:07,710 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:07,790 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:07,834 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
2016-05-27 14:41:07,896 INFO [diskquota.ConfigLoader] - DiskQuota configuration is not readable: gwc/geowebcache-diskquota.xml
2016-05-27 14:41:07,902 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2016-05-27 14:41:07,902 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2016-05-27 14:41:07,903 INFO [diskquota.DiskQuotaMonitor] - 1 layers attached to global quota 500.0 MB
2016-05-27 14:41:07,968 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2016-05-27 14:41:07,972 DEBUG [diskquota.DiskQuotaMonitor] - pdmp:anyrisk_pop has no saved used quota information,traversing layer cache to compute its disk usage.
2016-05-27 14:41:08,718 INFO [geotools.image] - Warp/affine reduction enabled: true
2016-05-27 14:41:08,915 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wcs’, available services were
2016-05-27 14:41:08,931 INFO [org.geoserver] - Loaded service ‘wcs’, disabled
2016-05-27 14:41:09,004 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wfs’, available services were [WCSInfoImpl[WCS]]
2016-05-27 14:41:09,018 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2016-05-27 14:41:09,069 DEBUG [config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id ‘wms’, available services were [WCSInfoImpl[WCS], WFSInfoImpl[WFS]]
2016-05-27 14:41:09,077 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2016-05-27 14:41:09,127 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2016-05-27 14:41:09,153 DEBUG [gwc.config] - GWC GeoServer specific configuration loaded from gwc-gs.xml
2016-05-27 14:41:09,153 DEBUG [guava.GuavaCacheProvider] - Reset Cache internally
2016-05-27 14:41:09,154 DEBUG [guava.GuavaCacheProvider] - Flushing cache
2016-05-27 14:41:09,154 DEBUG [guava.GuavaCacheProvider] - Removing Layers
2016-05-27 14:41:09,176 DEBUG [guava.GuavaCacheProvider] - Building new Cache
2016-05-27 14:41:09,177 DEBUG [gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl–402275cb_154f14e976c_-7ffe.xml
2016-05-27 14:41:09,186 INFO [image.jai] - Native acceleration disabled for “Mosaic” operation.
2016-05-27 14:41:09,206 INFO [image.jai] - Native acceleration disabled for “Warp” operation.
2016-05-27 14:41:09,583 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler ‘dispatcher’
2016-05-27 14:41:09,692 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2016-05-27 14:41:09,762 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2016-05-27 14:41:09,877 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2016-05-27 14:41:10,098 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 15 paths
2016-05-27 14:41:10,146 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/rest/**] onto handler ‘gwcRestDispatcher’
2016-05-27 14:41:10,195 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2016-05-27 14:41:10,195 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2016-05-27 14:41:10,298 INFO [config.XMLFileResourceProvider] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data/gwc’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/**] onto handler ‘geowebcacheDispatcher’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/demo/**] onto handler ‘geowebcacheDispatcher’
2016-05-27 14:41:10,338 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/gwc/proxy/**] onto handler ‘gwcProxyDispatcher’
2016-05-27 14:41:14,606 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2016-05-27 14:41:14,640 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2016-05-27 14:41:14,640 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon/**/*] onto handler ‘kmlIconService’
2016-05-27 14:41:15,073 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
2016-05-27 14:41:15,177 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler ‘dispatcher’
2016-05-27 14:41:15,177 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2016-05-27 14:41:15,197 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/styles/**] onto handler ‘filePublisher’
2016-05-27 14:41:15,197 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/www/**] onto handler ‘filePublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/schemas/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/j_acegi_security_check] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/login] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,201 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/j_spring_security_check] onto handler ‘classpathPublisher’
2016-05-27 14:41:15,245 INFO [org.geoserver] - GeoServer configuration lock is enabled
2016-05-27 14:41:15,737 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/rest] onto handler ‘restWrapper’
2016-05-27 14:41:15,737 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/rest/**] onto handler ‘restWrapper’
2016-05-27 14:41:15,746 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2016-05-27 14:41:15,746 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
2016-05-27 14:41:16,766 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/temp/**] onto handler ‘filePublisher’
2016-05-27 14:41:16,822 INFO [concurrent.ScheduledExecutorFactoryBean] - Initializing ExecutorService ‘wcs111timerFactory’
2016-05-27 14:41:19,689 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2016-05-27 14:41:19,701 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
2016-05-27 14:41:19,701 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2016-05-27 14:41:20,188 DEBUG [geotools.xml] - building schema for schema: http://www.opengis.net/gml/3.2
2016-05-27 14:41:31,753 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2016-05-27 14:41:31,753 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
2016-05-27 14:41:31,840 TRACE [geotools.factory] - ENTRY (GridCoverageFactory)
2016-05-27 14:41:31,840 TRACE [geotools.factory] - RETURN (GridCoverageFactory): found implementation GridCoverageFactory.
2016-05-27 14:41:31,988 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
2016-05-27 14:41:31,989 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/openlayers/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/options.png] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,020 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/openlayers3/**] onto handler ‘classpathPublisher’
2016-05-27 14:41:32,299 INFO [context.ContextLoader] - Root WebApplicationContext: initialization completed in 41198 ms
2016-05-27 14:41:33,517 INFO [geoserver.security] - Start reloading user/groups for service named default
2016-05-27 14:41:33,523 INFO [geoserver.security] - Reloading user/groups successful for service named default
2016-05-27 14:41:34,282 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerRememberMeAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@anonymised.com, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@anonymised.com]
2016-05-27 14:41:34,287 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter@…7637…]
2016-05-27 14:41:34,330 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com38…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerLogoutFilter@anonymised.com0…]
2016-05-27 14:41:34,403 DEBUG [security.RESTfulDefinitionSource] - Line 1: /**:GET=ADMIN
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET firstColonIndex= 3
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /:GET antPath= / methods= GET
2016-05-27 14:41:34,404 DEBUG [security.RESTfulDefinitionSource] - methodList = [GET]
2016-05-27 14:41:34,406 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [GET]
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - Line 1: /**:POST,DELETE,PUT=ADMIN
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT firstColonIndex= 3
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /:POST,DELETE,PUT antPath= / methods= POST,DELETE,PUT
2016-05-27 14:41:34,407 DEBUG [security.RESTfulDefinitionSource] - methodList = [POST, DELETE, PUT]
2016-05-27 14:41:34,407 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ADMIN], httpMethods: [POST, DELETE, PUT]
2016-05-27 14:41:34,408 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com…, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@anonymised.com, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@anonymised.com]
2016-05-27 14:41:34,437 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@anonymised.com, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@anonymised.com]
2016-05-27 14:41:34,443 INFO [web.DefaultSecurityFilterChain] - Creating filter chain: org.geoserver.security.GeoServerRequestMatcher@anonymised.com, [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter@anonymised.com, org.geoserver.security.filter.GeoServerBasicAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter@anonymised.com, org.geoserver.security.filter.GeoServerExceptionTranslationFilter@anonymised.com, org.geoserver.security.filter.GeoServerSecurityInterceptorFilter@anonymised.com]
2016-05-27 14:41:34,469 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
2016-05-27 14:41:34,481 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - AuthenticationCache removing all entries
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - Cache entries #: 0
2016-05-27 14:41:34,481 DEBUG [geoserver.security] - AuthenticationCache removed all entries
2016-05-27 14:44:13,398 INFO [servlet.DispatcherServlet] - FrameworkServlet ‘dispatcher’: initialization started
2016-05-27 14:44:13,417 INFO [support.XmlWebApplicationContext] - Refreshing WebApplicationContext for namespace ‘dispatcher-servlet’: startup date [Fri May 27 14:44:13 PDT 2016]; parent: Root WebApplicationContext
2016-05-27 14:44:13,420 INFO [xml.XmlBeanDefinitionReader] - Loading XML bean definitions from ServletContext resource [/WEB-INF/dispatcher-servlet.xml]
2016-05-27 14:44:14,147 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web] onto handler ‘wicket’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/index.html] onto handler ‘filePublisher’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web/**] onto handler ‘wicket’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Root mapping to handler ‘filePublisher’
2016-05-27 14:44:14,148 INFO [handler.SimpleUrlHandlerMapping] - Mapped URL path [/web/resources/**] onto handler ‘wicket’
2016-05-27 14:44:14,494 INFO [servlet.DispatcherServlet] - FrameworkServlet ‘dispatcher’: initialization completed in 1096 ms
2016-05-27 14:44:14,590 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : ‘Path: /web/, QueryString: null’; against ‘/web/**’
2016-05-27 14:44:14,602 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2016-05-27 14:44:15,479 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,480 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,494 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-05-27 14:44:15,707 DEBUG [org.geoserver] - Thread 31 locking in mode READ
2016-05-27 14:44:15,707 DEBUG [org.geoserver] - Thread 31 got the lock in mode READ
2016-05-27 14:44:18,024 DEBUG [geoserver.security] - Bad credentials
org.springframework.security.authentication.BadCredentialsException: Bad credentials
at org.springframework.security.authentication.dao.DaoAuthenticationProvider.additionalAuthenticationChecks(DaoAuthenticationProvider.java:98)
at org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:165)
at org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:82)
at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1478)
at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.(SecurityHomePageContentProvider.java:105)
at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
at org.apache.wicket.Component.beforeRender(Component.java:1017)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
at org.apache.wicket.Page.onBeforeRender(Page.java:801)
at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
at org.apache.wicket.Component.render(Component.java:2304)
at org.apache.wicket.Page.renderPage(Page.java:1018)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1078)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
2016-05-27 14:44:18,395 INFO [geoserver.security] - Strong cryptography is available
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Friday, May 27, 2016 12:49 AM
To: Curtis Mack
Cc: geoserver-users@anonymised.coms.sourceforge.net
Subject: Re: [Geoserver-users] GDAL Extention installed, but formats not showing on the list of options
Hi Curtis,
You already said that the log doesn’t report any error.
When GeoServer starts with GDAL jars in place, it should log one of these 2 messages (depending on native libs availability/unavailability).
When successfully loaded:
GDAL Native Library loaded (version: 1.9.2)
When missing:
Failed to load the GDAL native libs. This is not a problem
unless you need to use the GDAL plugins: they won’t be enabled
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path)
Do your log contains one of them?
Which logging level did you setup in GeoServer?
You may consider raising it to check if something more is logged.
Please, let us know.
Daniele
On Fri, May 27, 2016 at 2:24 AM, Curtis Mack <curtis.mack@anonymised.com> wrote:
I have a new Centos7 server with Geoserver 2.9-RC1 installed as a Web Archive. I have followed the instructions on http://docs.geoserver.org/latest/en/user/data/raster/gdal.html but am not seeing the GDAL Image Formats on the “New data source” menu. I see no errors in the log. Any help would be appreciated.
Here is some supporting info.
I believe I have GDAL-native setup correctly.
I can run “gdalinfo –version” and it returns “GDAL 1.9.2, released 2012/10/08”.
I run ” /opt/gdal192-CentOS5.8/javainfo/gdalinfo.sh –formats” and get the following.
Supported Formats:
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (rov): Raster Product Format TOC format
ECRGTOC (rov): ECRG TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (rov): CEOS SAR Image
CEOS (rov): CEOS Image
JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+v): ELAS
AIG (rov): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
SDTS (rov): SDTS Raster
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (rov): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (rov): Maptech BSB Nautical Charts
XPM (rwv): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (rov): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
PDS (rov): NASA Planetary Data System
TIL (rov): EarthWatch .TIL
ERS (rw+v): ERMapper .ers Labelled
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
L1B (rov): NOAA Polar Orbiter Level 1b Data Set
FIT (rwv): FIT Image
MrSID (rov): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (rov): MrSID JPEG2000
RMF (rw+v): Raster Matrix Format
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+v): Idrisi Raster A.1
INGR (rw+v): Intergraph Raster
GSAG (rwv): Golden Software ASCII Grid (.grd)
GSBG (rw+v): Golden Software Binary Grid (.grd)
GS7BG (rov): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (rov): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+v): Portable Pixmap Format (netpbm)
DOQ1 (rov): USGS DOQ (Old Style)
DOQ2 (rov): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (rov): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (rov): GSC Geogrid
FAST (rov): EOSAT FAST Format
BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
LAN (rw+v): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (rov): NLAPS Data Format
EIR (rov): Erdas Imagine Raw
DIPEx (rov): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
GTX (rw+v): NOAA Vertical Datum .GTX
LOSLAS (rov): NADCON .los/.las Datum Grid Shift
NTv2 (rw+v): NTv2 Datum Grid Shift
ACE2 (rov): ACE2
SNODAS (rov): Snow Data Assimilation System
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
KMLSUPEROVERLAY (rwv): Kml Super Overlay
XYZ (rwv): ASCII Gridded XYZ
HF2 (rwv): HF2/HFZ heightfield raster
OZI (rov): OziExplorer Image File
CTG (rov): USGS LULC Composite Theme Grid
E00GRID (rov): Arc/Info Export E00 GRID
ZMap (rwv): ZMap Plus Grid
NGSGEOID (rov): NOAA NGS Geoid Height Grids
Usage: gdalinfo [–help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-norat] [-noct] [-mdd domain]* [-checksum] datasetname
I have the data files installed:
ls -l $GDAL_DATA
total 2672
-rwxr-xr-x. 1 root root 1882 Jan 1 2012 compdcs.csv
-rwxr-xr-x. 1 root root 7195 Jan 1 2012 coordinate_axis.csv
-rwxr-xr-x. 1 root root 12025 Jan 1 2012 cubewerx_extra.wkt
-rwxr-xr-x. 1 root root 158260 Jan 1 2012 datum_shift.csv
-rwxr-xr-x. 1 root root 364766 Jan 1 2012 ecw_cs.wkt
-rwxr-xr-x. 1 root root 13898 Jan 1 2012 ellipsoid.csv
-rwxr-xr-x. 1 root root 52 Jan 1 2012 epsg.wkt
-rwxr-xr-x. 1 root root 209629 Jan 1 2012 esri_extra.wkt
-rwxr-xr-x. 1 root root 332546 Jan 1 2012 esri_StatePlane_extra.wkt
-rwxr-xr-x. 1 root root 75845 Jan 1 2012 esri_Wisconsin_extra.wkt
-rwxr-xr-x. 1 root root 49247 Jan 1 2012 gcs.csv
-rwxr-xr-x. 1 root root 513 Jan 1 2012 gcs.override.csv
-rwxr-xr-x. 1 root root 186320 Jan 1 2012 gdal_datum.csv
-rwxr-xr-x. 1 root root 13224 Jan 1 2012 GDALLogoBW.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoColor.svg
-rwxr-xr-x. 1 root root 12495 Jan 1 2012 GDALLogoGS.svg
-rwxr-xr-x. 1 root root 10033 Jan 1 2012 geoccs.csv
-rwxr-xr-x. 1 root root 15804 Jan 1 2012 gt_datum.csv
-rwxr-xr-x. 1 root root 1719 Jan 1 2012 gt_ellips.csv
-rwxr-xr-x. 1 root root 9120 Jan 1 2012 header.dxf
-rwxr-xr-x. 1 root root 60387 Jan 1 2012 nitf_spec.xml
-rwxr-xr-x. 1 root root 6144 Jan 1 2012 nitf_spec.xsd
-rwxr-xr-x. 1 root root 35009 Jan 1 2012 pci_datum.txt
-rwxr-xr-x. 1 root root 3466 Jan 1 2012 pci_ellips.txt
-rwxr-xr-x. 1 root root 566127 Jan 1 2012 pcs.csv
-rwxr-xr-x. 1 root root 1525 Jan 1 2012 pcs.override.csv
-rwxr-xr-x. 1 root root 1664 Jan 1 2012 prime_meridian.csv
-rwxr-xr-x. 1 root root 206531 Jan 1 2012 projop_wparm.csv
-rwxr-xr-x. 1 root root 13553 Jan 1 2012 s57agencies.csv
-rwxr-xr-x. 1 root root 18555 Jan 1 2012 s57attributes_aml.csv
-rwxr-xr-x. 1 root root 7452 Jan 1 2012 s57attributes.csv
-rwxr-xr-x. 1 root root 8981 Jan 1 2012 s57attributes_iw.csv
-rwxr-xr-x. 1 root root 21893 Jan 1 2012 s57expectedinput.csv
-rwxr-xr-x. 1 root root 64289 Jan 1 2012 s57objectclasses_aml.csv
-rwxr-xr-x. 1 root root 31408 Jan 1 2012 s57objectclasses.csv
-rwxr-xr-x. 1 root root 37247 Jan 1 2012 s57objectclasses_iw.csv
-rwxr-xr-x. 1 root root 9216 Jan 1 2012 seed_2d.dgn
-rwxr-xr-x. 1 root root 2048 Jan 1 2012 seed_3d.dgn
-rwxr-xr-x. 1 root root 10619 Jan 1 2012 stateplane.csv
-rwxr-xr-x. 1 root root 12071 Jan 1 2012 trailer.dxf
-rwxr-xr-x. 1 root root 18941 Jan 1 2012 unit_of_measure.csv
-rwxr-xr-x. 1 root root 8152 Jan 1 2012 vertcs.csv
-rwxr-xr-x. 1 root root 908 Jan 1 2012 vertcs.override.csv
ls -l /usr/share/apache-tomcat-7.0.68/webapps/geoserver/WEB-INF/lib
total 65184
-rw-r–r–. 1 root root 62983 Sep 16 2013 activation-1.1.jar
-rw-r–r–. 1 root root 4467 Sep 12 2013 aopalliance-1.0.jar
-rw-r–r–. 1 root root 95313 Sep 16 2013 batik-anim-1.7.jar
-rw-r–r–. 1 root root 401858 Sep 16 2013 batik-awt-util-1.7.jar
-rw-r–r–. 1 root root 558892 Sep 16 2013 batik-bridge-1.7.jar
-rw-r–r–. 1 root root 310919 Sep 16 2013 batik-css-1.7.jar
-rw-r–r–. 1 root root 173530 Sep 16 2013 batik-dom-1.7.jar
-rw-r–r–. 1 root root 10257 Sep 16 2013 batik-ext-1.7.jar
-rw-r–r–. 1 root root 242866 Sep 16 2013 batik-gvt-1.7.jar
-rw-r–r–. 1 root root 504741 Sep 16 2013 batik-js-1.7.jar
-rw-r–r–. 1 root root 73119 Sep 16 2013 batik-parser-1.7.jar
-rw-r–r–. 1 root root 60604 Sep 16 2013 batik-script-1.7.jar
-rw-r–r–. 1 root root 601098 Sep 16 2013 batik-svg-dom-1.7.jar
-rw-r–r–. 1 root root 215274 Sep 16 2013 batik-svggen-1.7.jar
-rw-r–r–. 1 root root 121997 Sep 16 2013 batik-transcoder-1.7.jar
-rw-r–r–. 1 root root 128286 Sep 16 2013 batik-util-1.7.jar
-rw-r–r–. 1 root root 30843 Sep 16 2013 batik-xml-1.7.jar
-rw-r–r–. 1 root root 1824421 Sep 12 2013 bcprov-jdk14-1.46.jar
-rw-r–r–. 1 root root 322362 Sep 16 2013 cglib-nodep-2.2.jar
-rw-r–r–. 1 root root 211652 Sep 12 2013 common-2.6.0.jar
-rw-r–r–. 1 root root 188671 Sep 12 2013 commons-beanutils-1.7.0.jar
-rw-r–r–. 1 root root 263965 Mar 21 2014 commons-codec-1.9.jar
-rw-r–r–. 1 root root 588337 Mar 24 08:25 commons-collections-3.2.2.jar
-rw-r–r–. 1 root root 160519 Dec 22 2013 commons-dbcp-1.4.jar
-rw-r–r–. 1 root root 57779 Sep 12 2013 commons-fileupload-1.2.1.jar
-rw-r–r–. 1 root root 305001 Sep 12 2013 commons-httpclient-3.1.jar
-rw-r–r–. 1 root root 163151 Sep 12 2013 commons-io-2.1.jar
-rw-r–r–. 1 root root 299994 Sep 12 2013 commons-jxpath-1.3.jar
-rw-r–r–. 1 root root 284220 Nov 9 2013 commons-lang-2.6.jar
-rw-r–r–. 1 root root 60686 Sep 12 2013 commons-logging-1.1.1.jar
-rw-r–r–. 1 root root 96203 Sep 16 2013 commons-pool-1.5.3.jar
-rw-r–r–. 1 root root 150629 Sep 12 2013 com.noelios.restlet-1.0.8.jar
-rw-r–r–. 1 root root 14072 Sep 12 2013 com.noelios.restlet.ext.servlet-1.0.8.jar
-rw-r–r–. 1 root root 10114 Sep 16 2013 com.noelios.restlet.ext.simple-1.0.8.jar
-rw-r–r–. 1 root root 342540 May 10 2015 core-0.26.jar
-rw-r–r–. 1 root root 1231403 Sep 12 2013 ecore-2.6.1.jar
-rw-r–r–. 1 root root 203035 Sep 12 2013 ehcache-1.6.2.jar
-rw-r–r–. 1 root root 37176 Sep 16 2013 encoder-1.1.jar
-rw-r–r–. 1 root root 86487 Sep 12 2013 ezmorph-1.0.6.jar
-rw-r–r–. 1 root root 924269 Sep 12 2013 freemarker-2.3.18.jar
-rw-r–r–. 1 root root 31693 Aug 28 2015 GeographicLib-Java-1.44.jar
-rw-r–r–. 1 root root 321652 May 3 10:19 geoserver-2.9-RC1-gdal-plugin.zip
-rw-r–r–. 1 root root 2564 May 3 17:15 gs-gdal-2.9-RC1.jar
-rw-r–r–. 1 root root 194137 May 3 17:11 gs-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 181456 May 3 17:11 gs-kml-2.9-RC1.jar
-rw-r–r–. 1 root root 1824051 May 3 17:10 gs-main-2.9-RC1.jar
-rw-r–r–. 1 root root 170214 May 3 17:09 gs-ows-2.9-RC1.jar
-rw-r–r–. 1 root root 115740 May 3 17:09 gs-platform-2.9-RC1.jar
-rw-r–r–. 1 root root 64502 May 3 17:11 gs-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 266528 May 3 17:11 gs-restconfig-2.9-RC1.jar
-rw-r–r–. 1 root root 57595 May 3 17:10 gs-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 46399 May 3 17:10 gs-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 116478 May 3 17:10 gs-wcs1_0-2.9-RC1.jar
-rw-r–r–. 1 root root 144135 May 3 17:10 gs-wcs1_1-2.9-RC1.jar
-rw-r–r–. 1 root root 432798 May 3 17:10 gs-wcs2_0-2.9-RC1.jar
-rw-r–r–. 1 root root 46004 May 3 17:10 gs-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 1425896 May 3 17:11 gs-web-core-2.9-RC1.jar
-rw-r–r–. 1 root root 374083 May 3 17:12 gs-web-demo-2.9-RC1.jar
-rw-r–r–. 1 root root 367266 May 3 17:11 gs-web-gwc-2.9-RC1.jar
-rw-r–r–. 1 root root 4422 May 3 17:12 gs-web-rest-2.9-RC1.jar
-rw-r–r–. 1 root root 561505 May 3 17:12 gs-web-sec-core-2.9-RC1.jar
-rw-r–r–. 1 root root 23204 May 3 17:12 gs-web-sec-jdbc-2.9-RC1.jar
-rw-r–r–. 1 root root 21131 May 3 17:12 gs-web-sec-ldap-2.9-RC1.jar
-rw-r–r–. 1 root root 76073 May 3 17:12 gs-web-wcs-2.9-RC1.jar
-rw-r–r–. 1 root root 36944 May 3 17:11 gs-web-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 157306 May 3 17:11 gs-web-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 686071 May 3 17:10 gs-wfs-2.9-RC1.jar
-rw-r–r–. 1 root root 958309 May 3 17:11 gs-wms-2.9-RC1.jar
-rw-r–r–. 1 root root 207878 May 2 20:17 gt-api-15-RC1.jar
-rw-r–r–. 1 root root 13977 May 2 20:24 gt-app-schema-resolver-15-RC1.jar
-rw-r–r–. 1 root root 23927 May 2 20:19 gt-arcgrid-15-RC1.jar
-rw-r–r–. 1 root root 59903 May 2 20:24 gt-complex-15-RC1.jar
-rw-r–r–. 1 root root 585183 May 2 20:19 gt-coverage-15-RC1.jar
-rw-r–r–. 1 root root 197346 May 2 20:19 gt-cql-15-RC1.jar
-rw-r–r–. 1 root root 88409 May 2 20:19 gt-data-15-RC1.jar
-rw-r–r–. 1 root root 2330229 May 2 20:18 gt-epsg-hsql-15-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 20:25 gt-geojson-15-RC1.jar
-rw-r–r–. 1 root root 31173 May 2 20:19 gt-geotiff-15-RC1.jar
-rw-r–r–. 1 root root 170468 May 2 20:18 gt-graph-15-RC1.jar
-rw-r–r–. 1 root root 35024 May 2 20:24 gt-grid-15-RC1.jar
-rw-r–r–. 1 root root 38722 May 2 20:22 gt-gtopo30-15-RC1.jar
-rw-r–r–. 1 root root 22658 May 2 20:22 gt-image-15-RC1.jar
-rw-r–r–. 1 root root 79294 May 3 17:15 gt-imageio-ext-gdal-15-RC1.jar
-rw-r–r–. 1 root root 374650 May 2 20:22 gt-imagemosaic-15-RC1.jar
-rw-r–r–. 1 root root 219685 May 2 20:21 gt-jdbc-15-RC1.jar
-rw-r–r–. 1 root root 50882 May 2 20:22 gt-jdbc-postgis-15-RC1.jar
-rw-r–r–. 1 root root 1753607 May 2 20:18 gt-main-15-RC1.jar
-rw-r–r–. 1 root root 510990 May 2 20:17 gt-metadata-15-RC1.jar
-rw-r–r–. 1 root root 351036 May 2 20:17 gt-opengis-15-RC1.jar
-rw-r–r–. 1 root root 59087 May 2 20:25 gt-process-15-RC1.jar
-rw-r–r–. 1 root root 176741 May 2 20:25 gt-process-feature-15-RC1.jar
-rw-r–r–. 1 root root 120766 May 2 20:26 gt-process-raster-15-RC1.jar
-rw-r–r–. 1 root root 24551 May 2 20:19 gt-property-15-RC1.jar
-rw-r–r–. 1 root root 1180650 May 2 20:17 gt-referencing-15-RC1.jar
-rw-r–r–. 1 root root 565938 May 2 20:20 gt-render-15-RC1.jar
-rw-r–r–. 1 root root 219407 May 2 20:19 gt-shapefile-15-RC1.jar
-rw-r–r–. 1 root root 9015 May 2 20:23 gt-svg-15-RC1.jar
-rw-r–r–. 1 root root 40093 May 2 20:22 gt-transform-15-RC1.jar
-rw-r–r–. 1 root root 243470 May 2 20:25 gt-wfs-ng-15-RC1.jar
-rw-r–r–. 1 root root 230688 May 2 20:24 gt-wms-15-RC1.jar
-rw-r–r–. 1 root root 651627 May 2 20:21 gt-xml-15-RC1.jar
-rw-r–r–. 1 root root 313002 May 2 20:18 gt-xsd-core-15-RC1.jar
-rw-r–r–. 1 root root 69559 May 2 20:20 gt-xsd-fes-15-RC1.jar
-rw-r–r–. 1 root root 106563 May 2 20:20 gt-xsd-filter-15-RC1.jar
-rw-r–r–. 1 root root 117409 May 2 20:19 gt-xsd-gml2-15-RC1.jar
-rw-r–r–. 1 root root 1553765 May 2 20:19 gt-xsd-gml3-15-RC1.jar
-rw-r–r–. 1 root root 121602 May 2 20:20 gt-xsd-ows-15-RC1.jar
-rw-r–r–. 1 root root 176648 May 2 20:20 gt-xsd-sld-15-RC1.jar
-rw-r–r–. 1 root root 177013 May 2 20:24 gt-xsd-wcs-15-RC1.jar
-rw-r–r–. 1 root root 148574 May 2 20:20 gt-xsd-wfs-15-RC1.jar
-rw-r–r–. 1 root root 2243036 Jun 3 2014 guava-17.0.jar
-rw-r–r–. 1 root root 570913 May 2 21:44 gwc-core-1.9-RC1.jar
-rw-r–r–. 1 root root 92133 May 2 21:46 gwc-diskquota-core-1.9-RC1.jar
-rw-r–r–. 1 root root 54352 May 2 21:46 gwc-diskquota-jdbc-1.9-RC1.jar
-rw-r–r–. 1 root root 35777 May 2 21:46 gwc-georss-1.9-RC1.jar
-rw-r–r–. 1 root root 8627 May 2 21:46 gwc-gmaps-1.9-RC1.jar
-rw-r–r–. 1 root root 21829 May 2 21:46 gwc-kml-1.9-RC1.jar
-rw-r–r–. 1 root root 63626 May 2 21:46 gwc-rest-1.9-RC1.jar
-rw-r–r–. 1 root root 10648 May 2 21:46 gwc-tms-1.9-RC1.jar
-rw-r–r–. 1 root root 5493 May 2 21:46 gwc-ve-1.9-RC1.jar
-rw-r–r–. 1 root root 62487 May 2 21:46 gwc-wms-1.9-RC1.jar
-rw-r–r–. 1 root root 20021 May 2 21:46 gwc-wmts-1.9-RC1.jar
-rw-r–r–. 1 root root 1207393 Sep 12 2013 h2-1.1.119.jar
-rw-r–r–. 1 root root 1466946 May 25 2015 hsqldb-2.3.0.jar
-rw-r–r–. 1 root root 39860 Nov 6 2015 imageio-ext-arcgrid-1.1.13.jar
-rw-r–r–. 1 root root 5151 May 3 17:15 imageio-ext-gdalarcbinarygrid-1.1.13.jar
-rw-r–r–. 1 root root 94016 May 3 17:15 imageio-ext-gdal-bindings-1.9.2.jar
-rw-r–r–. 1 root root 4938 May 3 17:15 imageio-ext-gdaldted-1.1.13.jar
-rw-r–r–. 1 root root 8106 May 3 17:15 imageio-ext-gdalecw-1.1.13.jar
-rw-r–r–. 1 root root 5083 May 3 17:15 imageio-ext-gdalecwjp2-1.1.13.jar
-rw-r–r–. 1 root root 4939 May 3 17:15 imageio-ext-gdalehdr-1.1.13.jar
-rw-r–r–. 1 root root 5037 May 3 17:15 imageio-ext-gdalenvihdr-1.1.13.jar
-rw-r–r–. 1 root root 5033 May 3 17:15 imageio-ext-gdalerdasimg-1.1.13.jar
-rw-r–r–. 1 root root 57744 May 3 17:15 imageio-ext-gdalframework-1.1.13.jar
-rw-r–r–. 1 root root 5006 May 3 17:15 imageio-ext-gdalidrisi-1.1.13.jar
-rw-r–r–. 1 root root 14978 May 3 17:15 imageio-ext-gdalkakadujp2-1.1.13.jar
-rw-r–r–. 1 root root 8703 May 3 17:15 imageio-ext-gdalmrsid-1.1.13.jar
-rw-r–r–. 1 root root 5129 May 3 17:15 imageio-ext-gdalmrsidjp2-1.1.13.jar
-rw-r–r–. 1 root root 4928 May 3 17:15 imageio-ext-gdalnitf-1.1.13.jar
-rw-r–r–. 1 root root 4981 May 3 17:15 imageio-ext-gdalrpftoc-1.1.13.jar
-rw-r–r–. 1 root root 26688 May 3 17:15 imageio-ext-geocore-1.1.13.jar
-rw-r–r–. 1 root root 26911 May 3 17:15 imageio-ext-imagereadmt-1.1.13.jar
-rw-r–r–. 1 root root 19493 Nov 10 2015 imageio-ext-png-1.1.13.jar
-rw-r–r–. 1 root root 52275 Nov 6 2015 imageio-ext-streams-1.1.13.jar
-rw-r–r–. 1 root root 335165 Nov 6 2015 imageio-ext-tiff-1.1.13.jar
-rw-r–r–. 1 root root 40586 Nov 6 2015 imageio-ext-utilities-1.1.13.jar
-rw-r–r–. 1 root root 1117661 Sep 16 2013 itext-2.1.5.jar
-rw-r–r–. 1 root root 258160 Sep 12 2013 jai_codec-1.1.3.jar
-rw-r–r–. 1 root root 1900631 Sep 12 2013 jai_core-1.1.3.jar
-rw-r–r–. 1 root root 1140632 Sep 12 2013 jai_imageio-1.1.jar
-rw-r–r–. 1 root root 178961 Sep 12 2013 jasypt-1.8.jar
-rw-r–r–. 1 root root 619507 Sep 16 2013 JavaAPIforKml-2.2.0.jar
-rw-r–r–. 1 root root 151304 Sep 29 2013 jdom-1.1.3.jar
-rw-r–r–. 1 root root 56702 Sep 12 2013 jettison-1.0.1.jar
-rw-r–r–. 1 root root 11497 Sep 12 2013 jgridshift-1.0.jar
-rw-r–r–. 1 root root 148490 Sep 12 2013 json-lib-2.2.3-jdk15.jar
-rw-r–r–. 1 root root 16046 Sep 16 2013 json-simple-1.1.jar
-rw-r–r–. 1 root root 91347 Sep 12 2013 jsr-275-1.0-beta-2.jar
-rw-r–r–. 1 root root 33031 Jun 9 2014 jsr305-2.0.3.jar
-rw-r–r–. 1 root root 117361 Apr 1 13:34 jt-affine-1.0.9.jar
-rw-r–r–. 1 root root 62676 Apr 1 13:34 jt-algebra-1.0.9.jar
-rw-r–r–. 1 root root 3839 Aug 26 2015 jt-attributeop-1.4.0.jar
-rw-r–r–. 1 root root 16052 Apr 1 13:34 jt-bandcombine-1.0.9.jar
-rw-r–r–. 1 root root 33911 Apr 1 13:34 jt-bandmerge-1.0.9.jar
-rw-r–r–. 1 root root 8477 Apr 1 13:34 jt-bandselect-1.0.9.jar
-rw-r–r–. 1 root root 14196 Apr 1 13:34 jt-binarize-1.0.9.jar
-rw-r–r–. 1 root root 13683 Apr 1 13:34 jt-border-1.0.9.jar
-rw-r–r–. 1 root root 18964 Apr 1 13:34 jt-buffer-1.0.9.jar
-rw-r–r–. 1 root root 18778 Apr 1 13:34 jt-classifier-1.0.9.jar
-rw-r–r–. 1 root root 64473 Apr 1 13:34 jt-colorconvert-1.0.9.jar
-rw-r–r–. 1 root root 38698 Apr 1 13:34 jt-colorindexer-1.0.9.jar
-rw-r–r–. 1 root root 20682 Apr 11 10:01 jt-concurrent-tile-cache-1.0.9.jar
-rw-r–r–. 1 root root 26019 Aug 26 2015 jt-contour-1.4.0.jar
-rw-r–r–. 1 root root 9840 Apr 1 13:34 jt-crop-1.0.9.jar
-rw-r–r–. 1 root root 18401 Apr 1 13:34 jt-errordiffusion-1.0.9.jar
-rw-r–r–. 1 root root 7110 Apr 1 13:34 jt-format-1.0.9.jar
-rw-r–r–. 1 root root 12696 Apr 1 13:34 jt-imagefunction-1.0.9.jar
-rw-r–r–. 1 root root 24170 Apr 1 13:34 jt-iterators-1.0.9.jar
-rw-r–r–. 1 root root 39688 Apr 1 13:34 jt-lookup-1.0.9.jar
-rw-r–r–. 1 root root 31245 Apr 1 13:34 jt-mosaic-1.0.9.jar
-rw-r–r–. 1 root root 7018 Apr 1 13:34 jt-nullop-1.0.9.jar
-rw-r–r–. 1 root root 25802 Apr 1 13:34 jt-orderdither-1.0.9.jar
-rw-r–r–. 1 root root 36758 Apr 1 13:34 jt-piecewise-1.0.9.jar
-rw-r–r–. 1 root root 16779 Aug 26 2015 jt-rangelookup-1.4.0.jar
-rw-r–r–. 1 root root 19233 Apr 1 13:34 jt-rescale-1.0.9.jar
-rw-r–r–. 1 root root 18290 Apr 1 13:34 jt-rlookup-1.0.9.jar
-rw-r–r–. 1 root root 794991 Sep 12 2013 jts-1.13.jar
-rw-r–r–. 1 root root 89274 Apr 1 13:34 jt-scale-1.0.9.jar
-rw-r–r–. 1 root root 34648 Apr 1 13:34 jt-stats-1.0.9.jar
-rw-r–r–. 1 root root 9981 Apr 1 13:34 jt-translate-1.0.9.jar
-rw-r–r–. 1 root root 117852 Apr 1 13:34 jt-utilities-1.0.9.jar
-rw-r–r–. 1 root root 202267 Aug 26 2015 jt-utils-1.4.0.jar
-rw-r–r–. 1 root root 19124 Apr 1 13:34 jt-vectorbin-1.0.9.jar
-rw-r–r–. 1 root root 10574 Aug 26 2015 jt-vectorbinarize-1.4.0.jar
-rw-r–r–. 1 root root 14229 Aug 26 2015 jt-vectorize-1.4.0.jar
-rw-r–r–. 1 root root 65330 Apr 1 13:34 jt-warp-1.0.9.jar
-rw-r–r–. 1 root root 32813 Apr 1 13:34 jt-zonal-1.0.9.jar
-rw-r–r–. 1 root root 19970 Aug 26 2015 jt-zonalstats-1.4.0.jar
-rw-r–r–. 1 root root 571 Sep 18 2013 LICENSE.txt
-rw-r–r–. 1 root root 489884 Apr 29 17:45 log4j-1.2.17.jar
-rw-r–r–. 1 root root 388864 Sep 16 2013 mail-1.4.jar
-rw-r–r–. 1 root root 231977 May 2 20:20 net.opengis.fes-15-RC1.jar
-rw-r–r–. 1 root root 532372 May 2 20:20 net.opengis.ows-15-RC1.jar
-rw-r–r–. 1 root root 661862 May 2 20:21 net.opengis.wcs-15-RC1.jar
-rw-r–r–. 1 root root 429390 May 2 20:20 net.opengis.wfs-15-RC1.jar
-rw-r–r–. 1 root root 48752 Sep 16 2013 org.json-2.0.jar
-rw-r–r–. 1 root root 175177 Sep 12 2013 org.restlet-1.0.8.jar
-rw-r–r–. 1 root root 2180 Sep 12 2013 org.restlet.ext.freemarker-1.0.8.jar
-rw-r–r–. 1 root root 1730 Sep 16 2013 org.restlet.ext.json-1.0.8.jar
-rw-r–r–. 1 root root 4504 Sep 12 2013 org.restlet.ext.spring-1.0.8.jar
-rw-r–r–. 1 root root 225333 Sep 16 2013 org.simpleframework-3.1.3.jar
-rw-r–r–. 1 root root 53222 May 2 20:20 org.w3.xlink-15-RC1.jar
-rw-r–r–. 1 root root 112635 Sep 12 2013 picocontainer-1.2.jar
-rw-r–r–. 1 root root 142870 Oct 14 2013 pngj-2.0.1.jar
-rw-r–r–. 1 root root 648487 Jun 10 2015 postgresql-9.4-1201-jdbc41.jar
-rw-r–r–. 1 root root 566 Jan 23 02:21 README.TXT
-rw-r–r–. 1 root root 25962 Sep 16 2013 slf4j-api-1.6.4.jar
-rw-r–r–. 1 root root 9748 Sep 16 2013 slf4j-log4j12-1.6.4.jar
-rw-r–r–. 1 root root 370067 Mar 23 20:52 spring-aop-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 731562 Mar 23 20:52 spring-beans-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1096773 Mar 23 20:52 spring-context-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 176774 Mar 23 22:00 spring-context-support-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 1078771 Mar 23 20:52 spring-core-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 262988 Mar 23 20:52 spring-expression-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 423659 Mar 23 20:52 spring-jdbc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 374411 Mar 23 21:59 spring-ldap-core-2.0.2.RELEASE.jar
-rw-r–r–. 1 root root 473345 Mar 23 20:54 spring-security-config-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 357254 Mar 23 20:54 spring-security-core-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 103988 Mar 23 21:58 spring-security-ldap-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 326872 Mar 23 20:54 spring-security-web-4.0.4.RELEASE.jar
-rw-r–r–. 1 root root 265523 Mar 23 20:52 spring-tx-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 767232 Mar 23 20:52 spring-web-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 876937 Mar 23 20:52 spring-webmvc-4.2.5.RELEASE.jar
-rw-r–r–. 1 root root 179346 Sep 16 2013 stax-1.2.0.jar
-rw-r–r–. 1 root root 26514 Sep 12 2013 stax-api-1.0.1.jar
-rw-r–r–. 1 root root 2198941 Jan 23 03:14 wicket-core-7.1.0.jar
-rw-r–r–. 1 root root 1274149 Jan 23 03:14 wicket-extensions-7.1.0.jar
-rw-r–r–. 1 root root 87937 Jan 23 03:14 wicket-request-7.1.0.jar
-rw-r–r–. 1 root root 376657 Jan 23 03:14 wicket-util-7.1.0.jar
-rw-r–r–. 1 root root 220536 May 7 2015 xml-apis-1.4.01.jar
-rw-r–r–. 1 root root 85686 Sep 16 2013 xml-apis-ext-1.3.04.jar
-rw-r–r–. 1 root root 84091 Sep 16 2013 xml-commons-resolver-1.2.jar
-rw-r–r–. 1 root root 7188 Sep 12 2013 xmlpull-1.1.3.1.jar
-rw-r–r–. 1 root root 119888 Sep 12 2013 xpp3-1.1.3.4.O.jar
-rw-r–r–. 1 root root 24956 Sep 12 2013 xpp3_min-1.1.4c.jar
-rw-r–r–. 1 root root 992820 Sep 12 2013 xsd-2.6.0.jar
-rw-r–r–. 1 root root 531571 Feb 23 2014 xstream-1.4.7.jar
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
